Roku Profile Needed - Now Supports DLNA
npuser
Post Tue Dec 31, 2013 5:50 pm
I am not sure if Roku adheres to all DLNA specs at all but it appears Roku Media Player App from Roku apps store seems to find network DLNA server and play medias well. It found my serviio then I used default Chaneru profile for the Roku which seems to play most of the file but online contents are different story.
i am calling on all device profile pros to help us out with online portion of the profile. Is it even possible?
thanks
NPuser
Roku App:
http://www.roku.com/channels/#!details/ ... dia-player
Live and VOD
http://sdkdocs.roku.com/display/sdkdoc/ ... LiveandVOD
Supported format:
http://sdkdocs.roku.com/display/sdkdoc/ ... deoFormats
Marksuk
Post Tue Dec 31, 2013 6:33 pm
Re: Roku Profile Needed - Now Supports DLNA
A Roku profile or even a Serviio application for a Roku player would be excellent.
I noticed this DLNA support recently too and it plays mkv, mp4, jpg and mp3.
Unfortunately online sources and avi files are not recognised.
npuser
Post Tue Dec 31, 2013 9:12 pm
Put beta profile together based upon Plex Roku DLNA profile and Chaneru profile. I am not sure if this even works as i have not yet tested with Roku Media Player App. If anyone willing to give it a test drive - have at it.
NPuser
<Profile id="RokuPM" name="Roku Media Player" extendsProfileId="1">
      <Detection>
         <HttpHeaders>
            <User-Agent>Roku/DVP-3.</User-Agent>
         </HttpHeaders>
      </Detection>
      <MediaFormatProfiles>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_HD_720p_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_HD_1080i_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_HP_HD_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_LPCM</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_ASP_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_SP_L6_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_NDSD</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/mpeg">MP3</MediaFormatProfile>
      </MediaFormatProfiles>
      <Video targetContainer="applehttp" targetVCodec="h264" targetACodec="aac">
         <Matches container="asf" />
         <Matches container="mpegvideo" />
         <Matches container="mpeg" />
         <Matches container="mpegts" />
         <Matches container="avi" />
         <Matches container="flv" />
         <Matches container="wtv" />
         <Matches container="ogg" />
         <Matches container="3gp" />
         <Matches container="rtp" />
         <Matches container="rtsp" />
         <Matches container="rm" />
      <Audio targetContainer="mp3">
         <Matches container="*" />
         </Audio>
      <OnlineTranscoding>
         <Video targetContainer="mpegts" targetACodec="aac" maxVBitrate="8000" DAR="16:9" aBitrate="384">
            <Matches container="*"/>
         </Audio>
      </OnlineTranscoding>
Post Wed Jan 01, 2014 12:07 am
Thanks for pointing out the new Roku channel. I can't get it to work. It shows all my DLNA devices (two machines running Serviio, a Windows Home Server and several Windows 7/8 PCs), but when I try to select one I get a Server Connection Error saying it can't connect. Doesn't matter which DLNA device I try, or if it's video or audio. I'll be posting on the Roku forum to check for any ideas there, and if anyone here has any suggestions I'd appreciate it. I know there's no connectivity issues, since the Roku connects fine to Netflix, Amazon, as well as my server running Plex or using the Chaneru channel. Something odd...
Post Wed Jan 01, 2014 3:13 am
atc98092 wrote:Thanks for pointing out the new Roku channel. I can't get it to work. It shows all my DLNA devices (two machines running Serviio, a Windows Home Server and several Windows 7/8 PCs), but when I try to select one I get a Server Connection Error saying it can't connect. Doesn't matter which DLNA device I try, or if it's video or audio. I'll be posting on the Roku forum to check for any ideas there, and if anyone here has any suggestions I'd appreciate it. I know there's no connectivity issues, since the Roku connects fine to Netflix, Amazon, as well as my server running Plex or using the Chaneru channel. Something odd...
OK, resolved the Roku connectivity issue. If anyone is interested, the Roku has some "secret" menus, and one of them allows disabling Ping replies. That cured the issue, and also resolving the Roku not believing it was connected to a network (even though it was and everything worked). :lol:
Now, I can see my Serviio machines, but the only videos visible are my few MP4 files. Virtually all my videos are in MKV containers. I've tried both the Chaneru profile and the one npuser posted above. No luck with either. I'll have to play around with the profile some more. :(
I will say the Roku Media Player seems to handle high bit rate videos quite well. I have a couple of HD MP4 files, and they seemed to play perfectly. Using MediaInfo, I see they have an average bit rate over 16Mbps, and I didn't think a Roku could handle that fat a stream.
npuser
Post Wed Jan 01, 2014 6:44 pm
looks like there are two verions of ROku devices -v3.x and v5.x. A minor mod for v5 but i am still not sure this even works.
NPuser
<Profile id="RokuMPApp" name="Roku Media Player" extendsProfileId="1">
      <Detection>
         <HttpHeaders>
            <User-Agent>Roku/DVP-5.</User-Agent>
         </HttpHeaders>
      </Detection>
      <Video targetContainer="mpegts" targetVCodec="h264" targetACodec="aac">
         </Audio>
      <OnlineTranscoding>
         <Video targetContainer="mpegts" targetVCodec="h264" targetACodec="aac" maxVBitrate="8000" DAR="16:9" aBitrate="384">
         </Audio>
Post Wed Jan 01, 2014 9:28 pm
npuser wrote:looks like there are two verions of ROku devices -v3.x and v5.x. A minor mod for v5 but i am still not sure this even works.
NPuser
      <Detection>
         <HttpHeaders>
         </HttpHeaders>
      </Detection>
         </Audio>
      <OnlineTranscoding>
         </Audio>
I tried making the user agent a wild card (*.Roku.*), but still can't see any of my MKV files. Only the MP4 videos and MP3 music files.
Marksuk
Post Thu Jan 02, 2014 7:54 am
Changing the profile to Generic DLNA (Roku is 192.168.0.16) makes mkv files playable on the ROKU.
Post Thu Jan 02, 2014 8:58 am
Could you provide format supported by your roku device ? (see signature link about Intel Upnp spy tool...)
It seems that your device does not support MPEGTS container, only MP4 or HLS, but serviio does not support this MP4 container for output transcoding...
Marksuk
Post Thu Jan 02, 2014 9:39 am
As far as I know Roku only supports mp4 and mkv video files.
On how to find out additional information about this then I just dont know.
It only serves the purpose of a client and is not a server.
Marksuk
Post Thu Jan 02, 2014 9:57 am
This is excellent.
I just changed the profile to Windows 8/RT and it now plays the online streaming, mp4 and mkv, I will keep trying different profiles.
Post Thu Jan 02, 2014 9:59 am
Marksuk wrote:On how to find out additional information about this then I just dont know.
Please look at my signature links (intel spy tool) to find format supported by your device ?
Marksuk
Post Thu Jan 02, 2014 10:45 am
The only device I can find on the network apart from the router is this Panasonic HDD recorder
Post Thu Jan 02, 2014 11:16 am
Could you list files/stream format that play with "Generic DLNA profile" and files/stream that play with "Windows 8/RT" profile ?
What about this :
   <Detection>
      <HttpHeaders>
      </HttpHeaders>
   </Detection>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AAC_MULT5</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AAC_MULT5_T</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AAC_MULT5_ISO</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_MPEG1_L3</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_MPEG1_L3_T</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_MPEG1_L3_ISO</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AC3</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HP_SD_MPEG1_L2_T</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HP_SD_MPEG1_L2_ISO</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AAC_MULT5</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AAC_MULT5_T</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AAC_MULT5_ISO</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_MPEG1_L3</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_MPEG1_L3_T</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_MPEG1_L3_ISO</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AC3</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HD_DTS_T</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HD_DTS_ISO</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HD_50_LPCM_T</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HP_HD_MPEG1_L2_ISO</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HP_HD_MPEG1_L2_T</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AAC</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AAC_T</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AAC_ISO</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AC3</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AC3_T</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AC3_ISO</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG1_L3</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG1_L3_T</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG1_L3_ISO</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG2_L2</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG2_L2_T</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG2_L2_ISO</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">VC1_TS_AP_L1_AC3_ISO</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">VC1_TS_AP_L2_AC3_ISO</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">VC1_TS_HD_DTS_T</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">VC1_TS_HD_DTS_ISO</MediaFormatProfile>
   <OnlineTranscoding>
         <Matches container="mp4" />
         <!--Matches container="applehttp" vCodec="h264" /-->
Marksuk
Post Thu Jan 02, 2014 11:30 am
Sorry I cant be more specific but in the Generic DLNA it plays mp4, mp3, mkv and jpeg
In Windows8/RT it supports all the above file types and it appears to be the only profile which suports online streaming. Mkv files seem to stream better in this profile too.
Avi files do not play in either profile. Avi is not naturally supported by Roku. In either profile then connection to Serviio is lost quite easily.
Marksuk
Post Thu Jan 02, 2014 12:31 pm
Post Thu Jan 02, 2014 1:28 pm
I also used the spy tool, but the Roku doesn't appear. For some reason the box doesn't respond like a normal DLNA player. Didn't make a difference if the Media Player was running or not. I even started the Chaneru player, but still nothing.
For the record, Roku does not support MKV files natively. Here is what is supported: http://sdkdocs.roku.com/display/sdkdoc/Encoding+Guide#EncodingGuide-25SupportedVideoFormats
Post Thu Jan 02, 2014 5:08 pm
atc98092 wrote:...
I don't unsderstand, Marksuk said that mkv files play on his Roku (with generic profile and W8RT) ...
Marksuk
Post Thu Jan 02, 2014 7:24 pm
Marksuk
Post Thu Jan 02, 2014 7:26 pm
I stand corrected, I just tried mkv files again and they do not play correctly at all, apologies, just mp4 video and online files are ok with profile Windows8/RT. :) Other profiles do not show online videos.
