v 1.4 does not work
jcurlee
Post Tue Jan 14, 2014 1:54 pm
v 1.4 does not work
Since I downloaded V 1.4, I can no longer stream any of my Videos from my computer library to my Sharp Aquos smart TV which used a DNLA app. The video files show up on the TV like they are being found from Serviio but they will not play. They are mostly MP3 or MP4 files. Nothing strange files. I also downloaded a new video and it will not play either. Everything played fine with the previous version and luckily I was able to uninstall V 1.4 and download the previous version. I will most likely try to avoid all new versions now.
Post Tue Jan 14, 2014 6:07 pm
Re: v 1.4 does not work
1.4 works fine. Sounds like you have not read the documentation on how to select the correct profile for your TV.
Return to User experiences
Users browsing this forum: Baidu [Spider] and 16 guests
