Tv not displaying Serviio after PC reboot
boben88
Post Sat Dec 28, 2013 4:49 pm
Hello! I am new to this, and ive been searching on google and on this forum for a possible solution. There is a chance that ive missed an solution, if that is the case. Then i am truly sorry.
So, 3 days ago I bought a Sony KDL-55W905A and got it home. Ive read about Serviio being one of the best programs to stream from PC to TV wireless. So speeding forward; at my first installment of Serviio 1.4, everything went smoothly and everything worked, I could stream movies with subtitles etc and TV displayed Serviio as a mediaserver. I was very happy that this worked smoothly.
But... After a reboot of my PC my TV suddenly stops displaying the Serviio server. It simply says "Disconnected" when i open the list of Mediaplayers on my TV. So one possible solution to this was to bound the IP to my network card. I have tried so and even inactivated the different networkcards i have installed in my computer. I have also tried to enter services.msc to stop and start Serviio service, but it does not work. I have also tried putting Serviio on a delayed start, gotten the same result.
I only came up with ONE solution that works, and that is to uninstall Serviio on my computer, and then installing it again. Then my TV displays Serviio and I can stream movies again like nothing ever happened. However, after a reboot once again the TV does not display the Serviio mediaserver anymore. So now for these past few days, the only method for me to watch streamed movies on my TV from my PC is that I have to uninstall everytime after ive rebooted. I find this pretty annoying in the long-run, and im looking for a longterm solution.
TDLR: Tv does not display Serviio after PC reboot. Forced to uninstall and install Serviio after a reboot to make it work. Using Windows7 Proff.
I am grateful that you took your time to read this post, and ill be even more grateful if it somehow can be fixed. Happy New Years from Sweden!
boben88
Post Fri Jan 03, 2014 6:18 pm
Re: Tv not displaying Serviio after PC reboot
Bump bump! Anyone with a possible solution or experianced anything like this?
bolzass
Post Fri Jan 03, 2014 10:53 pm
Hi!,
Just a question (I don't know anything about Windows installer).
You have checked ip, service running (and process), etc... And what about firewall?
npuser
Post Sat Jan 04, 2014 1:41 am
could you post a serviio.log after a clean reboot?
thanks
NPuser
Iveky
Post Sat Jan 04, 2014 11:21 am
check windows firewall ports...
boben88
Post Sat Jan 04, 2014 8:04 pm
npuser wrote:could you post a serviio.log after a clean reboot?
thanks
NPuser
Yes, of course. Bad from me not doing it from beginning.. I tried to remove the "useless" information such as which movies i got in folder and profiles.
2014-01-04 20:48:34,296 INFO  [ServiioConsole] Initializing Serviio Console
2014-01-04 20:48:34,358 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2014-01-04 20:48:34,374 INFO  [MediaServer] ------------------------------------------------------------------------
2014-01-04 20:48:34,374 INFO  [MediaServer] Serviio DLNA media streaming server v 1.4 (rev. c307c4dd528d)
2014-01-04 20:48:34,374 INFO  [MediaServer] Petr Nejedly 2009-2013
2014-01-04 20:48:34,374 INFO  [MediaServer] http://www.serviio.org
2014-01-04 20:48:34,374 INFO  [MediaServer] Java 1.7.0_05-Oracle Corporation
2014-01-04 20:48:34,374 INFO  [MediaServer] OS Windows 7 amd64 6.1
2014-01-04 20:48:34,374 INFO  [MediaServer] File encoding: windows-1252
2014-01-04 20:48:34,374 INFO  [MediaServer] Headless mode enabled: true
2014-01-04 20:48:34,374 INFO  [MediaServer] User: KINLOL$
2014-01-04 20:48:34,374 INFO  [MediaServer] User home dir: C:\
2014-01-04 20:48:34,374 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2014-01-04 20:48:36,449 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2014-01-04 20:48:36,449 INFO  [ServiioConsole] Starting Serviio Console
2014-01-04 20:48:36,667 INFO  [WebServer] Socket buffer set to 65535 bytes
2014-01-04 20:48:36,683 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2014-01-04 20:48:36,776 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2014-01-04 20:48:36,776 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2014-01-04 20:48:36,807 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2014-01-04 20:48:36,823 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2014-01-04 20:48:39,428 DEBUG [SwingHelper] Choosing java look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
2014-01-04 20:48:39,631 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2014-01-04 20:48:39,631 DEBUG [ServiioConsole] Checking if server is running
2014-01-04 20:48:45,403 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2014-01-04 20:48:45,403 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2014-01-04 20:48:45,403 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2014-01-04 20:48:45,403 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2014-01-04 20:48:45,419 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2014-01-04 20:48:45,419 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2014-01-04 20:48:45,419 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2014-01-04 20:48:45,419 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2014-01-04 20:48:45,419 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2014-01-04 20:48:45,419 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2014-01-04 20:48:45,419 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2014-01-04 20:48:45,419 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2014-01-04 20:48:45,419 DEBUG [DBLogDAOImpl] Checking if script 'script-1.1.sql' has been run
2014-01-04 20:48:45,419 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.sql' has been run
2014-01-04 20:48:45,419 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.1.sql' has been run
2014-01-04 20:48:45,434 DEBUG [DBLogDAOImpl] Checking if script 'script-1.3.sql' has been run
2014-01-04 20:48:45,434 DEBUG [DBLogDAOImpl] Checking if script 'script-1.4.sql' has been run
2014-01-04 20:48:45,450 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2014-01-04 20:48:45,465 DEBUG [LicenseValidator] Validating license file (348 bytes)
2014-01-04 20:48:46,043 INFO  [MediaServer] ------------------------------------------------------------------------
2014-01-04 20:48:46,043 INFO  [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2014-01-04 20:48:46,043 DEBUG [LocalAddressResolverStrategy] Resolving host IP address automatically
2014-01-04 20:48:46,604 INFO  [Device] Created UPnP Device with UUID: 223a9375-eb61-3269-abcf-3ad9f2e63b1f, bound address: 192.168.1.6
2014-01-04 20:48:48,570 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2014-01-04 20:48:48,570 INFO  [PluginCompilerThread] Started looking for plugins
2014-01-04 20:48:48,570 INFO  [UpdateChecker] Checking if a new version is available
2014-01-04 20:48:48,570 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2014-01-04 20:48:48,585 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2014-01-04 20:48:48,773 INFO  [FFMPEGWrapper] Found FFmpeg: ffmpeg version N-54096-ge41bf19 Copyright (c) 2000-2013 the FFmpeg developers
2014-01-04 20:48:48,788 DEBUG [DCRawWrapper] Invoking DCRAW to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/dcraw.exe
2014-01-04 20:48:48,788 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/dcraw.exe
2014-01-04 20:48:48,882 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2014-01-04 20:48:48,882 DEBUG [AbstractTranscodingDeliveryEngine] Deleting temporary transcoded files from: C:\Windows\TEMP\Serviio
2014-01-04 20:48:48,944 DEBUG [LocalAddressResolverStrategy] Resolving host IP address automatically
2014-01-04 20:48:48,944 INFO  [WebServer] WebServer starting on port 8895
2014-01-04 20:48:49,506 INFO  [Device] Updated bound IP address of Device with UUID: 223a9375-eb61-3269-abcf-3ad9f2e63b1f, bound address: 192.168.1.6
2014-01-04 20:48:49,521 DEBUG [DiscoveryManager] UPNP device 223a9375-eb61-3269-abcf-3ad9f2e63b1f (192.168.1.6) is available
2014-01-04 20:48:49,521 INFO  [EventDispatcher] Starting EventDispatcher
2014-01-04 20:48:49,521 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2014-01-04 20:48:49,521 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2014-01-04 20:48:49,521 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2014-01-04 20:48:49,599 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net3 (D-Link DWA-140 RangeBooster N USB Adapter(rev.B2)) and address 192.168.1.6, timeout = 0
2014-01-04 20:48:49,662 INFO  [RendererSearchSender] Searching for Renderer devices
2014-01-04 20:48:49,662 DEBUG [RendererSearchSender$RendererSearchWorker] Multicasting SSDP M-SEARCH using interface net3 (D-Link DWA-140 RangeBooster N USB Adapter(rev.B2)) and address 192.168.1.6, timeout = 0
2014-01-04 20:48:49,662 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net3 (D-Link DWA-140 RangeBooster N USB Adapter(rev.B2)) and address 192.168.1.6, timeout = 0
2014-01-04 20:48:49,677 DEBUG [RendererSearchSender$RendererSearchWorker] Sending 1 'm-search' messages
2014-01-04 20:48:49,677 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 223a9375-eb61-3269-abcf-3ad9f2e63b1f
2014-01-04 20:48:49,693 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.6:53562s
2014-01-04 20:48:50,473 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.1.9:52323/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2014-01-04 20:48:50,473 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 00000000-0000-1010-8000-d8d43c9fbae9 from address 192.168.1.9
2014-01-04 20:48:50,504 DEBUG [RendererManager] Adding renderer Renderer [uuid=00000000-0000-1010-8000-d8d43c9fbae9, ipAddress=192.168.1.9, name=KDL-55W905A, profileId=sony2013, manuallyAdded=false, forcedProfile=false, enabled=true, accessGroupId=1] to list of active renderers
2014-01-04 20:48:51,643 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:07 (advertisement duration is 1800 sec.)
2014-01-04 20:48:52,357 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.1.9:52323/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2014-01-04 20:48:52,361 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 00000000-0000-1010-8000-d8d43c9fbae9 from address 192.168.1.9
2014-01-04 20:48:52,454 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.1.9:52323/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2014-01-04 20:48:52,454 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 00000000-0000-1010-8000-d8d43c9fbae9 from address 192.168.1.9
2014-01-04 20:48:55,677 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2014-01-04 20:48:56,007 DEBUG [ServiioConsole] Retrieving console settings
2014-01-04 20:48:56,115 DEBUG [ServiioConsole] Setting console locale to be: en
2014-01-04 20:48:56,122 INFO  [Messages] Loaded console message bundle for locale: en
2014-01-04 20:48:56,122 DEBUG [ServiioConsole] Reading application data
2014-01-04 20:48:56,876 DEBUG [ServiioFrameView] Initializing main frame
2014-01-04 20:48:56,899 DEBUG [ServiioFrameView] System tray is supported
2014-01-04 20:48:57,110 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups
2014-01-04 20:48:57,614 DEBUG [RepositoryDAOImpl] Reading all Repositories
2014-01-04 20:48:57,633 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups for Repository (id = 1)
2014-01-04 20:48:57,697 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-01-04 20:48:58,224 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2014-01-04 20:48:58,423 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups
2014-01-04 20:48:59,648 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net3 (D-Link DWA-140 RangeBooster N USB Adapter(rev.B2)) and address 192.168.1.6, timeout = 0
2014-01-04 20:48:59,648 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 223a9375-eb61-3269-abcf-3ad9f2e63b1f
2014-01-04 20:48:59,742 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2014-01-04 20:48:59,820 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2014-01-04 20:49:00,413 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2014-01-04 20:49:00,428 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=0, titleKey=pc5dczc_media_library, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = null
2014-01-04 20:49:00,460 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A, titleKey=audio, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2014-01-04 20:49:00,491 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_ALB, titleKey=albums, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-01-04 20:49:00,491 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllAlbumsCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2014-01-04 20:49:00,522 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2014-01-04 20:49:00,538 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_A, titleKey=artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-01-04 20:49:00,538 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2014-01-04 20:49:00,553 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2014-01-04 20:49:00,569 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2014-01-04 20:49:00,584 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2014-01-04 20:49:00,600 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=AL_A, titleKey=album_artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-01-04 20:49:00,616 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListAlbumArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2014-01-04 20:49:00,631 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListAlbumArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2014-01-04 20:49:00,647 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForAlbumArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2014-01-04 20:49:00,662 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2014-01-04 20:49:00,662 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-01-04 20:49:00,694 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=local_default
2014-01-04 20:49:00,694 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-01-04 20:49:00,725 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioGenresByNameCommand, containerClass=MUSIC_GENRE, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2014-01-04 20:49:00,740 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForGenreCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2014-01-04 20:49:00,818 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_C, titleKey=composers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-01-04 20:49:00,834 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListComposerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2014-01-04 20:49:00,850 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListComposersForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=COM, recursive=false, cacheRegion=local_default
2014-01-04 20:49:00,881 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForComposerCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2014-01-04 20:49:00,896 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForComposerAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2014-01-04 20:49:00,912 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-01-04 20:49:00,928 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2014-01-04 20:49:00,928 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForInitialCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2014-01-04 20:49:00,943 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_R, titleKey=random_music, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2014-01-04 20:49:00,959 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListRandomSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=no_cache
2014-01-04 20:49:00,974 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_RA, titleKey=random_albums, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2014-01-04 20:49:00,974 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListRandomAlbumsCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=no_cache
2014-01-04 20:49:00,990 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=no_cache
2014-01-04 20:49:01,006 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_LVA, titleKey=last_listened_albums, class=CONTAINER, cacheRegion=local_resetafterplay, browsable = null, editable = true
2014-01-04 20:49:01,021 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListLastViewedAlbumsCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_resetafterplay
2014-01-04 20:49:01,021 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_resetafterplay
2014-01-04 20:49:01,037 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-01-04 20:49:01,052 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioPlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,052 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForPlaylistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,068 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2014-01-04 20:49:01,084 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2014-01-04 20:49:01,084 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_S, titleKey=All songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2014-01-04 20:49:01,099 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,115 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_AS, titleKey=Artist Songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2014-01-04 20:49:01,130 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsByNameCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART_S, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,130 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,146 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_AA, titleKey=Artist Albums, class=CONTAINER, cacheRegion=no_cache, browsable = false, editable = null
2014-01-04 20:49:01,162 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForArtistNameCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=no_cache
2014-01-04 20:49:01,177 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=no_cache
2014-01-04 20:49:01,177 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I, titleKey=image, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2014-01-04 20:49:01,193 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_A, titleKey=albums, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-01-04 20:49:01,208 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListFlatImageFoldersByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,208 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForFolderCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,224 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-01-04 20:49:01,240 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=local_default
2014-01-04 20:49:01,240 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_Y, titleKey=year, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-01-04 20:49:01,255 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,271 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,286 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_T, titleKey=month, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-01-04 20:49:01,286 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,302 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationMonthsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=MON, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,318 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationMonthAndYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,333 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-01-04 20:49:01,333 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagePlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,349 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForPlaylistCommand, containerClass=null, itemClass=PHOTO, idPrefix=S, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,364 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2014-01-04 20:49:01,364 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2014-01-04 20:49:01,380 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_AI, titleKey=All images, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2014-01-04 20:49:01,396 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListAllImagesCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,396 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V, titleKey=video, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2014-01-04 20:49:01,411 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-01-04 20:49:01,427 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,442 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForInitialCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,458 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_M, titleKey=movies, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-01-04 20:49:01,458 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListMovieVideosByNameCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,474 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_S, titleKey=series, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-01-04 20:49:01,489 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeriesByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SER, recursive=false, cacheRegion=local_resetafterplay
2014-01-04 20:49:01,505 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeasonsForSeriesCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SSN, recursive=false, cacheRegion=local_resetafterplay
2014-01-04 20:49:01,520 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListEpisodesForSeriesSeasonCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2014-01-04 20:49:01,520 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-01-04 20:49:01,536 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=local_default
2014-01-04 20:49:01,552 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LV, titleKey=last_viewed, class=CONTAINER, cacheRegion=local_resetafterplay, browsable = null, editable = true
2014-01-04 20:49:01,567 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastViewedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2014-01-04 20:49:01,567 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LA, titleKey=last_added, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-01-04 20:49:01,583 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastAddedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,598 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-01-04 20:49:01,614 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:07 (advertisement duration is 1800 sec.)
2014-01-04 20:49:01,614 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoGenresByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,614 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForGenreCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,630 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_R, titleKey=ratings, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-01-04 20:49:01,647 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoRatingsByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=RAT, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,658 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListMovieVideosForRatingCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,669 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_A, titleKey=actors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-01-04 20:49:01,679 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,691 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,704 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForActorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,713 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_D, titleKey=directors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-01-04 20:49:01,725 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,736 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,749 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForDirectorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,760 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_P, titleKey=producers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-01-04 20:49:01,773 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,783 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducersForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,795 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForProducerCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,805 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_RY, titleKey=release_years, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-01-04 20:49:01,818 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoReleaseYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=Y, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,830 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListMovieVideosForReleaseYearCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,840 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-01-04 20:49:01,852 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoPlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,864 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForPlaylistCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2014-01-04 20:49:01,875 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2014-01-04 20:49:01,886 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2014-01-04 20:49:01,902 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2014-01-04 20:49:03,402 DEBUG [RepositoryDAOImpl] Reading all Repositories
2014-01-04 20:49:03,404 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups for Repository (id = 1)
2014-01-04 20:49:03,405 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-01-04 20:49:03,438 DEBUG [ServiioConsole] Reading application data
2014-01-04 20:49:03,438 DEBUG [RepositoryView$LibraryStatusCheckerThread] Starting library status checking thread
2014-01-04 20:49:09,650 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net3 (D-Link DWA-140 RangeBooster N USB Adapter(rev.B2)) and address 192.168.1.6, timeout = 0
2014-01-04 20:49:09,650 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 223a9375-eb61-3269-abcf-3ad9f2e63b1f
2014-01-04 20:49:11,615 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:04:05 (advertisement duration is 1800 sec.)
2014-01-04 20:49:15,694 INFO  [FeedUpdaterThread] Started looking for information about online resources
2014-01-04 20:49:15,694 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2014-01-04 20:49:15,694 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-01-04 20:49:15,707 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2014-01-04 20:49:15,707 DEBUG [RepositoryDAOImpl] Reading all Repositories
2014-01-04 20:49:15,708 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2014-01-04 20:49:15,708 DEBUG [RepositoryDAOImpl] Reading all Repositories
2014-01-04 20:49:16,221 DEBUG [RepositoryDAOImpl] Marking Repository 1 as scanned with current timestamp
2014-01-04 20:49:16,366 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1) and extractor COVER_IMAGE_IN_FOLDER
2014-01-04 20:49:16,368 DEBUG [MediaItemDAOImpl] Getting file of media item 2
2014-01-04 20:49:16,369 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 2) and extractor EMBEDDED
2014-01-04 20:49:16,370 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 2) and extractor COVER_IMAGE_IN_FOLDER
2014-01-04 20:49:16,372 DEBUG [MediaItemDAOImpl] Getting file of media item 3
2014-01-04 20:49:16,373 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3) and extractor EMBEDDED
2014-01-04 20:49:16,374 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3) and extractor COVER_IMAGE_IN_FOLDER
2014-01-04 20:49:16,375 DEBUG [MediaItemDAOImpl] Getting file of media item 4
2014-01-04 20:49:16,376 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 4) and extractor EMBEDDED
2014-01-04 20:49:16,377 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 4) and extractor COVER_IMAGE_IN_FOLDER
2014-01-04 20:49:16,379 DEBUG [MediaItemDAOImpl] Getting file of media item 5
2014-01-04 20:49:16,380 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 5) and extractor EMBEDDED
2014-01-04 20:49:16,381 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 5) and extractor COVER_IMAGE_IN_FOLDER
2014-01-04 20:49:16,382 DEBUG [MediaItemDAOImpl] Getting file of media item 6
2014-01-04 20:49:16,383 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 6) and extractor EMBEDDED
2014-01-04 20:49:16,384 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 6) and extractor COVER_IMAGE_IN_FOLDER
2014-01-04 20:49:16,386 DEBUG [MediaItemDAOImpl] Getting file of media item 7
2014-01-04 20:49:16,388 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7) and extractor EMBEDDED
2014-01-04 20:49:16,389 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7) and extractor COVER_IMAGE_IN_FOLDER
2014-01-04 20:49:16,390 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 1)
2014-01-04 20:49:16,411 DEBUG [RepositoryDAOImpl] Marking Repository 1 as scanned with current timestamp
2014-01-04 20:50:15,695 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2014-01-04 20:50:15,695 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-01-04 20:50:56,047 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANPPPConnection:1 from address /192.168.1.6:50113s
2014-01-04 20:50:56,051 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.1.6:50113s
Iveky wrote:check windows firewall ports...
Yes, I have followed the guide/instructions on FAQ to open certain ports through the firewall. Thank you for your tip!
bolzass wrote:Hi!,
Hello friend! Yes I have checked IP. Im not getting a new one after each reboot, i checked with my router. And my firewall is open for the needed ports. Thanks for the thoughts!
So, on my thoughts. Since Serviio runs completly perfect only after a new installation, doesnt it rule out that its the firewall/router/ip fault?(if its not dynamic). Since the problem only exists when I have rebooted my computer. Can someone link/post me an 1.3.1 version or any older, so I can try a previous version?
Other than this issue, Serviio is running fine with subs etc.
When I started the computer earlier I noticed this
2014-01-04 19:34:59,221 WARN  [MultiCastUtils] Host IP address 192.168.1.6 is not available, will try again 9 times
2014-01-04 19:35:04,181 INFO  [RendererExpirationChecker] Leaving RendererExpirationChecker
2014-01-04 19:35:04,259 WARN  [MultiCastUtils] Host IP address 192.168.1.6 is not available, will try again 8 times
I don't think ive gotten this kind of message later on. I am not sure however. But if Ive gotten it now, then it should be displayed in the .log I posted above. Thank you guys for taking your time. Any suggestions are welcome!
Post Sun Jan 05, 2014 4:37 am
Hi boben88
Can you please turn on detailed logging (click on the link for details) and restart Serviio. Try to open the Serviio server from your TV - if it works, reboot your PC and try again until it fails. Attached your log file (it may be large) to your post so that we can review it.
Ideally we'd like to capture a detailed log of it working, and then not working (you may even need to re-install Serviio to get it working - turn on detailed logging before starting Serviio after installation). When responding let us know what the status was at each reboot.
boben88
Post Sun Jan 05, 2014 10:24 am
DenyAll wrote:Hi boben88
Oh, I thought I turned on detailed log, I guess I did something wrong. I apologize!
I will supply you with this information, in 2 days time tho. I am working on thesis atm, so when im done with it in 2 days time then ill have time to reboot and mix n trix with Serviio. Thanks for your tip!
Users browsing this forum: No registered users and 49 guests
