serviio is not starting
BSTF
Post Sun Feb 02, 2014 3:44 pm
hello,
the server is not starting in the attach is the message that i'm given.
thx
Acidburn003
Post Wed Feb 12, 2014 1:33 am
Re: serviio is not starting
Install latest java
Using Tapatalk
subdla
Post Wed Feb 12, 2014 6:44 am
I have the same problem. I have Java 7-51 installed. I selected the option of not installing Java 6 during Serviio installation. I have a Windows 7 64 bit Pro installation. I suspect that I need to point to System32-WOW to find the 64 bit Java equivalent. I do not understand the message "Please define EXE4J_Java_Home to point to an installed 64-bit-JDK ". How do I do that? I read the release notes. It indicates the problem with the 64 bit Windows and Java had been solved. I can try removing Java and Serviio and letting it install Java 6, but I suspect it still will not be able to find Java. I have this problem on two Windows 7 machines. My Windows XP 32 bit machine worked just fine, and did not install or need Java 6 - It accepted that I had Java 7.
subdla
Post Thu Feb 13, 2014 2:14 am
I checked the Java site, and it says you can have both 32 bit and 64 bit Java installed. So, I downloaded and installed the V7-51 64 bit Java. I now have both installed. Serviio now starts. I will start learning how to use it.
Return to General discussion
