MediaBrowser Error 500 after upgrade 1.4
dpolak
Post Tue Dec 24, 2013 1:03 am
Everyone,
I searched the forum as best as possible before I posted this. I have serviio running on OpenSuSE and it has been flawless from 0.x to 1.3.1 including MediaBrowser.
On the last update I did what I normally do, update the console on my Windows workstation, pointing it to the server and copying all files from the new tar to the current working directory on the server.
I have confirmed that ownership of all the files are the same as the previous version.
Now when I try to access MediaBrowser I get "Unknown server error (500, undefined)" after I log in. I also can no longer view the library through any of my Android devices running the Serviio client.
I changed the server to DEBUG mode but I do not see any errors. Your help would be greatly appreciated. If I can't get it to work I will just restore the backup of 1.3.1 I did before the upgrade.
Here is the log file, I deleted the old one to have a clean start on debug.
log4j:ERROR setFile(null,true) call failed.
java.io.FileNotFoundException: /log/serviio.log (No such file or directory)
        at java.io.FileOutputStream.open(Native Method)
        at java.io.FileOutputStream.<init>(FileOutputStream.java:212)
        at java.io.FileOutputStream.<init>(FileOutputStream.java:136)
        at org.apache.log4j.FileAppender.setFile(FileAppender.java:294)
        at org.apache.log4j.RollingFileAppender.setFile(RollingFileAppender.java
:207)
        at org.apache.log4j.FileAppender.activateOptions(FileAppender.java:165)
        at org.apache.log4j.config.PropertySetter.activate(PropertySetter.java:3
07)
        at org.apache.log4j.xml.DOMConfigurator.parseAppender(DOMConfigurator.ja
va:295)
        at org.apache.log4j.xml.DOMConfigurator.findAppenderByName(DOMConfigurat
or.java:176)
        at org.apache.log4j.xml.DOMConfigurator.findAppenderByReference(DOMConfi
gurator.java:191)
        at org.apache.log4j.xml.DOMConfigurator.parseChildrenOfLoggerElement(DOM
Configurator.java:523)
        at org.apache.log4j.xml.DOMConfigurator.parseRoot(DOMConfigurator.java:4
92)
        at org.apache.log4j.xml.DOMConfigurator.parse(DOMConfigurator.java:1001)
        at org.apache.log4j.xml.DOMConfigurator.doConfigure(DOMConfigurator.java
:867)
:773)
        at org.apache.log4j.helpers.OptionConverter.selectAndConfigure(OptionCon
verter.java:483)
        at org.apache.log4j.LogManager.<clinit>(LogManager.java:127)
        at org.slf4j.impl.Log4jLoggerFactory.getLogger(Log4jLoggerFactory.java:7
3)
        at org.slf4j.LoggerFactory.getLogger(LoggerFactory.java:242)
        at org.slf4j.LoggerFactory.getLogger(LoggerFactory.java:254)
        at org.serviio.MediaServer.<clinit>(MediaServer.java:72)
/usr/bin/serviio: line 68:   874 Killed                  "$JAVA" -Xmx512M -Xms20
M -XX:+UseParNewGC -XX:MinHeapFreeRatio=10 -XX:MaxHeapFreeRatio=20 $JAVA_OPTS -c
lasspath "$SERVIIO_CLASS_PATH" org.serviio.MediaServer "$@"
Post Tue Dec 24, 2013 6:08 pm
Re: MediaBrowser Error 500 after upgrade 1.4
It says it cannot find your log file, so I would guess that you made an error when you updated, because it would have been there before you started.
dpolak
Post Wed Dec 25, 2013 12:37 am
The error because the log was deleted before I ran the server in debug mode to get a clean file.
The log file resides in /var/log.
This was weird as I've never had an issue upgrading in the past.
All help and suggestions are greatly appreciated!
dpolak
Post Wed Dec 25, 2013 9:37 pm
Just an update for everyone. I decided to restore my 1.3.1 until a resolution is found for the issue I have. Works perfectly again, mediabrowser comes up with no issues and full of content.
I think something went wrong with 1.4 and the upgrade. Hopefully we can get it resolved.
Ralle88
Post Thu Dec 26, 2013 4:37 pm
1.4.0-0024 -> Firefox Error 26.0 > MediaBrowser "Unknown server error (500, undefined)
1.4.0-0024 -> Internet Explorer > MediaBrowser works :-)
Link: http://192.168.xxx.xxx:23424/mediabrowser/#/browse
dpolak
Post Fri Dec 27, 2013 12:07 am
Thanks Ralle88 but totally different issue. I've tried it with Chrome, Internet Exploder and it doesn't even work with the Serviio Android app.
I have also noticed that it will sometimes show no content through DLNA.
I've never had an issue with Serviio until this version.
