Cannot Playback .ts file from Mac to Sony Bravia
Moisie
Post Thu Feb 03, 2011 11:14 pm
Hello all:
I've recently started experimenting with Serviio - and I'm very impressed so far! Thanks to all those who have made it possible.
I'm running Serviio 0.5 on Mac OS X 10.6.6 into a Sony Bravia KDL-32EX403 via a wired home router connection; so far, the Bravia sees Serviio, and I appear to be able to play back H.264 / AAC files onto the Bravia successfully.
I was also hoping to play back some .ts files, saved from my Humax PVR-9200 DVB PVR machine; although the Bravia recognises the files (and displays an 'MPEG2' badge next to them), attempting to play them back results in a black screen and no audio output.
Please can you help me set this up?
Here is the result of ffmpeg for a sample file:
  built on Jan 12 2011 19:51:48 with gcc 4.0.1 (Apple Inc. build 5493)
  configuration: --enable-static --disable-shared --bindir=/tmp/ffmpeg --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-pthreads --disable-mmx --extra-ldflags=-L/tmp/static/lib --extra-cflags=-I/tmp/static/include
  libavutil     50.36. 0 / 50.36. 0
  libavcore      0.16. 0 /  0.16. 0
  libavcodec    52.108. 0 / 52.108. 0
  libavformat   52.92. 0 / 52.92. 0
  libavdevice   52. 2. 3 / 52. 2. 3
  libavfilter    1.72. 0 /  1.72. 0
  libswscale     0.12. 0 /  0.12. 0
[mpeg2video @ 0x102ca00] mpeg_decode_postinit() failure
    Last message repeated 1 times
[mpegts @ 0x1009600] max_analyze_duration reached
[NULL @ 0x1030200] start time is not set in av_estimate_timings_from_pts
[NULL @ 0x1033a00] start time is not set in av_estimate_timings_from_pts
[NULL @ 0x1035600] start time is not set in av_estimate_timings_from_pts
[NULL @ 0x1037200] start time is not set in av_estimate_timings_from_pts
[NULL @ 0x1038e00] start time is not set in av_estimate_timings_from_pts
[NULL @ 0x103aa00] start time is not set in av_estimate_timings_from_pts
[NULL @ 0x103c600] start time is not set in av_estimate_timings_from_pts
[NULL @ 0x103e200] start time is not set in av_estimate_timings_from_pts
Input #0, mpegts, from '/Volumes/500GB FreeAgent HD/Humax/009_2010Dec04_2211_QI_XL.ts':
  Duration: 00:45:12.18, start: 66579.257456, bitrate: 3240 kb/s
  Program 4671
  Program 4479
  Program 4415
  Program 4351
  Program 4228
    Stream #0.0[0x262]: Video: mpeg2video, yuv420p, 720x576 [PAR 64:45 DAR 16:9], 15000 kb/s, 25 fps, 25 tbr, 90k tbn, 50 tbc
    Stream #0.1[0x263](eng): Audio: mp2, 48000 Hz, 2 channels, s16, 256 kb/s
    Stream #0.2[0x264](eng): Audio: mp3, 0 channels, s16
    Stream #0.3[0x267](eng): Subtitle: dvbsub
    Stream #0.4[0x26b]: Data: [5][0][0][0] / 0x0005
    Stream #0.5[0x28a]: Data: [11][0][0][0] / 0x000B
    Stream #0.6[0x28b]: Data: [11][0][0][0] / 0x000B
    Stream #0.7[0x28c]: Data: [11][0][0][0] / 0x000B
    Stream #0.8[0x3f0]: Data: [11][0][0][0] / 0x000B
    Stream #0.9[0x3f1]: Data: [11][0][0][0] / 0x000B
    Stream #0.10[0x3f2]: Data: [11][0][0][0] / 0x000B
  Program 4164
And here's the output from the DEBUG log:
2011-02-03 23:07:33,401 DEBUG [WebServer] Incoming connection from /192.168.1.11:53207
2011-02-03 23:07:33,401 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.11:
2011-02-03 23:07:33,402 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2011-02-03 23:07:33,409 DEBUG [ContentDirectory] Browse() called for profile Sony Bravia TV with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2011-02-03 23:07:33,409 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-03 23:07:33,414 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-03 23:07:35,396 DEBUG [WebServer] Incoming connection from /192.168.1.11:53208
2011-02-03 23:07:35,397 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.11:
2011-02-03 23:07:35,397 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2011-02-03 23:07:35,414 DEBUG [ContentDirectory] Browse() called for profile Sony Bravia TV with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2011-02-03 23:07:35,414 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-03 23:07:35,423 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-03 23:07:37,609 DEBUG [WebServer] Incoming connection from /192.168.1.11:53209
2011-02-03 23:07:37,616 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.11:
2011-02-03 23:07:37,617 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2011-02-03 23:07:37,621 DEBUG [ContentDirectory] Browse() called for profile Sony Bravia TV with parameters: objectID = V_F, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2011-02-03 23:07:37,621 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-03 23:07:37,624 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-03 23:07:38,873 DEBUG [WebServer] Incoming connection from /192.168.1.11:53210
2011-02-03 23:07:38,874 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.11:
2011-02-03 23:07:38,874 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2011-02-03 23:07:38,879 DEBUG [ContentDirectory] Browse() called for profile Sony Bravia TV with parameters: objectID = V_F#FOL_R2, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2011-02-03 23:07:38,879 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-03 23:07:38,918 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-03 23:07:39,077 DEBUG [WebServer] Incoming connection from /192.168.1.11:53211
2011-02-03 23:07:39,079 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.11:
2011-02-03 23:07:39,079 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2011-02-03 23:07:39,084 DEBUG [ContentDirectory] Browse() called for profile Sony Bravia TV with parameters: objectID = V_F#FOL_R2, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 10, count = 10, sortCriteria =
2011-02-03 23:07:39,084 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-03 23:07:39,108 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-03 23:07:48,269 DEBUG [WebServer] Incoming connection from /192.168.1.11:53212
2011-02-03 23:07:48,270 DEBUG [ResourceTransportRequestHandler] HEAD /resource/210/MEDIA_ITEM/MPEG_TS_SD_NA_ISO HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-32EX403";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-32EX403"; mv="1.7";,Host: 192.168.1.10:8895]]
2011-02-03 23:07:48,270 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2011-02-03 23:07:48,271 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.11, Profile=Sony Bravia TV'
2011-02-03 23:07:48,271 DEBUG [ResourceTransportRequestHandler] Request for resource 210 and type 'MEDIA_ITEM' received
2011-02-03 23:07:48,271 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 210)
2011-02-03 23:07:48,272 DEBUG [VideoDAOImpl] Reading a Video (id = 210)
2011-02-03 23:07:48,273 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 210, format MPEG_TS_SD_NA_ISO and profile Sony Bravia TV
2011-02-03 23:07:48,273 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-02-03 23:07:48,273 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 1098573824,Date: Thu, 03 Feb 2011 23:07:48 GMT,Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/0.5,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-02-03 23:07:48,290 DEBUG [WebServer] Incoming connection from /192.168.1.11:53213
2011-02-03 23:07:48,290 DEBUG [ResourceTransportRequestHandler] GET /resource/210/MEDIA_ITEM/MPEG_TS_SD_NA_ISO HTTP/1.1, headers = [Range: bytes=0-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-32EX403";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-32EX403"; mv="1.7";,Host: 192.168.1.10:8895]]
2011-02-03 23:07:48,291 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2011-02-03 23:07:48,291 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.11, Profile=Sony Bravia TV'
2011-02-03 23:07:48,292 DEBUG [ResourceTransportRequestHandler] Request for resource 210 and type 'MEDIA_ITEM' received
2011-02-03 23:07:48,292 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 210)
2011-02-03 23:07:48,292 DEBUG [VideoDAOImpl] Reading a Video (id = 210)
2011-02-03 23:07:48,293 DEBUG [VideoDeliveryEngine] Delivering item '210' for client 'IPAddress=/192.168.1.11, Profile=Sony Bravia TV'
2011-02-03 23:07:48,293 DEBUG [VideoDeliveryEngine] Delivering file '009_2010Dec04_2211_QI_XL.ts' in native format
2011-02-03 23:07:48,294 DEBUG [MediaItemDAOImpl] Getting file of media item 210
2011-02-03 23:07:48,295 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 210) as read
2011-02-03 23:07:48,299 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-02-03 23:07:48,299 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1098573824
2011-02-03 23:07:48,300 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-02-03 23:07:48,300 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Range: bytes 0-1098573823/1098573824,Content-Length: 1098573824,Date: Thu, 03 Feb 2011 23:07:48 GMT,Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/0.5,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-02-03 23:07:51,500 DEBUG [WebServer] I/O error: Broken pipe
2011-02-03 23:07:51,504 DEBUG [WebServer] Incoming connection from /192.168.1.11:53214
2011-02-03 23:07:51,504 DEBUG [ResourceTransportRequestHandler] GET /resource/210/MEDIA_ITEM/MPEG_TS_SD_NA_ISO HTTP/1.1, headers = [Range: bytes=38453056-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-32EX403";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-32EX403"; mv="1.7";,Host: 192.168.1.10:8895]]
2011-02-03 23:07:51,505 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2011-02-03 23:07:51,505 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.11, Profile=Sony Bravia TV'
2011-02-03 23:07:51,505 DEBUG [ResourceTransportRequestHandler] Request for resource 210 and type 'MEDIA_ITEM' received
2011-02-03 23:07:51,506 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 210)
2011-02-03 23:07:51,506 DEBUG [VideoDAOImpl] Reading a Video (id = 210)
2011-02-03 23:07:51,507 DEBUG [VideoDeliveryEngine] Delivering item '210' for client 'IPAddress=/192.168.1.11, Profile=Sony Bravia TV'
2011-02-03 23:07:51,507 DEBUG [VideoDeliveryEngine] Delivering file '009_2010Dec04_2211_QI_XL.ts' in native format
2011-02-03 23:07:51,507 DEBUG [MediaItemDAOImpl] Getting file of media item 210
2011-02-03 23:07:51,509 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1060120768
2011-02-03 23:07:51,509 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-02-03 23:07:51,509 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Range: bytes 38453056-1098573823/1098573824,Content-Length: 1060120768,Date: Thu, 03 Feb 2011 23:07:51 GMT,Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/0.5,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-02-03 23:07:59,429 DEBUG [WebServer] I/O error: Broken pipe
2011-02-03 23:08:05,260 DEBUG [ActionsServerResource] Action with name 'stopServer' was requested
2011-02-03 23:08:05,261 DEBUG [DiscoveryManager] UPNP device 8dee68fe-0370-3fc8-a5f5-ae4a1fb10a65 (192.168.1.10) is unavailable
2011-02-03 23:08:05,261 DEBUG [WebServer] Socket closed
2011-02-03 23:08:05,261 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-02-03 23:08:05,261 INFO  [WebServer] WebServer shutting down
2011-02-03 23:08:05,263 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-02-03 23:08:05,263 INFO  [EventDispatcher] Leaving EventDispatcher
2011-02-03 23:08:05,266 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP byebye using interface vnic1 (vnic1) and address 10.37.129.2, timeout = 0
2011-02-03 23:08:05,268 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP byebye using interface vnic0 (vnic0) and address 10.211.55.2, timeout = 0
2011-02-03 23:08:05,358 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP byebye using interface en0 (en0) and address claudia-x.home, timeout = 0
2011-02-03 23:08:05,360 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-02-03 23:08:05,748 INFO  [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-02-03 23:08:10,495 DEBUG [ActionsServerResource] Action with name 'exitServiio' was requested
2011-02-03 23:08:10,498 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-02-03 23:08:10,700 INFO  [DatabaseManager] Shutting down database
2011-02-03 23:08:10,701 DEBUG [DBConnectionPool] Closed connection for pool Serviio DB Pool
2011-02-03 23:08:10,702 DEBUG [DBConnectionPool] Closed connection for pool Serviio DB Pool
2011-02-03 23:08:10,737 DEBUG [DatabaseManager] DB shutdown returned: Derby system shutdown.
2011-02-03 23:08:10,737 INFO  [VideoDeliveryEngine] Cleaning transcode engine and its data
2011-02-03 23:08:10,737 DEBUG [VideoDeliveryEngine] Deleting temporary transcoded files from: /var/folders/iQ/iQ4Sullk2RWewE+8ZME0bU+++TI/-Tmp-/Serviio
The KDL-32EX403 is running software PKG4.089EUL-0108.
If you can offer any guidance to help, I'd be really grateful!
Many thanks,
Pants.
Post Fri Feb 04, 2011 9:36 am
Re: Cannot Playback .ts file from Mac to Sony Bravia
Moisie wrote:...Attempting to play them back results in a black screen and no audio output.
  Program 4228
So your "009_2010Dec04_2211_QI_XL.ts" was delivered in native format with MPEG_TS_SD_NA_ISO DLNA profile
This is an mpeg2video with multiple audio tracks mp3/mp2 and Subtitle
Sony Bravia may support these format
You have an error on ffmpeg -i result : [NULL @ 0x1030200] start time is not set in av_estimate_timings_from_pts
I don't know what this...
For testing, we could change the Sony Profile to force transcoding like this:
<Profile id="9" name="Sony Bravia TV" extendsProfileId="1">
      <Detection>
         <UPnPSearch>
            <FriendlyName>BRAVIA.*</FriendlyName>
         </UPnPSearch>
      </Detection>
      <MediaFormatProfiles>
         <!-- rename native mpeg2ts with h264/ac3 ac3 formats to those supported by the tv -->
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3">AVC_TS_MP_HD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3">AVC_TS_MP_SD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
         <!-- rename transcoded mpeg2ts with h264 to one of the TV's supported profiles -->
         <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
      </MediaFormatProfiles>
         <!-- For dvr-ms files, and files saved from Humax PVR-9200 DVB PVR machine force mpeg2video transcoding-->
         <Video targetContainer="mpegts" targetACodec="ac3" forceVTranscoding="true">
            <Matches container="asf" vCodec="mpeg2video" />
            <Matches container="mpegts" vCodec="mpeg2video" />
            First remux all h264 video on MPEG-TS stream with ac3 audio transcoding, expected profile AVC_TS_MP_HD_AC3_ISO or
            <!-- if audio different to ac3, must be transcoded -->
            <Matches container="mpegts" aCodec="aac" />
            <Matches container="mpegts" aCodec="mp3" />
            <Matches container="mpegts" aCodec="dca" />
         <!-- All Others video/audio codec will be transcoded into mpeg2ts, mpeg2video and ac3 audio (MPEG_TS_SD_EU). -->
            <Matches container="asf" />
            <Matches container="avi" />
            <Matches container="mp4" />
            <Matches container="flv" />
tombert
Post Fri Feb 04, 2011 7:33 pm
I once tried to play files from a Hirschmann HD Recorder - as well .ts files - but Hirschmann puts timing information in a separate file ... well playback did go well with VLC but I also tried conversion and this failed with several converters I tried ...
The point is - such files are often not trustworthy ...
Post Sat Feb 05, 2011 12:58 pm
tombert wrote:...r - as well .ts files - but Hirschmann puts timing information in a separate file ...
Ok, could you have a look at this tool: http://www.videohelp.com/tools/TsRemux
TsRemux is a transport Stream Re-muxer with blu-ray/Sat/OTA and now MPG/VOB/EVOB stream support. Ability to trim streams at the beginning and/or the end, Ability to pick and choose elementary streams to be kept, Ability to remux PCR-less streams, Ability to remux program streams (MPG/VOB/EVOB) into TS/M2TS, Ability to demux elementary streams as well as subtitle streams compatible with SUPreader (right click the selected stream with the mouse)
tombert
Post Sat Feb 05, 2011 5:48 pm
Yes yes ... I know in principle it should work ...
A friend of mine tried to copy .ts file from one HD Recorder to another and it didn't work ... so my assumption is that these devices do not produce 100% compatible streams ...
Moisie
Post Wed Feb 09, 2011 11:02 pm
Hello all:
Thanks for your replies - I appreciate the rapidity and usefulness of them!
Illico wrote:You have an error on ffmpeg -i result : [NULL @ 0x1030200] start time is not set in av_estimate_timings_from_pts
(snip)
I've tried what you suggested. However, the Bravia now didn't find any video files available in my .ts folder; previously, it did display files (and tagged them as MPEG2), but only played black and silence.
I don't think I've done anything stupid to cause this - I simply pasted your updated profile over the one in the Serviio config folder, relaunched the server and forced the library to refresh. If I have done something stupid, please let me know!! :)
tombert wrote:I once tried to play files from a Hirschmann HD Recorder - as well .ts files - but Hirschmann puts timing information in a separate file ... well playback did go well with VLC but I also tried conversion and this failed with several converters I tried ...
Well this is entirely possible too!
I've found only VLC is able to playback these files previously - and even then, VLC doesn't display any playback timing information about the file...
Illico wrote:Ok, could you have a look at this tool: http://www.videohelp.com/tools/TsRemux
Thanks for the suggestion; however, TsRemux is Windows-only - and I'm a Mac Bunny... ;)
I'm sure I'm teaching the community to suck eggs here, but I've found MPEG Streamclip to be able to handle these .ts files - I regularly use it to convert the .ts files into H.264 for loading onto my iPhone...
If it looks like I'm on a road to nowhere with these raw .ts files from the Hummy, I'm happy to be told this. I've got a library of these files, but I'm happy to, over time, convert them to a more useful container if it's going to be more compatible!
Thanks,
Pants.
Post Thu Feb 10, 2011 1:29 pm
Moisie wrote:... I simply pasted your updated profile over the one in the Serviio config folder, relaunched the server and forced the library to refresh. If I have done something stupid, please let me know!! :)
Relaunched the server, did not take the change into account. You need to restart the serviio service.
Moisie wrote:I'm sure I'm teaching the community to suck eggs here, but I've found MPEG Streamclip to be able to handle these .ts files - I regularly use it to convert the .ts files into H.264 for loading onto my iPhone...
I will have a look.
Moisie
Post Thu Feb 10, 2011 5:31 pm
Hello again:
Sorry - I didn't explain myself properly. I meant to write:
I quit the Serviio application and Console, pasted your updated profile over the one in the Serviio config folder and relaunched the Serviio application and Console. I then refreshed the TV's internet content to make sure, and forced the Serviio library to refresh too.
After doing this, the TV didn't recognise any files in the folder containing just .ts files.
Thanks,
Pants.
Post Thu Feb 10, 2011 6:43 pm
Could you retry with my modified profile, enable detailed logging, check the ffmpeg lines when start to transcode and post the command line?
Moisie
Post Thu Feb 10, 2011 7:27 pm
Illico wrote:Could you retry with my modified profile, enable detailed logging, check the ffmpeg lines when start to transcode and post the command line?
Hello:
Of course I can; just one question: I don't understand the 'check the ffmpeg lines when start to transcode' bit. If the TV doesn't see the files at all, how would transcoding start?
Thanks,
Pants.
Post Thu Feb 10, 2011 7:55 pm
Ok, sorry, you said TV didn't recognise.. I thought it does not decode it.
So check the logging with the filename to understand why did it not added to the library.
Moisie
Post Thu Feb 17, 2011 8:32 pm
Illico wrote:Ok, sorry, you said TV didn't recognise.. I thought it does not decode it.
Hello again:
Sorry for the long delays between posts - I work long hours, and then my wife wouldn't be too pleased if I got home and started debugging the TV whilst she's watching it... ;)
Anyway, here's the latest:
It seems I was too hasty in reporting that the TV did not list the .ts files after updating the profile - it does.
However, it still does not playback. The behaviour is different now: previously, I would get a black screen and silence when the TV attempted to play a .ts file. Now, I get a busy spinning whirlygig for a few seconds, then the message "Temporarily cannot access the server. Please retry." appears on the TV. Attempting a retry results in the same behaviour.
I have tried rewriting the .ts files into .mpeg files using MPEG Streamclip - and these are recognised and played back successfully. So, if the answer is simply to rewrite them, I'm ok with that!
Anyway, here's the output from the debug log. In this sequence, I tried playing the .ts file twice (unsuccessfully), and then successfully played back a .mpeg file:
2011-02-17 20:19:04,894 DEBUG [WebServer] Incoming connection from /192.168.1.101:58458
2011-02-17 20:19:04,916 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.101:
2011-02-17 20:19:04,916 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2011-02-17 20:19:04,926 DEBUG [ContentDirectory] Browse() called for profile Sony Bravia TV with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2011-02-17 20:19:04,944 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-02-17 20:19:04,949 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-17 20:19:07,819 DEBUG [WebServer] Incoming connection from /192.168.1.101:58459
2011-02-17 20:19:07,819 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.101:
2011-02-17 20:19:07,819 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2011-02-17 20:19:07,823 DEBUG [ContentDirectory] Browse() called for profile Sony Bravia TV with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2011-02-17 20:19:07,871 DEBUG [VideoDAOImpl] Retrieving number of video initials
2011-02-17 20:19:07,893 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2
2011-02-17 20:19:07,919 DEBUG [SeriesDAOImpl] Retrieving number of series
2011-02-17 20:19:07,961 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO
2011-02-17 20:19:07,972 DEBUG [VideoDAOImpl] Retrieving number of 10 last viewed videos
2011-02-17 20:19:07,993 DEBUG [VideoDAOImpl] Retrieving number of 10 last added videos
2011-02-17 20:19:07,993 DEBUG [VideoDAOImpl] Retrieving number of videos of type 0
2011-02-17 20:19:08,011 DEBUG [GenreDAOImpl] Retrieving number of genres for VIDEO
2011-02-17 20:19:08,061 DEBUG [PersonDAOImpl] Retrieving number of person initials for role ACTOR
2011-02-17 20:19:08,190 DEBUG [PersonDAOImpl] Retrieving number of person initials for role DIRECTOR
2011-02-17 20:19:08,192 DEBUG [PersonDAOImpl] Retrieving number of person initials for role PRODUCER
2011-02-17 20:19:08,193 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-02-17 20:19:08,200 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-17 20:19:11,221 DEBUG [WebServer] Incoming connection from /192.168.1.101:58460
2011-02-17 20:19:11,222 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.101:
2011-02-17 20:19:11,222 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2011-02-17 20:19:11,235 DEBUG [ContentDirectory] Browse() called for profile Sony Bravia TV with parameters: objectID = V_F, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2011-02-17 20:19:11,235 DEBUG [RepositoryDAOImpl] Retrieving list of Repositories for VIDEO (from=0, count=10)
2011-02-17 20:19:11,249 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root'
2011-02-17 20:19:11,286 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO
2011-02-17 20:19:11,287 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-02-17 20:19:11,289 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-17 20:19:12,351 DEBUG [WebServer] Incoming connection from /192.168.1.101:58461
2011-02-17 20:19:12,352 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.101:
2011-02-17 20:19:12,352 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2011-02-17 20:19:12,356 DEBUG [ContentDirectory] Browse() called for profile Sony Bravia TV with parameters: objectID = V_F#FOL_R3, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2011-02-17 20:19:12,356 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder null
2011-02-17 20:19:12,378 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 123 (from=0, count=10)
2011-02-17 20:19:12,417 DEBUG [GenreDAOImpl] Reading a Genre (id = 18)
2011-02-17 20:19:12,427 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 428)
2011-02-17 20:19:12,460 DEBUG [MediaItemDAOImpl] Getting file of media item 428
2011-02-17 20:19:12,465 DEBUG [VideoDAOImpl] Reading a Video (id = 428)
2011-02-17 20:19:12,481 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 428 and profile Sony Bravia TV
2011-02-17 20:19:12,485 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 423)
2011-02-17 20:19:12,575 DEBUG [GenreDAOImpl] Reading a Genre (id = 18)
2011-02-17 20:19:12,575 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 427)
2011-02-17 20:19:12,576 DEBUG [MediaItemDAOImpl] Getting file of media item 427
2011-02-17 20:19:12,577 DEBUG [VideoDAOImpl] Reading a Video (id = 427)
2011-02-17 20:19:12,578 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 427 and profile Sony Bravia TV
2011-02-17 20:19:12,578 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file 009_2010Dec04_2211_QI_XL.ts: MPEG_TS_SD_EU_ISO
2011-02-17 20:19:12,578 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file 009_2010Dec04_2211_QI_XL.ts: MPEG_TS_SD_NA_ISO
2011-02-17 20:19:12,578 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file 009_2010Dec04_2211_QI_XL.ts: MPEG_TS_SD_KO_ISO
2011-02-17 20:19:12,578 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 422)
2011-02-17 20:19:12,579 DEBUG [GenreDAOImpl] Reading a Genre (id = 18)
2011-02-17 20:19:12,580 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 429)
2011-02-17 20:19:12,580 DEBUG [MediaItemDAOImpl] Getting file of media item 429
2011-02-17 20:19:12,581 DEBUG [VideoDAOImpl] Reading a Video (id = 429)
2011-02-17 20:19:12,582 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 429 and profile Sony Bravia TV
2011-02-17 20:19:12,582 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 425)
2011-02-17 20:19:12,591 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root'
2011-02-17 20:19:12,596 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-02-17 20:19:12,606 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-17 20:19:12,787 DEBUG [WebServer] Incoming connection from /192.168.1.101:58462
2011-02-17 20:19:12,789 DEBUG [ResourceTransportRequestHandler] GET /resource/423/COVER_IMAGE HTTP/1.1, headers = [transferMode.dlna.org: Interactive,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-32EX403";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-32EX403"; mv="1.7";,Host: 192.168.1.14:8895]]
2011-02-17 20:19:12,789 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2011-02-17 20:19:12,790 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.101, Profile=Sony Bravia TV'
2011-02-17 20:19:12,791 DEBUG [ResourceTransportRequestHandler] Request for resource 423 and type 'COVER_IMAGE' received
2011-02-17 20:19:12,792 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 423)
2011-02-17 20:19:12,792 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 423
2011-02-17 20:19:12,794 DEBUG [ResourceTransportRequestHandler] Entity will be consumed till the end
2011-02-17 20:19:12,794 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: -1
2011-02-17 20:19:12,794 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-02-17 20:19:12,794 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Date: Thu, 17 Feb 2011 20:19:12 GMT,Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/0.5,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2011-02-17 20:19:12,939 DEBUG [WebServer] Incoming connection from /192.168.1.101:58463
2011-02-17 20:19:12,939 DEBUG [ResourceTransportRequestHandler] GET /resource/422/COVER_IMAGE HTTP/1.1, headers = [transferMode.dlna.org: Interactive,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-32EX403";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-32EX403"; mv="1.7";,Host: 192.168.1.14:8895]]
2011-02-17 20:19:12,941 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2011-02-17 20:19:12,941 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.101, Profile=Sony Bravia TV'
2011-02-17 20:19:12,942 DEBUG [ResourceTransportRequestHandler] Request for resource 422 and type 'COVER_IMAGE' received
2011-02-17 20:19:12,942 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 422)
2011-02-17 20:19:12,945 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 422
2011-02-17 20:19:12,946 DEBUG [ResourceTransportRequestHandler] Entity will be consumed till the end
2011-02-17 20:19:12,946 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: -1
2011-02-17 20:19:12,946 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-02-17 20:19:12,946 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Date: Thu, 17 Feb 2011 20:19:12 GMT,Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/0.5,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2011-02-17 20:19:13,024 DEBUG [WebServer] Incoming connection from /192.168.1.101:58464
2011-02-17 20:19:13,025 DEBUG [ResourceTransportRequestHandler] GET /resource/425/COVER_IMAGE HTTP/1.1, headers = [transferMode.dlna.org: Interactive,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-32EX403";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-32EX403"; mv="1.7";,Host: 192.168.1.14:8895]]
2011-02-17 20:19:13,025 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2011-02-17 20:19:13,026 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.101, Profile=Sony Bravia TV'
2011-02-17 20:19:13,026 DEBUG [ResourceTransportRequestHandler] Request for resource 425 and type 'COVER_IMAGE' received
2011-02-17 20:19:13,026 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 425)
2011-02-17 20:19:13,026 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 425
2011-02-17 20:19:13,026 DEBUG [ResourceTransportRequestHandler] Entity will be consumed till the end
2011-02-17 20:19:13,026 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: -1
2011-02-17 20:19:13,027 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-02-17 20:19:13,027 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Date: Thu, 17 Feb 2011 20:19:13 GMT,Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/0.5,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2011-02-17 20:19:13,162 DEBUG [WebServer] Incoming connection from /192.168.1.101:58465
2011-02-17 20:19:13,163 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.101:
2011-02-17 20:19:13,163 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2011-02-17 20:19:13,167 DEBUG [ContentDirectory] Browse() called for profile Sony Bravia TV with parameters: objectID = V_F#FOL_R3, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2011-02-17 20:19:13,167 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-17 20:19:13,176 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-17 20:19:17,984 DEBUG [WebServer] Incoming connection from /192.168.1.101:58466
2011-02-17 20:19:17,988 DEBUG [ResourceTransportRequestHandler] HEAD /resource/427/MEDIA_ITEM/MPEG_TS_SD_NA_ISO HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-32EX403";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-32EX403"; mv="1.7";,Host: 192.168.1.14:8895]]
2011-02-17 20:19:17,988 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2011-02-17 20:19:17,988 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.101, Profile=Sony Bravia TV'
2011-02-17 20:19:17,988 DEBUG [ResourceTransportRequestHandler] Request for resource 427 and type 'MEDIA_ITEM' received
2011-02-17 20:19:17,989 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 427)
2011-02-17 20:19:17,991 DEBUG [VideoDAOImpl] Reading a Video (id = 427)
2011-02-17 20:19:17,994 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 427, format MPEG_TS_SD_NA_ISO and profile Sony Bravia TV
2011-02-17 20:19:17,994 DEBUG [VideoDeliveryEngine] Getting media info for transcoded version of file 009_2010Dec04_2211_QI_XL.ts
2011-02-17 20:19:17,994 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file 009_2010Dec04_2211_QI_XL.ts: MPEG_TS_SD_EU_ISO
2011-02-17 20:19:17,994 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file 009_2010Dec04_2211_QI_XL.ts: MPEG_TS_SD_NA_ISO
2011-02-17 20:19:17,994 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file 009_2010Dec04_2211_QI_XL.ts: MPEG_TS_SD_KO_ISO
2011-02-17 20:19:17,995 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-02-17 20:19:17,995 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Thu, 17 Feb 2011 20:19:17 GMT,Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/0.5,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-02-17 20:19:18,008 DEBUG [WebServer] Incoming connection from /192.168.1.101:58467
2011-02-17 20:19:18,009 DEBUG [ResourceTransportRequestHandler] GET /resource/427/MEDIA_ITEM/MPEG_TS_SD_NA_ISO HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=0.000-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-32EX403";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-32EX403"; mv="1.7";,Host: 192.168.1.14:8895]]
2011-02-17 20:19:18,009 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2011-02-17 20:19:18,009 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.101, Profile=Sony Bravia TV'
2011-02-17 20:19:18,009 DEBUG [ResourceTransportRequestHandler] Request for resource 427 and type 'MEDIA_ITEM' received
2011-02-17 20:19:18,010 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 427)
2011-02-17 20:19:18,010 DEBUG [VideoDAOImpl] Reading a Video (id = 427)
2011-02-17 20:19:18,011 DEBUG [VideoDeliveryEngine] Delivering item '427' for client 'IPAddress=/192.168.1.101, Profile=Sony Bravia TV'
2011-02-17 20:19:18,011 DEBUG [VideoDeliveryEngine] Delivering file '009_2010Dec04_2211_QI_XL.ts' using transcoding
2011-02-17 20:19:18,011 DEBUG [VideoDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.101, Profile=Sony Bravia TV'
2011-02-17 20:19:18,013 DEBUG [MediaItemDAOImpl] Getting file of media item 427
2011-02-17 20:19:18,015 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode file: /Volumes/500GB FreeAgent HD/Serviio Test/009_2010Dec04_2211_QI_XL.ts
2011-02-17 20:19:18,016 DEBUG [ProcessExecutor] Starting /Users/big_dave/Downloads/serviio-0.5-osx/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg -i /Volumes/500GB FreeAgent HD/Serviio Test/009_2010Dec04_2211_QI_XL.ts -y -vcodec mpeg2video -sameq -r 25.0 -g 15 -copyts -acodec ac3 -ab 192k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts /var/folders/iQ/iQ4Sullk2RWewE+8ZME0bU+++TI/-Tmp-/Serviio/transcoding-temp-427-MPEG2TS.stf
2011-02-17 20:19:19,259 WARN  [ProcessExecutor] Process /Users/big_dave/Downloads/serviio-0.5-osx/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg has a return code of 1! This is a possible error.
2011-02-17 20:19:19,259 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2011-02-17 20:19:25,524 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
   at org.serviio.delivery.resource.VideoDeliveryEngine.retrieveTranscodedResource(VideoDeliveryEngine.java:160)
   at org.serviio.delivery.resource.VideoDeliveryEngine.retrieveTranscodedResource(VideoDeliveryEngine.java:54)
   at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:90)
   at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:116)
   at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:126)
   at org.serviio.upnp.webserver.AbstractRequestHandler.handle(AbstractRequestHandler.java:52)
2011-02-17 20:19:44,409 DEBUG [WebServer] Incoming connection from /192.168.1.101:58468
2011-02-17 20:19:44,418 DEBUG [ResourceTransportRequestHandler] HEAD /resource/427/MEDIA_ITEM/MPEG_TS_SD_NA_ISO HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-32EX403";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-32EX403"; mv="1.7";,Host: 192.168.1.14:8895]]
2011-02-17 20:19:44,418 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2011-02-17 20:19:44,420 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.101, Profile=Sony Bravia TV'
2011-02-17 20:19:44,420 DEBUG [ResourceTransportRequestHandler] Request for resource 427 and type 'MEDIA_ITEM' received
2011-02-17 20:19:44,420 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 427)
2011-02-17 20:19:44,421 DEBUG [VideoDAOImpl] Reading a Video (id = 427)
2011-02-17 20:19:44,422 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 427, format MPEG_TS_SD_NA_ISO and profile Sony Bravia TV
2011-02-17 20:19:44,422 DEBUG [VideoDeliveryEngine] Getting media info for transcoded version of file 009_2010Dec04_2211_QI_XL.ts
2011-02-17 20:19:44,422 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file 009_2010Dec04_2211_QI_XL.ts: MPEG_TS_SD_EU_ISO
2011-02-17 20:19:44,422 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file 009_2010Dec04_2211_QI_XL.ts: MPEG_TS_SD_NA_ISO
2011-02-17 20:19:44,422 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file 009_2010Dec04_2211_QI_XL.ts: MPEG_TS_SD_KO_ISO
2011-02-17 20:19:44,422 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-02-17 20:19:44,422 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Thu, 17 Feb 2011 20:19:44 GMT,Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/0.5,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-02-17 20:19:44,430 DEBUG [WebServer] Incoming connection from /192.168.1.101:58469
2011-02-17 20:19:44,431 DEBUG [ResourceTransportRequestHandler] GET /resource/427/MEDIA_ITEM/MPEG_TS_SD_NA_ISO HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=0.000-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-32EX403";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-32EX403"; mv="1.7";,Host: 192.168.1.14:8895]]
2011-02-17 20:19:44,431 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2011-02-17 20:19:44,431 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.101, Profile=Sony Bravia TV'
2011-02-17 20:19:44,432 DEBUG [ResourceTransportRequestHandler] Request for resource 427 and type 'MEDIA_ITEM' received
2011-02-17 20:19:44,432 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 427)
2011-02-17 20:19:44,432 DEBUG [VideoDAOImpl] Reading a Video (id = 427)
2011-02-17 20:19:44,433 DEBUG [VideoDeliveryEngine] Delivering item '427' for client 'IPAddress=/192.168.1.101, Profile=Sony Bravia TV'
2011-02-17 20:19:44,433 DEBUG [VideoDeliveryEngine] Delivering file '009_2010Dec04_2211_QI_XL.ts' using transcoding
2011-02-17 20:19:44,434 DEBUG [VideoDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.101, Profile=Sony Bravia TV'
2011-02-17 20:19:44,435 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
2011-02-17 20:20:11,291 DEBUG [WebServer] Incoming connection from /192.168.1.101:58470
2011-02-17 20:20:11,292 DEBUG [ResourceTransportRequestHandler] HEAD /resource/428/MEDIA_ITEM/MPEG_PS_NTSC HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-32EX403";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-32EX403"; mv="1.7";,Host: 192.168.1.14:8895]]
2011-02-17 20:20:11,292 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2011-02-17 20:20:11,293 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.101, Profile=Sony Bravia TV'
2011-02-17 20:20:11,293 DEBUG [ResourceTransportRequestHandler] Request for resource 428 and type 'MEDIA_ITEM' received
2011-02-17 20:20:11,293 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 428)
2011-02-17 20:20:11,293 DEBUG [VideoDAOImpl] Reading a Video (id = 428)
2011-02-17 20:20:11,294 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 428, format MPEG_PS_NTSC and profile Sony Bravia TV
2011-02-17 20:20:11,341 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-02-17 20:20:11,341 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Thu, 17 Feb 2011 20:20:11 GMT,Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/0.5,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-02-17 20:20:11,351 DEBUG [WebServer] Incoming connection from /192.168.1.101:58471
2011-02-17 20:20:11,353 DEBUG [ResourceTransportRequestHandler] GET /resource/428/MEDIA_ITEM/MPEG_PS_NTSC HTTP/1.1, headers = [Range: bytes=0-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-32EX403";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-32EX403"; mv="1.7";,Host: 192.168.1.14:8895]]
2011-02-17 20:20:11,353 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2011-02-17 20:20:11,354 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.101, Profile=Sony Bravia TV'
2011-02-17 20:20:11,354 DEBUG [ResourceTransportRequestHandler] Request for resource 428 and type 'MEDIA_ITEM' received
2011-02-17 20:20:11,354 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 428)
2011-02-17 20:20:11,355 DEBUG [VideoDAOImpl] Reading a Video (id = 428)
2011-02-17 20:20:11,355 DEBUG [VideoDeliveryEngine] Delivering item '428' for client 'IPAddress=/192.168.1.101, Profile=Sony Bravia TV'
2011-02-17 20:20:11,355 DEBUG [VideoDeliveryEngine] Delivering file '009_2010Dec04_2211_QI_XL.mpeg' in native format
2011-02-17 20:20:11,355 DEBUG [MediaItemDAOImpl] Getting file of media item 428
2011-02-17 20:20:11,439 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 428) as read
2011-02-17 20:20:11,711 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-02-17 20:20:11,712 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1063338406
2011-02-17 20:20:11,712 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2011-02-17 20:20:11,713 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-02-17 20:20:11,713 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Range: bytes 0-1063338405/1063338406,Date: Thu, 17 Feb 2011 20:20:11 GMT,Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/0.5,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-02-17 20:20:12,036 INFO  [UpdateChecker] Checking if a new version is available
2011-02-17 20:20:12,857 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-02-17 20:20:13,410 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2011-02-17 20:20:13,673 DEBUG [WebServer] I/O error: Broken pipe
2011-02-17 20:20:13,675 DEBUG [WebServer] Incoming connection from /192.168.1.101:58472
2011-02-17 20:20:13,676 DEBUG [ResourceTransportRequestHandler] GET /resource/428/MEDIA_ITEM/MPEG_PS_NTSC HTTP/1.1, headers = [Range: bytes=1671168-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-32EX403";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-32EX403"; mv="1.7";,Host: 192.168.1.14:8895]]
2011-02-17 20:20:13,676 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2011-02-17 20:20:13,677 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.101, Profile=Sony Bravia TV'
2011-02-17 20:20:13,677 DEBUG [ResourceTransportRequestHandler] Request for resource 428 and type 'MEDIA_ITEM' received
2011-02-17 20:20:13,677 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 428)
2011-02-17 20:20:13,678 DEBUG [VideoDAOImpl] Reading a Video (id = 428)
2011-02-17 20:20:13,678 DEBUG [VideoDeliveryEngine] Delivering item '428' for client 'IPAddress=/192.168.1.101, Profile=Sony Bravia TV'
2011-02-17 20:20:13,678 DEBUG [VideoDeliveryEngine] Delivering file '009_2010Dec04_2211_QI_XL.mpeg' in native format
2011-02-17 20:20:13,678 DEBUG [MediaItemDAOImpl] Getting file of media item 428
2011-02-17 20:20:13,680 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1061667238
2011-02-17 20:20:13,680 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2011-02-17 20:20:13,680 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-02-17 20:20:13,680 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Range: bytes 1671168-1063338405/1063338406,Date: Thu, 17 Feb 2011 20:20:13 GMT,Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/0.5,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-02-17 20:20:15,496 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2011-02-17 20:20:15,498 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2011-02-17 20:20:18,504 DEBUG [WebServer] I/O error: Broken pipe
2011-02-17 20:20:19,726 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-02-17 20:20:26,949 DEBUG [ActionsServerResource] Action with name 'exitServiio' was requested
2011-02-17 20:20:26,955 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-02-17 20:20:27,155 DEBUG [WebServer] Socket closed
2011-02-17 20:20:27,155 DEBUG [DiscoveryManager] UPNP device 086927b9-bdb4-3323-80e1-dbadc7ec8407 (192.168.1.14) is unavailable
2011-02-17 20:20:27,155 INFO  [WebServer] WebServer shutting down
2011-02-17 20:20:27,155 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-02-17 20:20:27,155 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-02-17 20:20:27,155 INFO  [EventDispatcher] Leaving EventDispatcher
Hope that helps!
Thanks,
Pants.
Kelli
Post Fri Feb 18, 2011 12:25 am
Hi
I'm wondering if you have had the same issue as me. I have just set up my Sony Bravia and Sony wireless BluRay player. I have Serviio running and I see all of my movies (from my computer) on my bluray. I can play them but they keep stopping and starting, like it's streaming. Have you had this problem and if so, what did you do to correct it?
I'm on a Mac, OS 10.6.5.
Thanks,
Moisie
Post Sun Feb 20, 2011 11:23 am
Kelli wrote:Hi
Thanks,
Hi Kelli
Thanks for the response. I've not had the behaviour you described - my files either play back perfectly, or not at all (in the case of these .ts files).
For your information:
- I'm running Mac OS X 10.6.6;
- I have a wired Ethernet connection between computer and TV (via my home router);
- I've assigned a static IP address to my TV, so Serviio can find it easily each time I launch it (I run Serviio from my laptop, which isn't always at home);
- I've entered the IP address of my Mac's Ethernet port into Serviio, so that it connects out of the correct networking port.
Other than that, it all worked fine straight off the bat!
Hope that helps,
Pants.
jarpi
Post Thu Feb 16, 2012 10:13 am
yeah ts files are sometimes hard to deal with, but the simplest way to be able to play them is first to convert them to another format, like avi, which is supported by pretty much all players. I can recommend using Moviebox from Audials, it's a pretty good ts converter among other things and it supports all popular file formats. Anywho, just a suggestion :P
Post Thu Feb 16, 2012 10:32 am
@Moisie : Sorry for the long time....
But for your TS file, its seems that ffmpeg failed to transcode the file:
Could you retry locally the same ffmpeg command line and report the ffmpeg log error ?
@jarpi : disagree, ts files are much more supported by dlna devices
