Old Panasonic TX P42G20 (2009) - which profile?
kexx
Post Fri Jan 24, 2014 3:15 pm
I use Panasonic TC P42G20 plasma from 2009 + Panasonic Viera (2010) serviio profile.
Usually it works, but does not work correctly when it shoudl play .mkv + srt subtitles - the final picture is in different format. Should be 16:9 but it squeses it to 4:3... Any advice what to do differently?
Btw. some mkv are refused with "unsupported file format"...
thanks for help
KeXX
Post Fri Jan 24, 2014 5:26 pm
Re: Old Panasonic TX P42G20 (2009) - which profile?
What if you replcase this in the profile
with
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" DAR="16:9">
kexx
Post Fri Jan 24, 2014 6:59 pm
Yes, it works much better now, thans!
