KDLNX800 video streaming breaks up
ajay
Post Thu Feb 03, 2011 5:52 pm
Wireless streaming HD video files from PC to Sony TV breaks up. Streaming Audio files works fine. Is there a fix for this please ?
Post Thu Feb 03, 2011 5:53 pm
Re: KDLNX800 video streaming breaks up
ajay wrote:Wireless streaming HD video files from PC to Sony TV breaks up. Streaming Audio files works fine. Is there a fix for this please ?
more inforamtion is required please.
ajay
Post Thu Feb 03, 2011 10:57 pm
PC: Pentium 4 cpu 2.53 GHz. 2GB RAM
OS: MS-XP with service pack 3
Media server installed on my PC is streaming wirelessly to the TV.
iso files in DVD format stream without any issues to my SONY TV but HD video file in mkv are jerky
Post Thu Feb 03, 2011 11:03 pm
That is expected considering you're connecting wirelessly.
Post Thu Feb 03, 2011 11:06 pm
zip wrote:That is expected considering you're connecting wirelessly.
Beat me to that comment Zip lololol
ajay
Post Fri Feb 04, 2011 2:26 pm
just wanted to load my arsenal with viable options before I spend time over the weekend to look into it. don't know if its possible to disable live feeds to the TV to make way for extra bandwidth. Secondly, my router is configured for hybrid G and N. I's wondering if switching to N might help.
Post Fri Feb 04, 2011 2:42 pm
ajay wrote:just wanted to load my arsenal with viable options before I spend time over the weekend to look into it. don't know if its possible to disable live feeds to the TV to make way for extra bandwidth. Secondly, my router is configured for hybrid G and N. I's wondering if switching to N might help.
neither would make any difference
1) live feeds only active when ur using them and when ur not they sit inactive.
2) wireless type is select automaticly and the best support type is used.
3) Best way to improve things is to connect all deviced wired to the network.
