Samsung E5500W
dsig111
Post Sun Feb 02, 2014 8:09 am
Samsung E5500W
So I was using miniDLNA for a while on my ubuntu media server however I recently downloaded some shows that the audio wouldn't play due to being flac encoded. I switched to serviio and set everything up, however it still doesn't work. If I enable transcoding the videos won't play at all, it gives "the file selected is not supported" If I turn transcoding off it does like miniDLNA and plays the video but gives "Flac is not supported" error at the start and the video will have no audio. I am using the "Samsung TV / Player (E/F-series) profile.
ffmpeg -i
ffmpeg version 0.8.9-6:0.8.9-0ubuntu0.13.10.1, Copyright (c) 2000-2013 the Libav developers
  built on Nov  9 2013 19:09:46 with gcc 4.8.1
[matroska,webm @ 0x20ab400] Estimating duration from bitrate, this may be inaccurate
Input #0, matroska,webm, from '/shared/TV/Lost Girl/Season 03/S03E01 - Caged Fae.mkv':
  Duration: 00:44:07.02, start: 0.000000, bitrate: N/A
    Stream #0.0(eng): Video: h264 (High), yuv420p, 1280x720 [PAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0.1(eng): Audio: flac, 96000 Hz, 6 channels, s16 (default)
log
2014-02-02 00:45:03,702 WARN  [ProcessExecutor] Process ffmpeg has a return code        of 1! This is a possible error. Detailed output follows.
Expected number for threads but found: auto
2014-02-02 00:45:13,439 ERROR [ResourceTransportRequestHandler] Error while proc        essing resource, sending back 500 error. Message: Transcoded file '/tmp/Serviio/        transcoding-temp-591-sam_ef-ORIGINAL.stf' cannot be found, FFmpeg execution prob        ably failed
java.io.IOException: Transcoded file '/tmp/Serviio/transcoding-temp-591-sam_ef-O        RIGINAL.stf' cannot be found, FFmpeg execution probably failed
        at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryS        trategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:47)
        at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEn        gine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:134)
        at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(Abstract        DeliveryEngine.java:110)
        at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(        MediaResourceRetrievalStrategy.java:153)
        at org.serviio.delivery.GETMethodProcessor.retrieveResource(GETMethodPro        cessor.java:121)
        at org.serviio.delivery.GETMethodProcessor.buildDeliveryContainer(GETMet        hodProcessor.java:48)
        at org.serviio.delivery.AbstractMethodProcessor.handleRequest(AbstractMe        thodProcessor.java:100)
        at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(Resourc        eDeliveryProcessor.java:81)
        at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequ        est(ResourceTransportRequestHandler.java:86)
        at org.serviio.upnp.webserver.AbstractRequestHandler.handle(AbstractRequ        estHandler.java:61)
        at org.serviio.upnp.webserver.ServiioHttpService.doService(ServiioHttpSe        rvice.java:77)
        at org.apache.http.protocol.HttpService.handleRequest(HttpService.java:2        12)
        at org.serviio.upnp.webserver.WebServer$WorkerThread.run(WebServer.java:        192)
Post Tue Feb 04, 2014 8:21 pm
Re: Samsung E5500W
If you searched a bit or read info on the download page, you'd know that your ffmpeg is too old and you have to compile a new one, preferably from the sources provided on the download page.
dsig111
Post Wed Feb 05, 2014 11:21 am
Re: Samsung E5500W
zip wrote:If you searched a bit or read info on the download page, you'd know that your ffmpeg is too old and you have to compile a new one, preferably from the sources provided on the download page.
I searched quite a bit, and the download page claims the packages come with the install. Either way I compiled from source ffmpeg and the dependencies identified in the wiki. Guess what... still doesn't work. Now not only does it say file selected is not supported it also disconnects immediately afterwards.
new log:
2014-02-05 04:14:06,679 WARN  [ProcessExecutor] Process ffmpeg has a return code        of 1! This is a possible error. Detailed output follows.
Stream #0:1(eng): Audio: ac3, 96000 Hz, 5.1, fltp, 192 kb/s (default)
Stream mapping:
Stream #0:0 -> #0:0 (copy)
Stream #0:1 -> #0:1 (flac -> ac3)
Error while opening encoder for output stream #0:1 - maybe incorrect parameters        such as bit_rate, rate, width or height
2014-02-05 04:14:16,623 ERROR [ResourceTransportRequestHandler] Error while proc        essing resource, sending back 500 error. Message: FFmpeg execution failed
        at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryS        trategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:49)
new ffmpeg:
ffmpeg version 1.1.git Copyright (c) 2000-2013 the FFmpeg developers
  built on Feb  5 2014 03:10:18 with gcc 4.8 (Ubuntu/Linaro 4.8.1-10ubuntu9)
  configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-librtmp --enable-libxvid --enable-libass
    creation_time   : 2013-11-05 05:55:17
  Duration: 00:44:07.02, start: 0.000000, bitrate: 7081 kb/s
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0:1(eng): Audio: flac, 96000 Hz, 5.1(side), s16 (default)
Post Mon Feb 10, 2014 10:09 pm
Re: Samsung E5500W
Perhaps Serviio doesn't pick your newly compiled ffmpeg from the path. Try to pass ffmpeg.location property in the start script.
http://www.serviio.org/index.php?option ... icle&id=43
http://www.serviio.org/index.php?option ... e&id=21#q3
dsig111
Post Sun Feb 16, 2014 4:15 am
Re: Samsung E5500W
Made sure serviio was pointed to ffmpeg and its still not working, the log looks the same as before.
2014-02-15 21:10:31,666 WARN  [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
Stream mapping:
2014-02-15 21:10:41,636 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
        at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:49)
        at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:134)
        at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:110)
        at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:153)
        at org.serviio.delivery.GETMethodProcessor.retrieveResource(GETMethodProcessor.java:121)
        at org.serviio.delivery.GETMethodProcessor.buildDeliveryContainer(GETMethodProcessor.java:48)
        at org.serviio.delivery.AbstractMethodProcessor.handleRequest(AbstractMethodProcessor.java:100)
        at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:81)
        at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:86)
        at org.serviio.upnp.webserver.ServiioHttpService.doService(ServiioHttpService.java:77)
Post Sun Feb 16, 2014 6:07 pm
Re: Samsung E5500W
can you enable detailed logging, try to reproduce the error and then post the ffmpeg command used for the transcode job?
dsig111
Post Sat Mar 15, 2014 6:30 am
Re: Samsung E5500W
With this issue still continuing, and another issue of Serviio not finding media that even miniDNLA could find, I am uninstalling serviio from my linux machine and going to find an alternative.
