Sony Bravia play MP4 files
GTUKie
Post Sat Jun 08, 2013 5:16 pm
My Sony Bravia TV is unable to play MP4 files, even though the forum suggests that it should be able to.
I am using the profile Sony Bravia TV (US) 2012 do I need to edit the profile to enable playback??
The same file plays without issue in another room via my Sony Bluray which uses profile Sony BDP-Sx90(2012)
here are the details of one of the files:
C:\Windows\system32>cd "C:\Program Files\Serviio\lib
C:\Program Files\Serviio\lib>ffmpeg.exe -i "T:\TV\Top Gear\Season 19\S19x07.mp4"
ffmpeg version 1.1.1 Copyright (c) 2000-2013 the FFmpeg developers
built on Feb 5 2013 21:59:54 with gcc 4.7.2 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --extra-libs='-lrtmp -l
polarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-
runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-
mingw32- --pkg-config=pkg-config
libavutil 52. 13.100 / 52. 13.100
libavcodec 54. 86.100 / 54. 86.100
libavformat 54. 59.106 / 54. 59.106
libavdevice 54. 3.102 / 54. 3.102
libavfilter 3. 32.100 / 3. 32.100
libswscale 2. 1.103 / 2. 1.103
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'T:\TV\Top Gear\Season 19\S19x07.mp4':
major_brand : isom
minor_version : 512
compatible_brands: isomiso2avc1mp41
encoder : Larry Sanders
Duration: 00:57:46.92, start: 0.000000, bitrate: 1784 kb/s
Stream #0:0(eng): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 720x404,
1650 kb/s, 25 fps, 25 tbr, 20k tbn, 50 tbc
handler_name : VideoHandler
Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 12
6 kb/s
handler_name : SoundHandler
Sony Bravia KDL-55EX645
Sony BDVE190
Serviio 1.4.1.2
Windows 8.1 Pro 64bit
Post Sat Jun 08, 2013 5:58 pm
Re: Sony Bravia play MP4 files
Don't know what is the problem with your EX645 model and this mp4 file...
Something with resolution not standard (720x404) ?
You can try to create a custom profile for this particular file, by adding following just before the last </Profiles> element of .serviio/config/profiles.xml
save, restart serviio service or reboot PC, then manually select this new profile on console.
   <Profile id="custom" name="Sony Bravia TV with h264" extendsProfileId="sony2012">
      <OnlineTranscoding>
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" forceVTranscoding="true" maxVBitrate="17000" targetACodec="ac3" aBitrate="384" forceInheritance="true">
      </OnlineTranscoding>
GTUKie
Post Sat Jun 08, 2013 7:23 pm
Thank you for the suggestion. I updated the xml and rebooted PC. Then switched to the new profile.
I still cannot play 6 of the 7 files in the folder (all mp4) but one file does play.
Here are the details of the one file that I can play (on the Sony Bravia) in the hope it gives a clue to what is causing the problem.
C:\Program Files\Serviio\lib>ffmpeg.exe -i "T:\TV\Top Gear\Season 19\S19x05.mp4"
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'T:\TV\Top Gear\Season 19\S19x05.mp4':
major_brand : isom
minor_version : 1
compatible_brands: isomavc1
creation_time : 2013-02-23 21:59:47
Duration: 01:01:49.99, start: 0.000000, bitrate: 1294 kb/s
Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 720x406,
1164 kb/s, 25 fps, 25 tbr, 25k tbn, 50 tbc
5 kb/s
creation_time : 2013-02-23 21:59:49
handler_name : GPAC ISO Audio Handler
Sony BDVE190
Serviio 1.4.1.2
Post Sat Jun 08, 2013 7:42 pm
GTUKie wrote:Thank you for the suggestion. I updated the xml and rebooted PC. Then switched to the new profile.
Can't see any revelent difference between these two files...
But I'm suprised that mp4 file cannot play with the new custom profile.
Could enable detailed logging, and check the log to find the ffmpeg command line used to transcode these files ?
GTUKie
Post Sat Jun 08, 2013 8:25 pm
OK, I switched on DEBUG and I have attached the zipped up log file created when playing the mp4 file that does play.
Hope thats the one you wanted??
serviio.zip
(430.47 KiB) Downloaded 684 times
Sony BDVE190
Serviio 1.4.1.2
Post Sun Jun 09, 2013 8:34 am
OK, could retry with this :
   <Profile id="custom" name="Sony Bravia TV with mp4/h264" extendsProfileId="sony2012">
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" forceVTranscoding="true" maxVBitrate="17000" targetACodec="ac3" aBitrate="384">
GTUKie
Post Sun Jun 09, 2013 9:00 pm
You are great! I really appreciate your assistance.
Just in case others are having similar problems, the profile update fixed the .MP4 issue but broke my .avi files :(
So I added the new profile as this:
     <!-- 2012 models for US (without avi/divx)
             - Still images: JPEG, MPO
             - Music: MP3, linear PCM, WMA, MP4
             - Video: AVCHD, MPEG2, MPEG1, MP4 (AVC), MP4 (MPEG4), WMV -->
         <!-- Transcode DivX, AVI -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="384" forceInheritance="true">
            <Matches container="avi" vCodec="mpeg4" />
            <Matches container="avi" vCodec="msmpeg4" />
Now have both .avi and .mp4 files palying happily on my Sony Bravia :D
Thank you so much!!!
Sony BDVE190
Serviio 1.4.1.2
Post Mon Jun 10, 2013 9:54 am
GTUKie wrote:Now have both .avi and .mp4 files palying happily on my Sony Bravia :D
OK, nice, but it's a workaround...
Could you provide MediaInfo tool result for these two mp4 file (worked and failed)?
Seems similar to this : viewtopic.php?f=7&t=10692
GTUKie
Post Sun Dec 22, 2013 9:45 pm
Hi Illico,
Sorry I never replied previously as I didn't see your post.
I came back to see what I did to the profile in the past as I just installed Serviio 1.4 and find myself back in the same postion!
I will make my same old amendments but thought I would upload the MediaInfo information anyway as it may help others too.
DoesNotPlay.txt
(3.17 KiB) Downloaded 754 times
DoesPlay.txt
(3.56 KiB) Downloaded 785 times
Sony BDVE190
Serviio 1.4.1.2
subelman
Post Wed Jan 29, 2014 7:20 am
I was having the same problem using Serviio 1.4 and a Sony Bravia TV. Some MP4s would play, others would not play at all, and at least one would 'crash' the TV so the only way to recover was to 'reboot' the TV by unplugging its power cord. Using the suggested profile I can now view all the MP4s.
However, some of my MP4s also contain subtitles (closed captions) which I used to be able to switch on or off using the CC button on the TV's remote control. With the new custom profile I cannot get the Close Captions at all. Is there any way to add this capability to the Custom profile?
Thanks in advance.
Post Wed Jan 29, 2014 11:27 am
subelman wrote:However, some of my MP4s also contain subtitles (closed captions) which I used to be able to switch on or off using the CC button on the TV's remote control. With the new custom profile I cannot get the Close Captions at all. Is there any way to add this capability to the Custom profile?.
Close Captions could not be extracted from mp4 files (does from MKV) with serviio/ffmpeg : http://www.serviio.org/index.php?option ... icle&id=33
Could you provide MediaInfo tool result (in text format) of your mp4 file ?
subelman
Post Fri Jan 31, 2014 6:35 am
I have attached the MediaInfo output of an MP4. As you can see it has two audio streams (english soundtrack and director's commentary) and subtitles. I have three TV sets: A Sony Bravia, a Samsung and a Vizio, all purchased within the last 6 months. Here are the results:
Sony TV using the custom 'Sony Bravia TV with mp4/h264' profile: Will show video with english soundtrack. Cannot switch to second soundtrack or enable subtitles. Works the same with all my MP4s.
Sony TV using 'Sony Bravia TV (2012) - US' profile: Will show video with english soundtrack, and allows turning subtitles on and off. Cannot switch to second soundtrack, and will hang on some other MP4s, requiring power cycling.
Samsung TV using 'Samsung TV/player (E/F-series)' profile: Will show video with english soundtrack. Allows switching back and forth between the two soundtracks, but will not display subtitles on any MP4.
Vizio TV using 'Vizio TV' profile: Will show video with english soundtrack. Cannot switch to the second soundtrack or enable the subtitles in any of my MP4s.
Any suggestions are much appreciated.
MP4_report.txt
(5.67 KiB) Downloaded 740 times
wildchild55719
Post Wed Feb 12, 2014 4:24 am
mp4's not playing on my sony internet tv and sony av/brp ? it says file is corrupt . but i can play it on the sever (VLC)
ubuntu server 8.10
serviio 1.4
Jeremy R.Erspamer
ubuntu desktop 16.04
serviio pro
Sony Internet tv nsxgt1
serviio GO
sony srt5800es2
samsung un55es7500f
ps3 ps4
sony vdv-n790w
PS3
4 Iphone's "vlc"
3 Ipad's "vlc"
Users browsing this forum: Baidu [Spider] and 3 guests
