D5700 and WMV files
speedee
Post Mon Jan 20, 2014 8:04 pm
D5700 and WMV files
it seems that my Samsung U40D5700 won't play .wmv files ("Unsupported Video Codec") when selecting the C/D profile, but in General DLNA profile it does.
Anyone has an idea why this happens ?
Example file media info:
Format : Windows Media
Overall bit rate mode : Constant
Overall bit rate : 3 051 Kbps
Maximum Overall bit rate : 3 316 Kbps
Format : VC-1
Format profile : MP@ML
Codec ID : WMV3
Codec ID/Info : Windows Media Video 9
Codec ID/Hint : WMV3
Description of the codec : Windows Media Video 9
Duration : 24mn 7s
Bit rate mode : Constant
Bit rate : 3 160 Kbps
Width : 704 pixels
Height : 396 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.378
Stream size : 545 MiB
Language : English (US)
Format : WMA
Format version : Version 2
Codec ID : 161
Codec ID/Info : Windows Media Audio
Description of the codec : Windows Media Audio 9.2 - 128 kbps, 44 kHz, stereo 2-pass CBR
Duration : 24mn 7s
Bit rate : 128 Kbps
Channel count : 2 channels
Sampling rate : 44.1 KHz
Bit depth : 16 bits
Stream size : 22.1 MiB (4%)
Post Tue Jan 21, 2014 8:54 am
Re: D5700 and WMV files
Could you provide "ffmpeg -i <file>" result of your file ?
speedee
Post Tue Jan 21, 2014 7:47 pm
FFMPEG info is:
Input #0, asf, from 'T.wmv':
WMFSDKNeeded : 0.0.0.0000
DeviceConformanceTemplate: MP@ML
WMFSDKVersion : 11.0.5721.5275
IsVBR : 0
Duration: 00:24:07.91, start: 0.000000, bitrate: 3050 kb/s
Stream #0:0(eng): Audio: wmav2 (a[1][0][0] / 0x0161), 44100 Hz, stereo, fltp
, 128 kb/s
Stream #0:1(eng): Video: wmv3 (Main) (WMV3 / 0x33564D57), yuv420p, 704x396,
3160 kb/s, 29.97 tbr, 1k tbn, 1k tbc
