New server - can't get transcoding working
pointer2null
Post Sun Jan 12, 2014 9:51 pm
I'm in the middle of upgrading my home server and I can't get transcoding working.
I'm using centos 6.3. I've managed to build all the required libraries and Serviio is running except for transcoding. The log says
2014-01-12 21:41:02,654 WARN  [ProcessExecutor] Process /usr/local/bin/ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
libavdevice  52.  5. 0 / 52.  5. 0
libavfilter   1. 80. 0 /  1. 80. 0
libswscale    0. 14. 1 /  0. 14. 1
libpostproc  51.  2. 0 / 51.  2. 0
Expected number for threads but found: auto
2014-01-12 21:41:12,666 WARN  [ServiioStatusService] IOException occured. Returning error code 500 to the REST layer. Message: Transcoded file '/tmp/Serviio/transcoding-temp-20-flv_player-MEDIUM.stf' cannot be found, FFmpeg execution probably failed
2014-01-12 21:41:13,159 WARN  [ProcessExecutor] Process /usr/local/bin/ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
2014-01-12 21:41:23,155 WARN  [ServiioStatusService] IOException occured. Returning error code 500 to the REST layer. Message: Transcoded file '/tmp/Serviio/transcoding-temp-20-flv_player-MEDIUM.stf' cannot be found, FFmpeg execution probably failed
2014-01-12 21:41:23,695 WARN  [ProcessExecutor] Process /usr/local/bin/ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
I'm not sure whats up with ffmpeg - it seems fine:
[root@localhost rtmpdump]# /usr/local/bin/ffmpeg
ffmpeg version 0.7.12, Copyright (c) 2000-2011 the FFmpeg developers
  built on Jan 12 2014 17:40:26 with gcc 4.4.7 20120313 (Red Hat 4.4.7-4)
  configuration: --enable-gpl --enable-version3 --enable-shared --enable-nonfree --enable-postproc --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxvid --enable-x11grab --extra-cflags=-I/usr/local/include --extra-ldflags=-L/usr/local/lib
  libavutil    50. 43. 0 / 50. 43. 0
  libavcodec   52.123. 0 / 52.123. 0
  libavformat  52.111. 0 / 52.111. 0
Use -h to get full help or, even better, run 'man ffmpeg'
I'm hoping this is a common issue and has an easy solution?
(p.s. the instructions on http://wiki.serviio.org/doku.php?id=how ... all:centos don't work - there are various packages that cannot be found and ffmpeg will not build from the git repo)
npuser
Post Sun Jan 12, 2014 11:56 pm
Re: New server - can't get transcoding working
Could please delete the folder "serviio" inside /tmp and let serviio recreated it on next transcoding job? Looks like a screwy permission in /tmp/serviio folder.
thanks
NPuser
Post Mon Jan 13, 2014 6:12 pm
Its nothing to do with permsisions, its because ffmpeg is too old and as such doesn't understand the options that serviio is calling it with.
You will need to build it from source unless you can find a newer one. Which packages couldn't yum find?
pointer2null
Post Mon Jan 13, 2014 7:02 pm
Thanks for the replies. I'dd do both to be sure.
Will, on a clean VM (only guest additions installed)
[root@localhost gary]# yum remove x264 ffmpeg -y
Loaded plugins: fastestmirror, refresh-packagekit, security
Setting up Remove Process
No Match for argument: x264
Loading mirror speeds from cached hostfile
 * base: mirrors.manchester.m247.com
 * extras: mirrors.melbourne.co.uk
 * rpmforge: www.mirrorservice.org
 * updates: mirrors.manchester.m247.com
base        | 3.7 kB     00:00
extras        | 3.4 kB     00:00
rpmforge        | 1.9 kB     00:00
updates        | 3.4 kB     00:00
Package(s) x264 available, but not installed.
No Match for argument: ffmpeg
Package(s) ffmpeg available, but not installed.
No Packages marked for removal
[root@localhost gary]# yum install git libfaac-devel libmp3lame-devel libtheora-devel \
> libva-devel libvdpau-devel libvorbis-devel libX11-devel libXfixes-devel texi2html yasm \
> libxvidcore-devel  libXext-devel libXfixes-devel librtmp-devel
 * base: mirror.synergyworks.co.uk
 * extras: centos.mirroring.pulsant.co.uk
 * updates: mirror.mhd.uk.as44574.net
Setting up Install Process
Package git-1.7.1-3.el6_4.1.x86_64 already installed and latest version
No package libfaac-devel available.
No package libmp3lame-devel available.
Resolving Dependencies
--> Running transaction check
Then the other libs are ok until rtmpdump:
[root@localhost gary]# cd /usr/src
[root@localhost src]# git clone git://git.ffmpeg.org/rtmpdump
Initialized empty Git repository in /usr/src/rtmpdump/.git/
remote: Counting objects: 2531, done.
remote: Compressing objects: 100% (892/892), done.
remote: Total 2531 (delta 1910), reused 2149 (delta 1638)
Receiving objects: 100% (2531/2531), 769.61 KiB | 754 KiB/s, done.
Resolving deltas: 100% (1910/1910), done.
[root@localhost src]# cd rtmpdump
[root@localhost rtmpdump]# make SYS=posix
make[1]: Entering directory `/usr/src/rtmpdump/librtmp'
gcc -Wall   -DRTMPDUMP_VERSION=\"v2.4\" -DUSE_OPENSSL  -O2 -fPIC   -c -o rtmp.o rtmp.c
rtmp.c:60:25: error: openssl/ssl.h: No such file or directory
rtmp.c:61:25: error: openssl/rc4.h: No such file or directory
rtmp.c:62:25: error: openssl/md5.h: No such file or directory
rtmp.c:63:25: error: openssl/bio.h: No such file or directory
rtmp.c:64:28: error: openssl/buffer.h: No such file or directory
rtmp.c:66: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘*’ token
In file included from rtmp.c:150:
handshake.h:66:25: error: openssl/sha.h: No such file or directory
handshake.h:67:26: error: openssl/hmac.h: No such file or directory
handshake.h:70:2: error: #error Your OpenSSL is too old, need 0.9.8 or newer with SHA256
handshake.h:76: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘*’ token
In file included from handshake.h:86,
                 from rtmp.c:150:
dh.h:167:24: error: openssl/bn.h: No such file or directory
dh.h:168:24: error: openssl/dh.h: No such file or directory
                 from rtmp.c:150:
dh.h:170: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘*’ token
                 from rtmp.c:150:
dh.h:197: error: expected ‘)’ before ‘y’
dh.h:247: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘*’ token
dh.h:280: error: expected ‘)’ before ‘*’ token
dh.h:314: error: expected ‘)’ before ‘*’ token
dh.h:350: error: expected ‘)’ before ‘*’ token
handshake.h:116: error: expected declaration specifiers or ‘...’ before ‘RC4_handle’
handshake.h: In function ‘InitRC4Encryption’:
handshake.h:118: error: ‘SHA256_DIGEST_LENGTH’ undeclared (first use in this function)
handshake.h:118: error: (Each undeclared identifier is reported only once
handshake.h:118: error: for each function it appears in.)
handshake.h:120: error: ‘HMAC_CTX’ undeclared (first use in this function)
handshake.h:120: error: expected ‘;’ before ‘ctx’
handshake.h:122: error: ‘rc4keyIn’ undeclared (first use in this function)
handshake.h:122: error: ‘RC4_KEY’ undeclared (first use in this function)
handshake.h:123: error: ‘rc4keyOut’ undeclared (first use in this function)
handshake.h:125: warning: implicit declaration of function ‘HMAC_CTX_init’
handshake.h:125: error: ‘ctx’ undeclared (first use in this function)
handshake.h:125: warning: implicit declaration of function ‘HMAC_Init_ex’
handshake.h:125: warning: implicit declaration of function ‘EVP_sha256’
handshake.h:126: warning: implicit declaration of function ‘HMAC_Update’
handshake.h:127: warning: implicit declaration of function ‘HMAC_Final’
handshake.h:127: warning: implicit declaration of function ‘HMAC_CTX_cleanup’
handshake.h:132: warning: implicit declaration of function ‘RC4_set_key’
handshake.h:118: warning: unused variable ‘digest’
handshake.h: In function ‘HMACsha256’:
handshake.h:269: error: ‘HMAC_CTX’ undeclared (first use in this function)
handshake.h:269: error: expected ‘;’ before ‘ctx’
handshake.h:271: error: ‘ctx’ undeclared (first use in this function)
handshake.h: In function ‘CalculateDigest’:
handshake.h:282: error: ‘SHA256_DIGEST_LENGTH’ undeclared (first use in this function)
handshake.h:283: warning: unused variable ‘message’
handshake.h: In function ‘VerifyDigest’:
handshake.h:297: error: ‘SHA256_DIGEST_LENGTH’ undeclared (first use in this function)
handshake.h:297: warning: unused variable ‘calcDigest’
handshake.h: In function ‘HandShake’:
handshake.h:703: error: ‘RC4_handle’ undeclared (first use in this function)
handshake.h:703: error: expected ‘;’ before ‘keyIn’
handshake.h:704: error: expected ‘;’ before ‘keyOut’
handshake.h:772: warning: implicit declaration of function ‘DHInit’
handshake.h:772: warning: assignment makes pointer from integer without a cast
handshake.h:783: warning: implicit declaration of function ‘DHGenerateKey’
handshake.h:790: warning: implicit declaration of function ‘DHGetPublicKey’
handshake.h:806: error: ‘SHA256_DIGEST_LENGTH’ undeclared (first use in this function)
handshake.h:893: warning: implicit declaration of function ‘DHComputeSharedSecretKey’
handshake.h:907: error: ‘keyIn’ undeclared (first use in this function)
handshake.h:907: error: ‘keyOut’ undeclared (first use in this function)
handshake.h:907: error: too many arguments to function ‘InitRC4Encryption’
handshake.h:847: warning: unused variable ‘digestResp’
handshake.h:1049: warning: implicit declaration of function ‘RC4’
handshake.h:983: warning: unused variable ‘digest’
handshake.h:982: warning: unused variable ‘signature’
handshake.h: In function ‘SHandShake’:
handshake.h:1077: error: ‘RC4_handle’ undeclared (first use in this function)
handshake.h:1077: error: expected ‘;’ before ‘keyIn’
handshake.h:1078: error: expected ‘;’ before ‘keyOut’
handshake.h:1160: warning: assignment makes pointer from integer without a cast
handshake.h:1195: error: ‘SHA256_DIGEST_LENGTH’ undeclared (first use in this function)
handshake.h:1277: error: ‘keyIn’ undeclared (first use in this function)
handshake.h:1277: error: ‘keyOut’ undeclared (first use in this function)
handshake.h:1277: error: too many arguments to function ‘InitRC4Encryption’
handshake.h:1214: warning: unused variable ‘digestResp’
handshake.h:1341: warning: unused variable ‘digest’
handshake.h:1340: warning: unused variable ‘signature’
rtmp.c: In function ‘RTMP_TLS_Init’:
rtmp.c:243: warning: implicit declaration of function ‘SSL_load_error_strings’
rtmp.c:244: warning: implicit declaration of function ‘SSL_library_init’
rtmp.c:245: warning: implicit declaration of function ‘OpenSSL_add_all_digests’
rtmp.c:246: error: ‘RTMP_TLS_ctx’ undeclared (first use in this function)
rtmp.c:246: warning: implicit declaration of function ‘SSL_CTX_new’
rtmp.c:246: warning: implicit declaration of function ‘SSLv23_method’
rtmp.c:247: warning: implicit declaration of function ‘SSL_CTX_set_options’
rtmp.c:247: error: ‘SSL_OP_ALL’ undeclared (first use in this function)
rtmp.c:248: warning: implicit declaration of function ‘SSL_CTX_set_default_verify_paths’
rtmp.c: In function ‘RTMP_TLS_AllocServerContext’:
rtmp.c:258: error: ‘RTMP_TLS_ctx’ undeclared (first use in this function)
rtmp.c:281: warning: implicit declaration of function ‘SSLv23_server_method’
rtmp.c:281: warning: assignment makes pointer from integer without a cast
rtmp.c:282: warning: implicit declaration of function ‘SSL_CTX_use_certificate_chain_file’
rtmp.c:283: warning: implicit declaration of function ‘SSL_CTX_free’
rtmp.c:286: warning: implicit declaration of function ‘SSL_CTX_use_PrivateKey_file’
rtmp.c:286: error: ‘SSL_FILETYPE_PEM’ undeclared (first use in this function)
rtmp.c: In function ‘RTMP_Init’:
rtmp.c:327: error: ‘RTMP_TLS_ctx’ undeclared (first use in this function)
rtmp.c: In function ‘RTMP_TLS_Accept’:
rtmp.c:958: warning: implicit declaration of function ‘SSL_new’
rtmp.c:958: warning: assignment makes pointer from integer without a cast
rtmp.c:959: warning: implicit declaration of function ‘SSL_set_fd’
rtmp.c:960: warning: implicit declaration of function ‘SSL_accept’
rtmp.c: In function ‘RTMP_Connect1’:
rtmp.c:977: error: ‘RTMP_TLS_ctx’ undeclared (first use in this function)
rtmp.c:979: warning: implicit declaration of function ‘SSL_connect’
rtmp.c: In function ‘b64enc’:
rtmp.c:2457: error: ‘BIO’ undeclared (first use in this function)
rtmp.c:2457: error: ‘bmem’ undeclared (first use in this function)
rtmp.c:2457: error: ‘b64’ undeclared (first use in this function)
rtmp.c:2457: warning: left-hand operand of comma expression has no effect
rtmp.c:2458: error: ‘BUF_MEM’ undeclared (first use in this function)
rtmp.c:2458: error: ‘bptr’ undeclared (first use in this function)
rtmp.c:2460: warning: implicit declaration of function ‘BIO_new’
rtmp.c:2460: warning: implicit declaration of function ‘BIO_f_base64’
rtmp.c:2461: warning: implicit declaration of function ‘BIO_s_mem’
rtmp.c:2462: warning: implicit declaration of function ‘BIO_push’
rtmp.c:2463: warning: implicit declaration of function ‘BIO_write’
rtmp.c:2464: warning: implicit declaration of function ‘BIO_flush’
rtmp.c:2466: warning: implicit declaration of function ‘BIO_get_mem_ptr’
rtmp.c:2475: warning: implicit declaration of function ‘BIO_free_all’
rtmp.c: In function ‘PublisherAuth’:
rtmp.c:2521: error: ‘MD5_DIGEST_LENGTH’ undeclared (first use in this function)
rtmp.c:2522: error: ‘MD5_CTX’ undeclared (first use in this function)
rtmp.c:2522: error: expected ‘;’ before ‘md5ctx’
rtmp.c:2599: warning: implicit declaration of function ‘MD5_Init’
rtmp.c:2599: error: ‘md5ctx’ undeclared (first use in this function)
rtmp.c:2600: warning: implicit declaration of function ‘MD5_Update’
rtmp.c:2603: warning: implicit declaration of function ‘MD5_Final’
rtmp.c:2715: warning: unused variable ‘hash3’
rtmp.c:2715: warning: unused variable ‘hash2’
rtmp.c:2715: warning: unused variable ‘hash1’
rtmp.c:2521: warning: unused variable ‘md5sum_val’
rtmp.c: In function ‘RTMP_Close’:
rtmp.c:4235: warning: implicit declaration of function ‘DH_free’
rtmp.c: In function ‘RTMPSockBuf_Fill’:
rtmp.c:4268: warning: implicit declaration of function ‘SSL_read’
rtmp.c: In function ‘RTMPSockBuf_Send’:
rtmp.c:4311: warning: implicit declaration of function ‘SSL_write’
rtmp.c: In function ‘RTMPSockBuf_Close’:
rtmp.c:4327: warning: implicit declaration of function ‘SSL_shutdown’
rtmp.c:4328: warning: implicit declaration of function ‘SSL_free’
make[1]: *** [rtmp.o] Error 1
make[1]: Leaving directory `/usr/src/rtmpdump/librtmp'
make: *** [librtmp/librtmp.a] Error 2
Installing openssl-devl fixes this.
I followed instructions here http://www.vimp.com/en/web/faq/items/howto-install-the-transcoding-tools-on-redhat-centos-etc.html to get the libraries. Looks like I cut and pasted the wrong version of ffmpeg as well :oops:
Update:
Now when I try with the source from the serviio site I get:
[root@localhost ffmpeg]# ./configure --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libtheora \
>  --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 \
> --enable-x11grab --enable-libvpx --enable-librtmp --enable-libxvid
ERROR: librtmp not found
If you think configure made a mistake, make sure you are using the latest
version from Git.  If the latest version fails, report the problem to the
ffmpeg-user@ffmpeg.org mailing list or IRC #ffmpeg on irc.freenode.net.
Include the log file "config.log" produced by configure as this will help
solving the problem.
