Hibernate on Synology DS213j
SerialK
Post Sat Jan 18, 2014 3:04 pm
Hi!
i've been playing around with serviio on my NAS and it seems to keep it awake all the time..
Here is a part of my var/log/messages, can you help me with the Problem? 192.168.178.21 is the local fixed IP-address of the NAS. It's static by the fritzBox
Jan 17 12:23:06 Disk-Station upnpd: (upnpd.c:203) upnpd.c(203) : IP change (old IP = NULL, new IP = 188.194.233.82)
Jan 17 12:23:07 Disk-Station upnpd: (upnpd.c:432) Failed to Add (IP[192.168.178.21], port[6690]) synoerrno=[403,Unknown(403)]
Jan 17 12:59:59 Disk-Station kernel: [312385.537507] ata2: wake up from deepsleep, reset link now
Jan 17 12:59:59 Disk-Station kernel: [312385.628213] ata2: device plugged sstatus 0x123
Jan 17 13:00:09 Disk-Station kernel: [312394.484957] ata2: link is slow to respond, please be patient (ready=0)
Jan 17 13:00:09 Disk-Station kernel: [312397.769568] ata2: wake up successful, the reset fail can be ignored
Jan 17 13:38:57 Disk-Station upnpd: (upnpd.c:203) upnpd.c(203) : IP change (old IP = NULL, new IP = 188.194.233.82)
Jan 17 13:38:58 Disk-Station upnpd: (upnpd.c:432) Failed to Add (IP[192.168.178.21], port[6690]) synoerrno=[403,Unknown(403)]
Jan 17 14:09:44 Disk-Station kernel: [316570.226692] ata2: wake up from deepsleep, reset link now
Jan 17 14:09:44 Disk-Station kernel: [316570.317399] ata2: device plugged sstatus 0x123
Jan 17 14:09:49 Disk-Station kernel: [316579.174136] ata2: link is slow to respond, please be patient (ready=0)
Jan 17 14:09:53 Disk-Station kernel: [316582.338742] ata2: wake up successful, the reset fail can be ignored
Jan 17 14:52:42 Disk-Station upnpd: (upnpd.c:203) upnpd.c(203) : IP change (old IP = NULL, new IP = 188.194.233.82)
Jan 17 14:52:43 Disk-Station upnpd: (upnpd.c:432) Failed to Add (IP[192.168.178.21], port[6690]) synoerrno=[403,Unknown(403)]
Jan 17 15:11:37 Disk-Station kernel: [320284.277405] ata2: wake up from deepsleep, reset link now
Jan 17 15:11:37 Disk-Station kernel: [320284.368198] ata2: device plugged sstatus 0x123
Jan 17 15:11:43 Disk-Station kernel: [320293.224905] ata2: link is slow to respond, please be patient (ready=0)
Jan 17 15:11:46 Disk-Station kernel: [320296.329543] ata2: wake up successful, the reset fail can be ignored
Jan 17 15:51:41 Disk-Station upnpd: (upnpd.c:203) upnpd.c(203) : IP change (old IP = NULL, new IP = 188.194.233.82)
Jan 17 15:51:42 Disk-Station upnpd: (upnpd.c:432) Failed to Add (IP[192.168.178.21], port[6690]) synoerrno=[403,Unknown(403)]
Jan 17 16:08:09 Disk-Station upnpd: (upnpd.c:203) upnpd.c(203) : IP change (old IP = NULL, new IP = 188.194.233.82)
Jan 17 16:08:10 Disk-Station upnpd: (upnpd.c:432) Failed to Add (IP[192.168.178.21], port[6690]) synoerrno=[403,Unknown(403)]
Jan 17 17:29:29 Disk-Station upnpd: (upnpd.c:203) upnpd.c(203) : IP change (old IP = NULL, new IP = 188.194.233.82)
Jan 17 17:29:30 Disk-Station upnpd: (upnpd.c:432) Failed to Add (IP[192.168.178.21], port[6690]) synoerrno=[403,Unknown(403)]
Jan 17 18:38:58 Disk-Station upnpd: (upnpd.c:203) upnpd.c(203) : IP change (old IP = NULL, new IP = 188.194.233.82)
Jan 17 18:38:59 Disk-Station upnpd: (upnpd.c:432) Failed to Add (IP[192.168.178.21], port[6690]) synoerrno=[403,Unknown(403)]
Jan 17 19:39:00 Disk-Station upnpd: (upnpd.c:203) upnpd.c(203) : IP change (old IP = NULL, new IP = 188.194.233.82)
Jan 17 19:39:01 Disk-Station upnpd: (upnpd.c:432) Failed to Add (IP[192.168.178.21], port[6690]) synoerrno=[403,Unknown(403)]
Jan 17 20:39:01 Disk-Station upnpd: (upnpd.c:203) upnpd.c(203) : IP change (old IP = NULL, new IP = 188.194.233.82)
Jan 17 20:39:02 Disk-Station upnpd: (upnpd.c:432) Failed to Add (IP[192.168.178.21], port[6690]) synoerrno=[403,Unknown(403)]
Jan 17 21:06:56 Disk-Station kernel: [341605.319497] ata2: wake up from deepsleep, reset link now
Jan 17 21:06:56 Disk-Station kernel: [341605.410256] ata2: device plugged sstatus 0x123
Jan 17 21:07:02 Disk-Station kernel: [341614.266959] ata2: link is slow to respond, please be patient (ready=0)
Jan 17 21:07:07 Disk-Station kernel: [341617.481567] ata2: wake up successful, the reset fail can be ignored
Jan 17 21:39:02 Disk-Station upnpd: (upnpd.c:203) upnpd.c(203) : IP change (old IP = NULL, new IP = 188.194.233.82)
Jan 17 21:39:03 Disk-Station upnpd: (upnpd.c:432) Failed to Add (IP[192.168.178.21], port[6690]) synoerrno=[403,Unknown(403)]
Jan 17 22:51:40 Disk-Station upnpd: (upnpd.c:203) upnpd.c(203) : IP change (old IP = NULL, new IP = 188.194.233.82)
Jan 17 22:51:41 Disk-Station upnpd: (upnpd.c:432) Failed to Add (IP[192.168.178.21], port[6690]) synoerrno=[403,Unknown(403)]
Jan 18 01:13:52 Disk-Station upnpd: (upnpd.c:203) upnpd.c(203) : IP change (old IP = NULL, new IP = 188.194.233.82)
Jan 18 01:13:53 Disk-Station upnpd: (upnpd.c:432) Failed to Add (IP[192.168.178.21], port[6690]) synoerrno=[403,Unknown(403)]
Jan 18 04:43:06 Disk-Station upnpd: (upnpd.c:203) upnpd.c(203) : IP change (old IP = NULL, new IP = 188.194.233.82)
Jan 18 04:43:07 Disk-Station upnpd: (upnpd.c:432) Failed to Add (IP[192.168.178.21], port[6690]) synoerrno=[403,Unknown(403)]
Jan 18 05:47:51 Disk-Station upnpd: (upnpd.c:203) upnpd.c(203) : IP change (old IP = NULL, new IP = 188.194.233.82)
Jan 18 05:47:52 Disk-Station upnpd: (upnpd.c:432) Failed to Add (IP[192.168.178.21], port[6690]) synoerrno=[403,Unknown(403)]
Jan 18 06:24:05 Disk-Station kernel: [375034.202994] ata2: wake up from deepsleep, reset link now
Jan 18 06:24:05 Disk-Station kernel: [375034.293696] ata2: device plugged sstatus 0x123
Jan 18 06:24:10 Disk-Station kernel: [375043.150551] ata2: link is slow to respond, please be patient (ready=0)
Jan 18 06:24:14 Disk-Station kernel: [375046.315129] ata2: wake up successful, the reset fail can be ignored
Jan 18 10:39:05 Disk-Station upnpd: (upnpd.c:203) upnpd.c(203) : IP change (old IP = NULL, new IP = 188.194.233.82)
Jan 18 10:39:06 Disk-Station upnpd: (upnpd.c:432) Failed to Add (IP[192.168.178.21], port[6690]) synoerrno=[403,Unknown(403)]
Jan 18 10:52:45 Disk-Station upnpd: (upnpd.c:432) Failed to Add (IP[192.168.178.21], port[6690]) synoerrno=[403,Unknown(403)]
Jan 18 11:52:20 Disk-Station upnpd: (upnpd.c:203) upnpd.c(203) : IP change (old IP = NULL, new IP = 188.194.233.82)
Jan 18 11:52:21 Disk-Station upnpd: (upnpd.c:432) Failed to Add (IP[192.168.178.21], port[6690]) synoerrno=[403,Unknown(403)]
Jan 18 12:12:16 Disk-Station kernel: [395926.662658] ata2: wake up from deepsleep, reset link now
Jan 18 12:12:16 Disk-Station kernel: [395926.753466] ata2: device plugged sstatus 0x123
Jan 18 12:12:22 Disk-Station kernel: [395935.613435] ata2: link is slow to respond, please be patient (ready=0)
Jan 18 12:12:25 Disk-Station kernel: [395938.778189] ata2: wake up successful, the reset fail can be ignored
Jan 18 12:52:44 Disk-Station upnpd: (upnpd.c:203) upnpd.c(203) : IP change (old IP = NULL, new IP = 188.194.233.82)
Jan 18 12:52:45 Disk-Station upnpd: (upnpd.c:432) Failed to Add (IP[192.168.178.21], port[6690]) synoerrno=[403,Unknown(403)]
Jan 18 13:22:01 Disk-Station kernel: [400112.333453] ata2: wake up from deepsleep, reset link now
Jan 18 13:22:01 Disk-Station kernel: [400112.424192] ata2: device plugged sstatus 0x123
Jan 18 13:22:07 Disk-Station kernel: [400121.289790] ata2: link is slow to respond, please be patient (ready=0)
Jan 18 13:22:12 Disk-Station kernel: [400124.454395] ata2: wake up successful, the reset fail can be ignored
Jan 18 13:54:30 Disk-Station upnpd: (upnpd.c:203) upnpd.c(203) : IP change (old IP = NULL, new IP = 188.194.233.82)
Jan 18 13:54:31 Disk-Station upnpd: (upnpd.c:432) Failed to Add (IP[192.168.178.21], port[6690]) synoerrno=[403,Unknown(403)]
Jan 18 14:31:47 Disk-Station kernel: [404298.333002] ata2: wake up from deepsleep, reset link now
Jan 18 14:31:47 Disk-Station kernel: [404298.423702] ata2: device plugged sstatus 0x123
Jan 18 14:31:53 Disk-Station kernel: [404307.280810] ata2: link is slow to respond, please be patient (ready=0)
Jan 18 14:31:56 Disk-Station kernel: [404310.445598] ata2: wake up successful, the reset fail can be ignored
Jan 18 15:12:52 Disk-Station upnpd: (upnpd.c:203) upnpd.c(203) : IP change (old IP = NULL, new IP = 188.194.233.82)
Jan 18 15:12:53 Disk-Station upnpd: (upnpd.c:432) Failed to Add (IP[192.168.178.21], port[6690]) synoerrno=[403,Unknown(403)]
Jan 18 15:57:23 Disk-Station synoupnp: (upnpclient.c:777) 2 send action failed [port = 0] 713
SerialK
Post Sun Jan 19, 2014 8:58 pm
Re: Hibernate on Synology DS213j
Nobody can tell me what that upnp line means?
or what link it is resetting?
bikerp
Post Wed Jan 22, 2014 8:13 am
just a guess. Maybe it tries to register external IP adresss on Synology DDNS server.
Pavel
drSHLEFF
Post Mon Feb 10, 2014 4:09 pm
I have the same issue on DS713+. Serviio prevents NAS hibernation because periodically scan for new files, even if there is no activity :(
I have already raised this issue with developers and even offered to use inotify linux subsystem for identify file activity instead periodical scan, but no reply received ...
mysteray
Post Fri Feb 14, 2014 11:48 pm
I agree. I reckon something should be done about this. The way serviio is running at the moment is not very economical. Maybe that's an exaggeration, but when I inspect the detailed logging of Serviio I can see that it practically works the entire time every second. Is that what keeps my DS-114 awake? I wonder.
MarcelTheRadioMan1
Post Thu Apr 17, 2014 7:58 pm
Do you have more news about a solution of this problem? I have this problem too with the latest release of the Serviio package.
