dmr.xml editing
NX3
Post Sat Jan 04, 2014 9:18 pm
dmr.xml editing
Does anyone know how to edit the details in the dmr.xml file ? I can change the friendlyName via the tv menu but my model number is wrong, it just says dmr (see below). While Serviio is smart enough to work out this is a Sony 2011 series not all software is that smart but I can't see how to edit the model name.
http://192.168.1.222:52323/dmr.xml
<device><deviceType>urn:schemas-upnp-org:device:MediaRenderer:1</deviceType><friendlyName>BRAVIA KDL-37EX723</friendlyName><manufacturer>Sony Corporation</manufacturer><manufacturerURL>http://www.sony.net/</manufacturerURL><modelName>DMR</modelName><UDN>uuid:00000000-0000-1010-8000-30F9ED4C7949</UDN><dlna:X_DLNADOC>DMR-1.50</dlna:X_DLNADOC>
Post Sun Jan 05, 2014 8:28 am
Re: dmr.xml editing
Not sure you can.
Only friendly name could by changed through Sony menu settings.
NX3
Post Sun Jan 05, 2014 12:42 pm
Re: dmr.xml editing
After much googling I can't find away to change it. My panel was replaced on my set under warranty so think thats how it got the wrong name. I changed the friendly name at least......serviio works perfectly with it :)
Users browsing this forum: Google [Bot] and 53 guests
