Serviio 0.5 on Qnap TS-419P
geniusit
Post Wed Feb 02, 2011 9:27 pm
Hi, I had serviio 0.4.2 working on my qnap, and It's a great stream server.
I installed today the 0.5 version (anyway I didn't erase the 0.4.2) I have some problems on metadata, I can't see the titles of film, meanwhile in the other old version it works good, but is it the same for you? I changed in the serviio console the default language for metadata and I put italian, this thing wasn't possible in the old version. I noticed that adding file it's a lot slower in this version, in the 0.4.2 library update it's faster (the first time too when it creates the db, I noticed the old version is faster) may be I did something wrong?
edited: sorry for me, ok in the previous version browsing the "folder" type the titles was shown, in this version in the "folder" category is shown the filename! it's better! do you know if there is any software to edit in the right way for serviio the metadata? there is a particular key metadata (like the imdb code) to add to files? (instead title and year).
Serviio 1.0.1 - Qnap TS-419P (8TB) - Samsung UE55C8000XP - Network cables Cat.7 for all House (no wifi)
Post Wed Feb 02, 2011 11:27 pm
Re: Serviio 0.5 on Qnap TS-419P
No, but you can manage your metadata with XBMC or Swisscenter now if you don't feel like renaming your files. Post post some file names that don't get recognized so that I can add the pattern to future release.
geniusit
Post Thu Feb 03, 2011 2:48 am
Maybe because the title is half italian like this three:
Awake - Anestesia coscente 1080p CK.mkv
Batman - Il Cavaliere Oscuro - 1080p.mkv
Fast & Furious - Solo parti originali.mkv
But I thought that the the titles are taken from metadata extractor that find online, getting the metadata from files, it depends on the filename too?
Post Thu Feb 03, 2011 9:23 am
geniusit
Post Thu Feb 03, 2011 11:18 am
Ah ok, I didn't read this sorry! But on the serviio client there is a tab where I can set the metadata extractor, is it just for the priority this tab?
Post Thu Feb 03, 2011 11:27 am
Nope, the file name is used for the online metadata lookup.
Return to User experiences
Users browsing this forum: No registered users and 61 guests
