Serviio 1.4 not ready for prime time
rgsurplus
Post Thu Jan 02, 2014 4:35 pm
I upgraded to 1.4 the other day
well first the server would not run---- after 2 hrs I got it to work (windows 7 64bit)
loaded my movies that where accessible from 1.3 do not show on the dlna player or in firefox
the movies that do show do not play at all on firefox 22---- floplayer does not load
then wow I lost the license file
I hope I can downgrade back to 1.3 and I hope the sales dept. will answer my emails to resend me my lic. file
nothing at all shows up in EI
Regards
A fan of Serviio
Post Thu Jan 02, 2014 5:52 pm
Re: Serviio 1.4 not ready for prime time
There is a known issue with firefox..use chrome or IE...or downgrade to the old Mediabrowser as posted elsewhere. Otherwise 1.4 works fine.
rgsurplus
Post Fri Jan 03, 2014 2:55 am
jhb50 wrote:There is a known issue with firefox..use chrome or IE...or downgrade to the old Mediabrowser as posted elsewhere. Otherwise 1.4 works fine.
not from where I sit
I will repeat my statements again less the firefox issue
some folders that have movies in them that worked with 1.3.1 don't even show up in 1.4
movies don't play on internet explorer ,should not release,, not work with firefox
no insult just fact
I have disabled firewall as test still no go and sometimes after restart server does not restart have to reboot then restart
and no answer as to why my pro license is gone???
I did say I was going back to 1.3.1
serviio from the start has been the best media server for me then any other and I have tried a lot of them
happy new year eha
Post Fri Jan 03, 2014 4:48 am
Sounds like you are using a different profile with 1.4, and that you did a cold install of 1.4 rather than overwrite 1.3 which would have preserved your 1.3 settings and licence.
Post Fri Jan 03, 2014 11:10 am
You should have your license file in your mailbox now.
rgsurplus
Post Sat Jan 04, 2014 4:49 pm
TY downgraded to 1.3.1 and now all folders are showing and all media plays as before
and now shows licensed edition
can't wait for a good 1.4
been hoping for search capability
Post Sat Jan 04, 2014 5:00 pm
As I said, 1.4 works fine. I've been using it for over a month including all the beta's with Chrome, so if you have problems, look to the way you installed it.
jdomi
Post Sun Jan 05, 2014 2:16 am
I believe the OP is correct in saying version 1.4 is not ready for prime time.
I have been happily using Serviio for some time now without a glitch... until I upgraded from 1.3.1 to 1.4. The service wouldn't start; I uninstalled it and reinstalled it a couple of times with the same results. I then downgraded to 1.3.1 hoping I would get back to normal but the service wouldn't start either. Unfortunately, I could not make it to generate a log on either version. So now, I uninstalled Serviio and hope to wait for a good new version and start all over again while I watch my movies on a DLNA DVD player.
If someone wants to help I am willing to try.
Best regards.
Post Sun Jan 05, 2014 3:53 am
It should be obvious that if 1.3.1 won't start that your problem does not lie with 1.4
Post Sun Jan 05, 2014 7:11 am
@jdomi. Try re-installing Java (ensuring latest version) prior to re-installing Serviio 1.4.
jdomi
Post Sun Jan 05, 2014 7:39 pm
@jhb50: You have quite a few posts and seem to be experienced on this for you to say something like that. Any program can screw up the program's environment (registry and the likes) in such a way that no other version of the program would work until it's all cleaned up. Thank you anyway for taking the time.
@DennyAll: Thank you very much, I reinstalled Java using the most recent version (7.45), reinstalled 1.4 and it now works. At the end, jhb50 was right, but not because of what he said, got it?
Post Mon Jan 06, 2014 12:36 am
Resolved: Serviio 1.4 is more than ready for prime time
As above
ron90010
Post Tue Jan 07, 2014 12:02 am
I had this problem on my windows 7 setup. Here is how I fixed it:
downloaded java 7.45 for windows (32 bit and 64 bit versions - two separate files)
http://www.java.com/en/download/manual.jsp
reinstalled Java 7.45 (32 bit version)
reinstalled Java 7.45 (64 bit version)
reinstalled serviio 1.4
reboot
reconfig library
everything now works
Users browsing this forum: No registered users and 52 guests
