[SOLVED] Keep MKV DTS Audio
sirius4
Post Sun Jan 12, 2014 9:04 am
I am using Sony BDP-S480, it woks fine to play MKV video, but I found no matter the original audio encoding is DTS or dolby digital 5.1, my AV amplifier will always show dolby digital 5.1. Seems the DTS audio has been converted to dolby digital 5.1, I tried disable transcoding but no help. But when I play the same MKV video on S480 through direct attached USB, my AV amplifier can correct detect DTS audio.
I was wondering if Serviio can keep DTS to my DPS-S480 player?
Please help provide you opinion.
Steven
Post Sun Jan 12, 2014 10:28 am
Re: Keep MKV DTS Audio
What is the profile selected on serviio console ?
If it was Sony BDP 2010, try comment this line in ""Sony BDP-Sx70/SMP-N100 (2010)"" section from profiles.xml file
<!--Matches container="matroska" aCodec="dca" /-->
The MKV should be delivered in native format to your Sony BDP device.
PS: You can not compare DLNA and USB inputs, they does not use same firmware and same decoder...
sirius4
Post Sun Jan 12, 2014 12:50 pm
Hi Illico,
Thank you for the prompt reply. The suggest config change did work for me.
Regards
Steven
Users browsing this forum: Google [Bot] and 7 guests
