[SOLVED] Cannot get Homestream 2.0 work with my Sony Bravia
olf
Post Sun Jan 05, 2014 4:27 pm
I have recently bought a Sony Bravia KDL-32W653A. And when I first installed the TV and HomeStream 2.0 everything worked like a charm!
A couple of days later (nothing had changed configuration-wise) my TV could no longer "see" my HomeStream server. I then made a factory reset on the tv, but still the TV couldn't see the server (The server could see the TV though - showing a green dot when it was on and a red one, when it was off).
I then tried to uninstall HomeStream and reinstalling it. Now HomeStream can no longer see the TV!
My TV has the newest firmware available: PKG4.001EUA
Windows 8.1 - all patches installed
Java: Version 7 update 45 (newest available)
The TV is connected via WIFI and it can connect to the internet via my Technicolor router.
Any hints on what to do?
/Ole
NX3
Post Sun Jan 05, 2014 6:39 pm
Re: Cannot get Homestream 2.0 work with my Sony Bravia
What firewall do you have?
Sent from my HTC One mini using Tapatalk
olf
Post Mon Jan 06, 2014 3:57 pm
Ah, forgot to mention firewall.
Windows build-in. And all TCP and UDP ports are open (and rules are active!)
olf
Post Wed Jan 08, 2014 8:32 pm
Problem solved!
And I am very sorry for having posted above question! On the other hand, the solution might be one others can use as well...
All I had to do, was turn off my router, wait a minute and turn it on again!
Feel embarrassed that I didn't try that before posting here! :oops:
Thanks to all who read and commented.
