Cue Sheet support??
n3mmr
Post Sat Jan 04, 2014 3:04 pm
Cue Sheet support??
Would it be possible to make Serviio support Cue Sheet+Single Flac (or WAV) file??
Post Sun Jan 05, 2014 9:47 am
Re: Cue Sheet support??
Seems like a big task, will see.
n3mmr
Post Sun Jan 05, 2014 3:50 pm
zip wrote:Seems like a big task, will see.
If the support for this is not too special-cased, it might open up for having several Cuesheet entries cover different parts of the same interval;
Like having one entry for the entire symphony and then separate entries for each movement. This would then allow gapless playback of entire symphonies, i e w/o breaks at the movement boundaries, even if the renderer used is no good at gapless playback in itself.
Return to Feature requests
