High network usage in IDLE mode
dan_ru
Post Sun Dec 22, 2013 10:35 am
I discover high network usage in IDLE (DNLA client not active - TV shows regular tv signal) mode.
Environment:
1) Serviio 1.4.0 on Windows 7 x64
2) LG 47LM620T-ZE (latests firmware 04.51.07)
Steps to reproduce:
1) Start Serviio
2) Just switch on TV
[ImageExtractStrategy], [LibraryAdditionsCheckerThread], [LibraryManager], [LibraryUpdatesCheckerThread] and [MediaItemDAO_Impl] are cuted from serviio.log.
I also captured network dump (you can open it by wireshark) with filter "port 8895 || port 1900".
BR, Daniil
pc5dczc_net_dump.zip
(36.14 KiB) Downloaded 303 times
(254.53 KiB) Downloaded 400 times
derby.log
(1.17 KiB) Downloaded 409 times
Post Thu Jan 16, 2014 7:54 am
Re: High network usage in IDLE mode
Can you give me some pointers?
dan_ru
Post Thu Jan 16, 2014 8:49 am
I see strange behavior in dump file: frequently repeating of same messages between TV and Serviio. Just open (by wireshark http://www.wireshark.org) dump file and you will see it.
192.168.0.10 - PC with Serviio
192.168.0.11 - TV
dan_ru
Post Thu Jan 23, 2014 5:13 pm
Is it support forum ?
Post Thu Jan 23, 2014 10:19 pm
I don't see anything weird. There is some browsing activity (which includes downloading the thumbnails). Is that what you meant?
dan_ru
Post Fri Jan 24, 2014 7:05 am
Thanks for answer.
Problem is that this happens incessantly (without any delay and break). TV and Serviio can communicate in same manner long time (several hours). Is it TV problem ?
Post Fri Jan 24, 2014 3:48 pm
you can compare with the serviio.log, but it should sent the Browse requests only when you're actually browsing the contents on the TV
Users browsing this forum: Google [Bot] and 63 guests
