Great product but having .WTV metadata problem
scruffy53
Post Wed Jan 22, 2014 7:21 pm
I installed Serviio yesterday so I can stream recorded TV shows from Media Center PC running Windows 7 x64 to a Samsung smart tv in an upstairs bedroom. The TV shows are recorded in .wtv format. Without Serviio I can browse the shows and the metadata is correct but I can't view them. WIth Serviio, I can watch the shows and I must say that the quality of the transcoding far exceeded my expectations. But the metadata is incorrect to the point that I really can't tell which show is which. All the pertinent metadata is contained within the body of the .wtv file. Right click on the file and select 'Properties' and then select the 'Details' tab to see the metadata. Is it possible that Serviio is not using the embedded metadata from the file but trying to find it online using the filename? Or perhaps I just don't have it configured properly?
Post Wed Jan 22, 2014 7:24 pm
Re: Great product but having .WTV metadata problem
Yes, embedded video file metadata is not used yet. Can you post ffmpeg -i for your file?
Post Thu Jan 23, 2014 1:14 am
zip wrote:Yes, embedded video file metadata is not used yet. Can you post ffmpeg -i for your file?
Here's one Zip. I have dozens more, including some HD if you'd like.
E:\Recorded TV>c:\ffmpeg\ffmpeg -i "at the earth's core (1976).wtv"
ffmpeg version N-54960-gf3f4e13 Copyright (c) 2000-2013 the FFmpeg developers
  built on Jul 26 2013 19:21:01 with gcc 4.7.3 (GCC)
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av
isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
le-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetyp
e --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --ena
ble-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-l
ibopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libsp
eex --enable-libtheora --enable-libtwolame --enable-libvo-aacenc --enable-libvo-
amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --
enable-libxvid --enable-zlib
  libavutil      52. 40.100 / 52. 40.100
  libavcodec     55. 19.100 / 55. 19.100
  libavformat    55. 12.102 / 55. 12.102
  libavdevice    55.  3.100 / 55.  3.100
  libavfilter     3. 81.103 /  3. 81.103
  libswscale      2.  4.100 /  2.  4.100
  libswresample   0. 17.103 /  0. 17.103
[wtv @ 000000000250aca0] truncated file
    Last message repeated 3 times
[wtv @ 000000000250aca0] unknown media type, mediatype:80ea0a67823ad011b79b00aa0
03767a7, subtype:224a8d6e0c31d011b79a00aa003767a7, formattype:d617640f18c3d011a4
3f00a0c9223196
Input #0, wtv, from 'at the earth's core (1976).wtv':
    WM/MediaClassPrimaryID: db9830bd-3ab3-4fab-8a371a995f7ff74
    WM/MediaClassSecondaryID: ba7f258a-62f7-47a9-b21f4651c42a000
    Title           : At the Earth's Core
    WM/SubTitleDescription: Victorian explorers (Doug McClure, Peter Cushing) bu
rrow to Pellucidar, where mutant Sagoths rule the Wing People.
    genre           : General;Movies;Sci-Fi/Fantasy;Fantasy
    WM/OriginalReleaseTime: 1976
    WM/MediaCredits : Doug McClure/Peter Cushing/Caroline Munro/Cy Grant/Godfrey
 James/Sean Lynch/Keith Barron/Helen Gill/Anthony Verner/Robert Gillespie/Michae
l Crane/Bobby Parr/Andee Cromarty;Kevin Connor;;
    service_provider: KOMODT2
    service_name    : KOMODT2 (KOMO-DT2)
    WM/MediaNetworkAffiliation: Independent
    WM/MediaOriginalChannel: 4
    WM/MediaOriginalChannelSubNumber: 2
    WM/MediaOriginalBroadcastDateTime: 0001-01-01T00:00:00Z
    WM/MediaIsStereo: false
    WM/MediaIsRepeat: false
    WM/MediaIsLive  : false
    WM/MediaIsTape  : false
    WM/MediaIsDelay : false
    WM/MediaIsSubtitled: false
    WM/MediaIsMovie : true
    WM/MediaIsPremiere: false
    WM/MediaIsFinale: false
    WM/MediaIsSAP   : false
    WM/MediaIsSport : false
    WM/ParentalRating: **+;PG;TV-PG
    WM/ParentalRatingReason: Adult Situations;Violence
    WM/Provider     : MediaCenterDefault
    WM/ProviderRating: **+
    WM/VideoClosedCaptioning: false
    WM/WMRVEncodeTime: 2011-04-21 21:59:03
    WM/WMRVServiceID: !MCService!214589384
    WM/WMRVRequestID: -1
    WM/WMRVScheduleItemID: -1
    WM/WMRVQuality  : 3
    WM/WMRVOriginalSoftPrePadding: 0
    WM/WMRVOriginalSoftPostPadding: 0
    WM/WMRVHardPrePadding: -300
    WM/WMRVHardPostPadding: 0
    WM/WMRVATSCContent: true
    WM/WMRVDTVContent: true
    WM/WMRVHDContent: false
    WM/MediaOriginalRunTime: 52689301334
    WM/MediaThumbWidth: 352
    WM/MediaThumbHeight: 234
    WM/MediaThumbStride: 1056
    WM/MediaThumbRet: 0
    WM/MediaThumbRatingSystem: 255
    WM/MediaThumbRatingLevel: 255
    WM/MediaThumbRatingAttributes: 0
    WM/MediaThumbAspectRatioX: 16
    WM/MediaThumbAspectRatioY: 9
    WM/MediaThumbTimeStamp: 4641301931177504108
    Duration        : 52689301334
    WM/WMRVEndTime  : 2011-04-21 23:26:52
    WM/WMRVBitrate  : 2.782972
    WM/WMRVKeepUntil: -1
    WM/WMRVActualSoftPrePadding: 300
    WM/WMRVActualSoftPostPadding: 0
    WM/WMRVContentProtected: false
    WM/WMRVContentProtectedPercent: 0
    WM/WMRVExpirationDate: 0004-01-*0 00:00:0/
    WM/WMRVExpirationSpan: 9223372036854775807
    WM/WMRVInBandRatingSystem: 255
    WM/WMRVInBandRatingLevel: 255
    WM/WMRVInBandRatingAttributes: 0
    WM/WMRVWatched  : true
  Duration: 01:27:48.73, start: 0.200000, bitrate: 2783 kb/s
    Stream #0:0[0x5]: Video: mpeg2video (Main), yuv420p, 720x480 [SAR 32:27 DAR
16:9], max. 2384 kb/s, 29.97 fps, 29.97 tbr, 10000k tbn, 59.94 tbc
    Stream #0:1[0x7]: Audio: ac3, 48000 Hz, stereo, fltp, 256 kb/s
E:\Recorded TV>
Return to User experiences
Users browsing this forum: No registered users and 77 guests
