Backup configuration request
paniko
Post Fri May 03, 2013 11:28 am
I want to know if is it possible to implement a backup configuration files for serviio.
Or if it's not possible is possible to implement a backup for the library and the online media sources?
Let me know
Many thanks,
Paniko
Sumsung EU46D6500 | XBox 360 | Samsung Galaxy S 6 Edge | Windows 10 - i7 64bit | Serviio 1.5.2 Pro
Beta Tester
Post Fri May 03, 2013 1:14 pm
Re: Backup configuration request
just store the library folder
Pauli
Post Sun Jan 19, 2014 9:34 am
I want to transfer Serviio to a new server and do not want to make all settings. So backing up the library folder is not enough ...
So is there a possibility to transfer all settings to the new installation? Where all my config's stored?
Thanks, Pauli
Iveky
Post Sun Jan 19, 2014 3:08 pm
i moved mine to new faster fedora linux pc:
mine videos are in same folders as on old server, so, i checked only file permitions for all videos and AFTER that copied whole serviio folder, not only library (/opt/serviio)
everything works as on old server.
Pauli
Post Sun Jan 19, 2014 3:24 pm
OK + Thanks!
Now I see the library folder at Serviio and there are the config! So moving this to the new server and everything is working fine!
Pauli
Return to Feature requests
