Question with Sony profile
Post Sun Jan 05, 2014 11:16 pm
I have two BDP-S3100 players, using the BDP-Sx90 (2012) profile. I use this one because it appears to pass my MKV files natively. However, I just discovered at least a few MKV files that are still being transcoded, and playback is unwatchable due to FFMPEG not being able to keep up with the video stream. Looking at profiles.xml, it appears that there is something that is still catching some MKV files with multiple audio tracks. Here's MediaInfo information on a file that is still being transcoded:
Unique ID                                : 333831892877393773954366734157700241021 (0xFB25AF134F7B4C6548AAC9ACF181967D)
Complete name                            : F:\The Hunt for Red October (1990).mkv
File size                                : 35.0 GiB
Duration                                 : 2h 15mn
Overall bit rate                         : 37.1 Mbps
Movie name                               : The Hunt For Red October
Encoded date                             : UTC 2014-01-05 03:38:50
Writing application                      : MakeMKV v1.8.7 win(x64-release)
Writing library                          : libmakemkv v1.8.7 (1.3.0/1.4.1) win(x64-release)
Format settings, ReFrames                : 2 frames
Duration                                 : 2h 15mn
Height                                   : 1 080 pixels
Audio #1
Format                                   : TrueHD
Codec ID                                 : A_TRUEHD
Duration                                 : 2h 15mn
Maximum bit rate                         : 5 148 Kbps
Bit depth                                : 24 bits
Compression mode                         : Lossless
Title                                    : 5.1
Audio #2
Duration                                 : 2h 15mn
Bit rate                                 : 640 Kbps
Stream size                              : 619 MiB (2%)
Title                                    : 3/2+1
Text #1
Format                                   : PGS
Codec ID                                 : S_HDMV/PGS
Codec ID/Info                            : The same subtitle format used on BDs/HD-DVDs
Text #2
Format                                   : PGS
Menu
00:00:00.000                             : en:Chapter 01
00:13:12.958                             : en:Chapter 02
00:19:35.757                             : en:Chapter 03
00:33:26.504                             : en:Chapter 04
00:43:06.417                             : en:Chapter 05
00:51:46.770                             : en:Chapter 06
01:05:25.546                             : en:Chapter 07
01:11:14.979                             : en:Chapter 08
01:25:03.807                             : en:Chapter 09
01:36:51.680                             : en:Chapter 10
01:47:51.756                             : en:Chapter 11
01:55:18.745                             : en:Chapter 12
02:07:59.421                             : en:Chapter 13
I have other MKV files with the same level of encoding and bit rate, and the player does fine playing without transcoding. What should I comment out of the profile file to send all MKV files without transcoding? I think it is this section:
<Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="320" forceInheritance="true">
The next section also talks about unsupported audio, such as TrueHD. However, this Sony player will accept both TrueHD and DTS Master Audio as a bitstream, so I don't want the audio changed either. I've seen my receiver indicate it is receiving both HD audio formats, so I want them sent intact.
Any suggestions?
Post Mon Jan 06, 2014 1:31 am
Re: Question with Sony profile
That section of code shouldn't be impacting as your file is a level High@L4.1, so won't match the: profile="high" levelGreaterThan="4.1"
If you are sure your player supports TrueHD then remove (or comment out) the line:
    <Matches container="matroska" aCodec="truehd" />
This is causing your file to be remuxed, and the audio transcoded to AC3. Once removed the file will be presented natively (as-is) to the player... as long as the player supports this audio all should be fine.
ps. even delivered natively, this file has a 37Mbps bit rate which is pretty high - your network needs to be fast (and your players need to handle it).
Post Mon Jan 06, 2014 1:16 pm
DenyAll wrote:That section of code shouldn't be impacting as your file is a level High@L4.1, so won't match the: profile="high" levelGreaterThan="4.1"
Yep. Wired gigabit, so no connection issues. Of course, the Sony doesn't have a gigabit LAN connection, but my network has plenty of overhead space. I even have a couple of videos that can hit over 50Mbps (The Dark Knight Returns for one). That's assuming the bit rate display in the Sony is accurate.
Since I've seen my Yamaha receiver display both DTS Master Audio and Dolby TrueHD while streaming, I'd say the Sony supports it. But since I'm already seeing it on the Yamaha, it seems that the Sony is already passing the bitstream audio, and Serviio is not remuxing it. And that doesn't explain why the Sony is displaying this particular video as MPG, while it shows MKV of other files.
What exactly does this line do: <Matches container="matroska" vCodec="vp8" /> ? What video codec is vp8?
Post Mon Jan 06, 2014 11:12 pm
Not sure how the TrueHD is getting to your receiver as that line will enforce its transcoding to AC3??? Removing this line will ensure these files are played natively.
VP8 is a video codec, see http://en.wikipedia.org/wiki/VP8. This line tells Serviio to transcode these files - if you attempt to play an MKV file that contains VP8 encoded video, Serviio will transcode the video to mpeg2 (and the audio to AC3 if not already) and package it in a mpeg2-ts container.
