3D catagory or Filemarker
sharkbit
Post Sat Jan 25, 2014 7:00 pm
I would like to see a denotation for 3D movies in the DB / MediaBrowser.
I have many 3D Movies, and sometimes have the standard movie as well. It would be nice to easily see what 3D movies i have.
To help Searching for this topic: Stereoscopic, Three Dimensional, 3DSBS, 3DTB, 3DUD.
Samsung E6500 | ROKU 3 x2 | XBOX 360 | iPad
This Media Server Kicks Ars!
Post Sun Jan 26, 2014 9:06 am
Re: 3D catagory or Filemarker
can you post ffmpeg -i of some 3d files? I want to see if there is any indication thaht they are indeed 3d.
Post Sun Jan 26, 2014 4:47 pm
They are just normal files. Even TV cannot distinguish them. One must press 3D button to play them in 3D.
Here is ffmpeg and Mediainfo output.
C:\Users\John>ffmpeg -i "D:\Treasure Houses of Britain 3D S01E03.mkv"
ffmpeg version N-55020-g768e40b Copyright (c) 2000-2013 the FFmpeg developers
built on Jul 28 2013 18:01:30 with gcc 4.7.3 (GCC)
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av
isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
le-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetyp
e --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --ena
ble-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-l
ibopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libsp
eex --enable-libtheora --enable-libtwolame --enable-libvo-aacenc --enable-libvo-
amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --
enable-libxvid --enable-zlib
libavutil 52. 40.100 / 52. 40.100
libavcodec 55. 19.100 / 55. 19.100
libavformat 55. 12.102 / 55. 12.102
libavdevice 55. 3.100 / 55. 3.100
libavfilter 3. 81.103 / 3. 81.103
libswscale 2. 4.100 / 2. 4.100
libswresample 0. 17.103 / 0. 17.103
Input #0, matroska,webm, from 'D:\Azureus Active Downloads\3D Seeding\Treasure H
ouses of Britain 3D S01E03.mkv':
creation_time : 2011-03-05 11:20:15
Duration: 00:44:46.94, start: 0.000000, bitrate: 3692 kb/s
Stream #0:0: Video: h264 (High), yuv420p, 1920x1080, SAR 1:1 DAR 16:9, 25 fp
s, 25 tbr, 1k tbn, 50 tbc (default)
Stream #0:1(eng): Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s (clean effect
s)
Unique ID : 254810599379994489645566755150142967422 (0xBFB2BC816393F9CEA456E1DFBF790E7E)
Complete name : D:\Treasure Houses of Britain 3D S01E03.mkv
Format : Matroska
File size : 1.16 GiB
Duration : 44mn 46s
Overall bit rate : 3 692 Kbps
Encoded date : UTC 2011-03-05 11:20:15
Writing application : mkvmerge v4.3.0 ('Escape from the Island') built on Sep 5 2010 10:30:51
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 44mn 46s
Bit rate : 3 499 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.067
Stream size : 1.07 GiB (93%)
Writing library : x264 core 105 r1724 b02df7b
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=5 / psy=1 / psy_rd=0.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3499 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : ME (music and effects)
Codec ID : A_AC3
Duration : 44mn 46s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 61.5 MiB (5%)
Language : English
Post Sun Jan 26, 2014 8:01 pm
hmm. not much that can be done then.
Iveky
Post Sun Jan 26, 2014 8:23 pm
only common thing that can be used is: '3D' in title or better from metadata:
Input #0, matroska,webm, from 'Top.Gun.3D.mkv':
title : Top Gun 3D SBS [www.newpct.com][toni32]
creation_time : 2013-02-16 16:07:20
Duration: 01:51:03.68, start: 0.000000, bitrate: 12482 kb/s
Chapter #0.0: start 0.000000, end 166.291000
hervidero
Post Sun Jan 26, 2014 8:38 pm
So is it not possible to make Serviio look at the filename and remember some details before parsing it to ffmpeg or online sources?
For example: "Movie.mkv" gets listed as "Movie" and "Movie [3D].mkv" gets listed as "Movie [3D]" ?
I have posted a related question earlier: viewtopic.php?f=5&t=15764
spudy12
Post Sun Jan 26, 2014 10:40 pm
Only issue I can see with taking it from the title is for the film Piranha 3D and 3DD (Both crap films)
So would probably need to distinguish between that and a 3D film by having brackets around the 3D ie [3D]
Post Mon Jan 27, 2014 2:27 am
I have an idea as a workaround. My apologies if you're already using it :lol:
Enable the Folders option on the presentation panel, then make a single folders that contain only 3D videos. Not the most elegant way, but at least when you want specifically to choose something 3D, they're all in one place. Of course, they will be in the normal lists as well, without being noted as 3D. Like a said, just a workaround for the time being. :D
sharkbit
Post Mon Feb 10, 2014 4:19 pm
I have been using a Folder called 3D and trying to store all my 3D stuff in that, but they still show up in all the other menus.
I would like to see Serviio search the File name for something like (3DSBS | 3DTB | 3DUD) or maybe a configurable string.
Anyway i do most of the suggested stuff now anyway, just it gets a little complicate trying to enplane all that to the Wife n kids...
:D
Post Tue Feb 11, 2014 12:07 am
Perhaps someone may want to raise a bitbucket request for it (and others vote): https://bitbucket.org/xnejp03/serviio/issues/
My two cents: I think it may work if you had a marker in the filename - "3D", delimited by dots or spaces. It may then be possible for Serviio to:
  1. search the online sources excluding the "3D" from the search.
  2. append "3D" to the title returned by the online search
  3. possibly add an additional "3D" genre to that returned by the search
There is a flaw in the plan however: note there are movies in the TMDb database that already contain the phrase 3D or 3-D in the title so more thinking needs to be done on how to handle that. Of course, raising the issue doesn't mean it will get done in the short term - there are many competing priorities.
sharkbit
Post Sun Feb 23, 2014 12:55 am
I like the solution posted by DenyAll, and i added a comment to the Bitbucket page here: https://bitbucket.org/xnejp03/serviio/issue/569/add-support-of-mpo-3d-images
Post Thu Feb 27, 2014 7:44 am
OK, however the issue you commented against wasn't related to 3D video or how to add metadata specific to 3D movies. Illico's issue was related to 3D image files (.mpo).
Also, although I agree with the comment 'As for the movies with 3D in the title that arn't 3D... they suck.. so who cares' - its a personal taste thing so somebody, somewhere will care (and who knows, they may actually make a good 3-D movie one day....) :D
DukeUK
Post Fri Feb 28, 2014 7:38 pm
I have a solution.
Here is what i do.
I have a Folder named "Movies"
in it is a sub folder called "3D Movies"
Each time i add a 3D film to it i go off on the internet and find a 3D DVD Cover for that film.
Then i name the .jpg exactly the same as whatever my film is called.
Now when i click Movies category within Serviio, i have 2 films with the same name BUT the 3D one has a 3D cover :)
DukeUK
Post Fri Feb 28, 2014 7:52 pm
Like this :)
2 version of the new Thor film
Post Sun Mar 02, 2014 11:09 pm
DukeUK - a good workaround solution.
I have created a separate bitbucket issue for this at https://bitbucket.org/xnejp03/serviio/i ... -3d-movies and incorporated an idea from viewtopic.php?f=5&t=15477. Please note that I have only facilitated this - I do not have a particular requirement for this feature (having no devices that support 3D) so if you think it has merit you may want to vote on that site. As stated above, this doesn't mean it will get done in the short term - there are many competing priorities.
thingy
Post Mon Mar 31, 2014 6:18 pm
[matroska @ 00000000003DA1F0]Unknown entry 0x53B8
If it is muxed with side by side: left first (1; side_by_side_left... for the video stream with mkvmerge
There might be a range of unknown entries for this...
Or if the word 3D och (SBS eller OU), for side by side and over under respectively, is contained in the name.
symbols: 3dII or 3D= only small squares instead of lines. to mark sbs and ou.
But a 3d symbol on titles that have 3D in the path would be appreciated.
Return to Feature requests
Users browsing this forum: Baidu [Spider] and 7 guests
