ASS subtitle position
sirius4
Post Sun Jan 12, 2014 12:59 pm
My player is Sony BDP-S480, I am testing the subtitle position in ASS with below parameters.
[V4+ Styles]
Format: Name, Fontname, Fontsize, PrimaryColour, SecondaryColour, OutlineColour, BackColour, Bold, Italic, Underline, BorderStyle, Outline, Shadow, Alignment, MarginL, MarginR, MarginV, AlphaLevel, Encoding
Style: Default,Arial,16,&Hffffff,&Hffffff,&H0,&H0,0,0,0,1,1,0,2,10,10,10,0,0
Alignment: 8
If the "Alignment" works, the subtitle should display in the up center of the screen, but actually not, the subtitle position seems not affected by "Alignment".
Please advise how to change subtitle position in ASS.
Steven
Post Sun Jan 12, 2014 1:49 pm
Re: ASS subtitle position
I made some test here : viewtopic.php?f=3&t=8255#p57781
But I don't remember if I play with "Alignment" options
EDIT: Spécification en français (in french)
http://sweetkaraoke.pagesperso-orange.f ... SS2%29.pdf
Post Sun Jan 12, 2014 1:55 pm
If you look at the spec : http://www.perlfu.co.uk/projects/asa/ass-specs.doc
Could you try this :
[V4+ Styles]
Style: Default,Arial,16,&Hffffff,&Hffffff,&H0,&H0,0,0,0,1,1,0,8,10,10,10,0,0
sirius4
Post Sun Jan 12, 2014 2:05 pm
Hi Illico,
Thank you for your reply.
I did check your previous post, you didn't test Alignment.
Anyway my gold is display subtitle in the black area (when play 1080P MKV video, most of videos show on my TV will have two black area, one on the top, one on the bottom).
Regards
Steven
sirius4
Post Sun Jan 12, 2014 2:36 pm
Hi Illico,
The parameter you suggested was correct, anyway I tried below parameter, only half of subtitle displayed, the other half of subtitle is hided in the black area, I think that's means the subtitle cannot be displayed in the black area.
[V4+ Styles]
Style: Default,Arial,16,&Hffffff,&Hffffff,&H0,&H0,0,0,0,1,1,0,2,10,10,-10,0,0
Test completed.
Steven
Post Sun Jan 12, 2014 3:18 pm
It seems that for your request, you will need ASS2 format [V4 Styles++] and use "RelativeTo" format option.
Look at this french specification of ASS2.
Si le champ "RelativeTo" est à 0, les coordonnées permettant de déterminer la position des lignes de sous-titre sont calculées en incluant les bandes noires (Relative to Screen).
If the field "RelativeTo"Is 0, the coordinates for determining the position of the lines subtitle are calculated including the black bars (Relative to Screen).
If the field "RelativeTo"Is 1, as for ASS (Relative to Frame).
Also look at this : http://forum.doom9.org/showthread.php?p=811063
But the ffmpeg libass does not support V4++
sirius4
Post Mon Jan 13, 2014 12:08 pm
Hi Illico,
Thank you for the information.
Steven
