Problem to transcode pure audio files to LPCM
pierrep
Post Mon Jan 13, 2014 7:55 am
Hello
I have a device (Sharp Aquos TV) supporting only LPCM. My music collection is mainly composed of FLAC files. So I had to transcode.
With Serviio 1.2 I had no problem but when upgraded to Serviio 1.4, it's impossible to read the transcoded file on the device.
I had a look at the debug log file and I try to launch manually the same ffmpeg command
$ ffmpeg -threads 4 -i InputFile.flac -y -threads 4 -ar 44100 -ac 2 -f s16be OutputFile.flv
ffmpeg version 0.10.9-7:0.10.9-1~saucy1 Copyright (c) 2000-2013 the FFmpeg developers
  Input #0, flac, from 'InputFile.flac':
    Stream #0:0: Audio: flac, 44100 Hz, stereo, s16
  Output #0, s16be, to 'OutputFile.flv':
    Stream #0:0: Audio: pcm_s16be, 44100 Hz, 2 channels, s16, 1411 kb/s
  Stream mapping:
    Stream #0:0 -> #0:0 (flac -> pcm_s16be)
  size=   71226kB time=00:06:53.46 bitrate=1411.2kbits/s
  video:0kB audio:71226kB global headers:0kB muxing overhead 0.000000%
$ ffmpeg -i OutputFile.flv
OutputFile.flv: Invalid data found when processing input
I have tried with multiple versions of ffmpeg on both Linux/Ubuntu x64 and Windows 7 x86 and with multiple input files (Flac and Wav) with always the same result :(
What has been changed concerning this kind of transcoding between Serviio 1.2 and 1.4?
Pierre
pierrep
Post Wed Jan 15, 2014 8:59 am
Re: Problem to transcode pure audio files to LPCM
Hello
I've made some tests: the ffmpeg command launched by Serviio is not valid (as the -f parameter force output file format which is normally auto detected from the file extension of the output file).
Existing command: ffmpeg -threads 4 -i InputFile.flac -y -threads 4 -ar 44100 -ac 2 -f s16be OutputFile.flv
I've tested with the following command: ffmpeg -threads 4 -i InputFile.flac -y -threads 4 -ar 44100 -ac 2 -acodec lpcm_s16be OutputFile.flv.
We have to omit the -f s16be parameter with a FLV output
This new command create a valid file (according to ffmpeg) but it seems it is a Little-Endian PCM file (pcm_16le) instead of the expected Big-Endian (pcm_16be).
When I open it with VLC for example it's not possible to play it correctly. It is OK if I use lpcm_s16le codec but DLNA norm says "Big-Endian LPCM"
Genereted file with -acodec lpcm_s16be
Input #0, flv, from 'OutputFile.flv':
    encoder         : Lavf55.23.103
  Duration: 00:01:00.00, start: 0.000000, bitrate: 1412 kb/s
    Stream #0:0: Audio: pcm_s16le, 44100 Hz, stereo, s16, 1411 kb/s
How is it possible to change the ffmpeg command launched by Serviio? (Do we have to wait for a new version or patch?)
Regards
Pierre
pierrep
Post Tue Jan 21, 2014 9:50 am
I've made additional tests
The only way I have found to create a valid Big Endian LPCM file is to use: fmpeg -i InputFile.flac -y -threads 4 -ar 44100 -ac 2 -acodec pcm_s16be -f dvd OutputFile.flv
This command create some warnings but create a file which is seen as "PCM / Big Endian" by Mediainfo and is correctly played by VLC on a little endian hardware (PC with Windows 7)
I cannot test the created file with Serviio and my renderer as Serviio do not support pure audio .FLV files, .L16 files or .PCM files
Regards
Pierre
