Cant get anything to work :O
flaske83
Post Sun Jan 05, 2014 9:41 pm
so here's my setup:
Both TV and PC (Windows 7 64-bit) are connected to the same Wifi-network wireless.
TV: Sony Bravia Kdl-55w805
I altered the profiles.xml after reading the (Sony Bravia 2013 Read-me).
The server is started, and under "Rendering profiles", i can one unknown device, and i selected the new profile (Sony Bravia TV) (2013).
Tried updating several times.
Im not even sure this is the right IP address for the TV, or if the device even is the TV since it says unknown device.
Even so, where do i go from here to find Servioo on my Sony Bravia?
The Youtube tutorial was no help at all, as it is 5 years old and tells me to click on Xcrossmedia bar (im assuming this is the home button?)
Is Servioo not for Norwegian users by chance, as many other things?
If not, i need some help explaining this.
Post Mon Jan 06, 2014 7:54 am
Re: Cant get anything to work :O
- Update your serviio to 1.4 version (profiles.xml contains 2013 profile)
- On Sony Bravia network menu, clean the server list and refresh it.
- On serviio Console device list, clean the list and refresh it.
If that does not work, enable detailed logging and post your log here.
flaske83
Post Mon Jan 06, 2014 10:54 am
Hi, i had the 1.40 version already, i updated the server list on the Sony Bravia network menu i think, and now i can find the Sony Bravia through Servioo.
How do i access the folders i have shared from my Sony Bravia TV? Cant figure this part out
Post Mon Jan 06, 2014 12:42 pm
Serviio side:
On serviio console, you have to add shared folder, and you have to check the type of media you want to add to the library (video/audio/photo).
Wait some minute to library build...
Sony side:
Press [Home] button, then select the video section for video clips, audio section for audio clip...
flaske83
Post Mon Jan 06, 2014 1:30 pm
I've got the Sergioo side covered, however when i click "Home" on the TV all i get are the following options:
Log
TV
Programs
Connected units
Settings
There is no Video, or Audio.
Post Mon Jan 06, 2014 5:32 pm
Oups, sorry, I have a 2010 model and sony change the menu organization since 2013 model, so I could not help you here...someone else for help ?
