Viera TX-P50v20e mkv mp4 issue
sebag73
Post Sat Dec 28, 2013 11:36 am
hello
Dear Panasonic and Serviio users.
I have Serviio 1.4 installed on Ubuntu 12.04, i use it for music and movies.
As TV i have got Viera TX-P50v20e (2010) with sw. rev. 2518-10300.
It works ok with avi but i am not able to play .mkv or .mp4 movie files.
I try to play my gopro .mp4 files but it fails too.
Please let me know if any of You had and solved that issue?
Any suggestions?
thanx in advance Seba
Post Sat Jan 04, 2014 11:45 am
Re: Viera TX-P50v20e mkv mp4 issue
Are you using the Panasonic 2010 profile? If so, make sure you have transcoding enabled - this should then play your MP4 and MKV files.
sebag73
Post Thu Jan 16, 2014 2:37 pm
hello Guys
I don't belive that no one use serviio and Panasonic Viera 2010????
This is my profile:
<Profile id="viera2010" name="Panasonic Viera (2010)" extendsProfileId="viera2011a">
<!-- Panasonic Viera VT20, V20, G20, D25, D28 (2010) -->
<!-- detection removed as it was interfering with detection of the 2011/2012 Viera profiles
<Detection>
<HttpHeaders>
<User-Agent>.*Panasonic.*</User-Agent>
</HttpHeaders>
</Detection> -->
<!-- unsupported codecs will be transcoded into mpeg-ts, mpeg2 video and ac3 audio -->
<Audio targetContainer="mp3">
<Matches container="flac" />
<Matches container="ogg" />
<Matches container="asf" />
<Matches container="adts" />
</Audio>
and with that profile it doesn't play: *.mp4, *.rmvb files.
Any ideas?
I try to modify that profile and add next line:
<Video targetContainer="asf" targetVCodec="wmv2" targetACodec="wmav2" maxVBitrate="15360">
<Matches container="mpeg" />
<Matches container="mpegvideo" />
<Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3">
<Matches container="mpegts" aCodec="aac"/>
but it was even worst....
thx. Seba
Post Thu Jan 16, 2014 11:37 pm
I do. I have a TX-P55V20A. The Panasonic 2010 profile works fine for me (I have made some mods to it, but the stock profile does the job).
MP4 files are already transcoded by this profile (the transcoding commands are in the "Panasonic Viera G/GT/DT/UT/VT (2011/2012)" profile, which the 2010 profile inherits). My MP4 files work fine. I don't have any .rmvb files, so haven't tested them (but they should be transcoded by the inherited 2011/12 profile.
Can you post MediaInfo details for those files that are not working.
Will never work. The Panasonic V20 cannot play asf files natively so you cannot transcode to that format. What is it that you are trying to do here...?
sebag73
Post Fri Jan 17, 2014 2:04 pm
mediainfo for my mp4:
Complete name : D:\Video\sony_livigno\s_2.mp4
Format : MPEG-4
Format profile : Sony PSP
Codec ID : MSNV
File size : 28.9 MiB
Duration : 15s 15ms
Overall bit rate : 16.2 Mbps
Encoded date : UTC 2013-12-23 10:52:22
Tagged date : UTC 2014-01-11 15:04:01
Format : AVC
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 15s 15ms
Bit rate mode : Variable
Bit rate : 16.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.257
Stream size : 28.7 MiB (99%)
Language : English
Tagged date : UTC 2013-12-23 10:52:22
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 15s 6ms
Source duration : 14s 997ms
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 234 KiB (1%)
Source stream size : 234 KiB (1%)
Language : English
Post Fri Jan 17, 2014 11:39 pm
This should be transcoding?? Is it only this MP4 that doesn't transcode or is it all. You haven't actually stated what the problem is - does it not play at all, or plays erratically?
sebag73
Post Sat Feb 01, 2014 6:27 pm
hello
it doesn't play at all.
Message like "unsupported file"
rgrds seba
Post Sun Feb 02, 2014 12:17 am
I wonder if the Panasonic is having a hard time with the bit rate of this file (16Mbps)?? Try adding this to your 2010 profile as a test (remember to restart your PC after changing profiles.xml):
<Video targetContainer="mpegts" targetVCodec="mpeg2video" DAR="16:9"  maxVBitrate="10000" targetACodec="ac3" aBitrate="384">
Return to Panasonic
