Unknown Genre assigned to Videos
Post Mon Jan 20, 2014 12:40 am
Cannot recall seeing this issue reported - apologies if already done:
I store my Home Movies in a separate shared folder (ie. separate from my copies of commercial movies) and do not have "Retrieve Descriptive Metadata" ticked for that shared folder. This ensures that these videos do inadvertently get assigned the wrong metadata (I use on-line metadata for my other shared folders) and therefore do not appear in the library under categories that require metadata eg. "Movies", "Series", "Directors", etc.
They do however appear under the category "Genres", under the genre "Unknown". Is this by design or is it a bug? Given that there shouldn't be any metadata collected for these files, I was surprised to see them there. If by design, is there any way to assign all files in a folder and its subfolders to a more meaningful Genre (eg. "Home Movies").
Post Tue Jan 21, 2014 5:34 pm
Re: Unknown Genre assigned to Videos
It's a feature, basically hardcoding this value for any video that has no genre (as a result of not retrieving the metadata).
So it can have that value either by not using metadata, or when using metadata but no genre value found. So hardcoding it to Home Movies would not make sense in that second case.
Post Wed Jan 22, 2014 1:03 pm
Thanks. Not overly concerned about this but it does seem a little inconsistent - for example, we don't assign videos for which metadata isn't collected to "Unknown" in the Ratings category, or created an "Unknown" n the "Directors" category for it, etc.
Users browsing this forum: Baidu [Spider] and 33 guests
