PS4 Browser Compatibility
a_PS4_User
Post Tue Dec 31, 2013 8:59 pm
First of all, I love Serviio. It is hands down the best DLNA server around. Imagine my devastation when I turned on my new PlayStation 4 to find Sony had disabled DLNA playback abilities. I immediately thought of using the browser based web app to try and load my videos. No go. The PS4 browser does not have a Flash player capable of working with Serviio. The Browser does work with videos on some sites though so I was hoping there may be a way to add a feature into Serviio that would allow the PS4 browser to play the content through the web browser app. I think it can handle html5... (a user elsewhere posted this about the PS4 browser detailing it's capabilities: http://coding.vdhdesign.co.nz/?p=351 )
In short, please enhance your software to allow the crippled PS4 browser to load videos through the Serviio web browser app.
Thanks!!!!!!
btw, with no alternative to view streaming content on the PS4, adding this ability would be a great advertising feature to boost sales. I would personally create blog posts detailing instructions to "Finally stream your content to your PS4" using Serviio.
Xmantium
Post Tue Dec 31, 2013 10:28 pm
Re: PS4 Browser Compatibility
So what happens when you tried to use Serviio v1.4 MediaBrowser?
http://serviio.org/component/content/ar ... diabrowser
v1.4 is compatible with HTML5 standards as far as i know
Post Wed Jan 01, 2014 11:30 am
it only turns on HTML5 mode for iOS and WP user agents.
bofty
Post Tue Jan 28, 2014 7:44 pm
Is there any chance this will change any time soon? I've got both a Wii-U and a PS4 neither work with flash.
Would it be possible to create a HTML5 renderer profile that we could assign to devices (I know it's probably not that simple), or simply tag a device as an IOS device to fool the media browser somehow (if possible).
PS. Sorry for dragging this up again. I couldn't find anyone asking about PS4's/HMTL5 recently
spudy12
Post Tue Jan 28, 2014 9:33 pm
Surely you could just detect the user agent like you do for ios devices and then present it with the html5 version?
User agent is supposedly like this:
Useragentstring example:
Mozilla/5.0 (PlayStation 4 1.000) AppleWebKit/536.26 (KHTML, like Gecko)
Mozilla/5.0 (PlayStation 4 1.52) AppleWebKit/536.26 (KHTML, like Gecko)
Post Tue Jan 28, 2014 10:14 pm
The HTML5 video player must support Apple HLS format, otherwise any transcoded video will not play anyway. If it doesn't, you could only play MP4 files using the Original quality setting.
spudy12
Post Wed Jan 29, 2014 12:09 am
I might be wrong with this but I read somewhere that it did support HLS
Youtube works and that falls back to the HTML5 version which uses HLS I think (from what I read, as I said I might be wrong)
Don't know if these links are of any use
http://html5test.com/compare/browser/playstation4.html
Post Wed Jan 29, 2014 9:31 am
Try to display this page. I didn't try it on iPad, but there it should play.
http://demos.flowplayer.org/videotest/hls.html
bofty
Post Wed Jan 29, 2014 9:05 pm
That works fine on the Wii-U. Not able to test the playstation atm.
Thanks for taking the time to look into this guys
spudy12
Post Wed Jan 29, 2014 11:07 pm
zip wrote:Try to display this page. I didn't try it on iPad, but there it should play.
will try and test on a ps4 tomorrow
spudy12
Post Thu Jan 30, 2014 10:37 pm
Can confirm the link works fine on the PS4 browser.
Post Fri Jan 31, 2014 12:40 am
Will try to add it for 1.4.1, please test in the beta
spudy12
Post Fri Jan 31, 2014 12:42 am
zip wrote:Will try to add it for 1.4.1, please test in the beta
Great news! Will do.
Thanks Zip
EDIT: RE the Wii, as far as I can tell although it will play html5, detecting it could be an issue.
It appears to use the opera browser and only give an opera User agent string so no easy way to detect it. However I did find this for the wii u which suggests it has this user agent
User Agent: Mozilla/5.0 (Nintendo WiiU) AppleWebKit/534.52 (KHTML, like Gecko) NX/2.1.0.8.21 NintendoBrowser/1.0.0.7494.US/
I will capture some packets and test further when I get some time
bofty
Post Sat Feb 01, 2014 1:01 am
You guys are awesome! Thanks for all the work you've put into this
bofty
Post Tue Feb 04, 2014 6:27 pm
Is there somewhere I can download the beta and test this out?
spudy12
Post Tue Feb 04, 2014 7:02 pm
No new beta out yet.
Message Zip about becoming a beta tester if you want to help test new versions when they are released
bofty
Post Fri Mar 14, 2014 7:59 pm
Just wanted to say that with the new update (1.4.1) this is now working flawlessly on the Wii U!
Post Fri Mar 14, 2014 8:53 pm
bofty wrote:Just wanted to say that with the new update (1.4.1) this is now working flawlessly on the Wii U!
Niiice.
Anyone can confirm the PS4?
Barbutus
Post Sat Mar 15, 2014 3:25 pm
on my PS4 now I see the mediabrowser, Do I login by entering the password, I see the list of files correctly. But I can not start playback
p.s course I enabled transcoding
spudy12
Post Sat Mar 15, 2014 3:40 pm
Barbutus wrote:on my PS4 now I see the mediabrowser, Do I login by entering the password, I see the list of files correctly. But I can not start playback
Does this mean its working now?
Not had a chance to test this yet
Return to Feature requests
