What profile should I choose?
cevepe
Post Wed Dec 25, 2013 8:56 pm
I have a new TV, but I want to ask which profile to use for DLNA stream VLC. I have a Panasonic TV TX-L32E6E
Post Wed Dec 25, 2013 10:53 pm
Re: What profile should I choose?
Either the Panasonic Viera G/GT/DT/UT/VT (2011/2012) profile that is packaged with Serviio, or you could try the Panasonic 2013 profile being developed here: viewtopic.php?f=13&t=12367
cevepe
Post Thu Dec 26, 2013 11:15 am
How do I embed the profile in Serviio? :oops:
Post Fri Dec 27, 2013 2:07 am
Edit your profiles.xml file located in the Serviio/config folder, using any text editor (you may want to back this file up first in case of issues). Copy and paste the profile from the link above , pasting it just above the final line (ie. between the line containing "</Profile>" and the one containing "</Profiles>").
You need to restart your PC (or restart the Serviio service if you know how to do that) after making any changes to profiles.xml. If Serviio fails to start you have likely done something wrong so start again from the backup.
