Some playlists not showing up
numpdog
Post Thu Jan 30, 2014 12:39 am
I have 25 playlists, but only 12 of them are displayed on either the Media Browser or my Samsung TV. They are all .wpl files with the same format. Any ideas?
Iveky
Post Thu Jan 30, 2014 8:02 am
Re: Some playlists not showing up
not playable contents?
numpdog
Post Thu Jan 30, 2014 1:10 pm
They play fine in Windows Media Player
Post Thu Jan 30, 2014 1:34 pm
can you attach one of those that don't work?
numpdog
Post Thu Jan 30, 2014 2:21 pm
I just did a force refresh in Serviio console and the attached is still not showing up in the playlists. Had to do it as a .zip file since the BB complained that the .wpl could be an attack.
Ireland.zip
(3.18 KiB) Downloaded 361 times
numpdog
Post Thu Jan 30, 2014 2:30 pm
I tried saving the playlist as a .m3u playlist, then did another force refresh. Now it shows up. Is there a problem using .wpl playlists?
numpdog
Post Thu Jan 30, 2014 3:31 pm
Good news! To force an overwrite, I did a "save playlist AS" in WMP to the existing .wpl file for each playlist that was missing and now all the playlists show up via Serviio. I hope this helps anybody who might be having the same problem.
Still would like to know what it didn't like about the original .wpl files :?:
Iveky
Post Thu Jan 30, 2014 3:50 pm
compare for differences or post new one and we will compare
numpdog
Post Thu Jan 30, 2014 3:56 pm
I did the compare. The GUID metatag was in the bad .wpl, but I tried removing that line and it still didn't work.
Post Thu Jan 30, 2014 6:59 pm
The original file was saved with unsupported BOM bytes at the beginning of the file. I have now fixed that for 1.4.1.
numpdog
Post Thu Jan 30, 2014 7:39 pm
I see that now that I ran a 'dump' of the file. I wonder where that came from.
Thanks for the follow-up!
