Exposure of Serving Status via API
Post Fri Jan 31, 2014 3:33 am
Hi zip,
In other posts (eg. viewtopic.php?f=8&t=10752&p=72157&hilit=internal#p72157) you have alluded to the fact that Serviio keeps an internal register of it's [transcoding] jobs. Does this also include other streaming activities (not just transcoding, such as streaming, browsing, etc).
If so, would it be possible to expose this via the API? Ideally if on a per renderer basis, this could be exposed via the rest/status command perhaps by expanding the <STATUS> field (currently either "ACTIVE", "INACTIVE" or "UNKNOWN" - which is almost always "UNKNOWN" for me for some reason) by adding additional states (eg. "BROWSING", "SERVING NATIVE", "SERVING TRANSCODED", "SERVING NATIVE (CDS)", "SERVING TRANSCODED (CDS)" for example.. if possible you could also add the filename in the SERVING categories :) ).
Do you think this is worth pursuing? If so, I can raise a bitbucket. Would it be reliable? (eg. would Serviio detect that SERVING has stopped, even if the user simply turns their device off?)
The reason for this request is I have an app (viewtopic.php?f=17&t=12136) that infers streaming status by monitoring TCP sessions. This method is OK 99% of the time but sometimes TCP sessions don't get closed properly, or conversely (especially for CDS access) don't stay open long enough to be detected. While this method is OK in the absence of anything better, the ultimate method of detecting streaming sessions would be to get it "from the horse's mouth" by simply querying the Serviio server.
ps. havent posted to the Features Request as this is Developer specific.
Post Fri Jan 31, 2014 12:54 pm
Re: Exposure of Serving Status via API
It's a big task and am not planning on adding it for now.
