WDTV Live Hub and Serviio
bubbabyte
Post Mon Feb 03, 2014 7:29 pm
Hi guys,
I've read through everything i can possibly read through on this forum but I can't figure this out. I have a D-Link router (826L) and Upnp is enabled and ipv4 multicast is enabled as well which was done about a month ago and seemed to resolve the issue. Then just a few days ago i noticed i kept getting dropped (content source has been removed) message, and i check my pc and the server is still running, even stopping it and restarting the service wouldn't bring it back someitmes. This is what is shown in my log and i have no idea what it means or what i should do to correct it.
2014-02-02 22:20:54,437 INFO [WebServer] WebServer shutting down
2014-02-02 22:20:54,438 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2014-02-02 22:20:54,438 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2014-02-02 22:20:54,439 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2014-02-02 22:20:54,439 INFO [EventDispatcher] Leaving EventDispatcher
2014-02-02 22:20:54,517 INFO [WebServer] WebServer starting on port 8895
2014-02-02 22:20:54,590 INFO [Device] Updated bound IP address of Device with UUID: 52f87b40-3dc2-3196-b089-5640e5a2fa57, bound address: 192.168.0.104
2014-02-02 22:20:54,591 INFO [EventDispatcher] Starting EventDispatcher
2014-02-02 22:20:54,591 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2014-02-02 22:20:54,591 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2014-02-02 22:20:54,678 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Marvell Yukon 88E8055 PCI-E Gigabit Ethernet Controller) and address 192.168.0.104, timeout = 0
2014-02-02 22:20:54,722 INFO [RendererSearchSender] Searching for Renderer devices
2014-02-02 22:22:23,879 INFO [RendererManager] Stored a new renderer: uuid='1476dc56-bae6-4c3b-a3b9-f0fbffa7fd6c', name = 'Unrecognized device', ipAddress='192.168.0.104', profile = '1'
2014-02-02 22:23:18,084 INFO [MediaServer] Serviio server instance is already running
I've made my ip static on the WDTV hub, and that didn't help. I'm not sure what else to do.
bubbabyte
Post Mon Feb 03, 2014 9:08 pm
Re: WDTV Live Hub and Serviio
Just fyi, its not linked to the whole 30 minute issue that others had, as it seems completely random. Sometimes hours, sometimes 10 minutes etc.
bubbabyte
Post Mon Feb 03, 2014 9:20 pm
Happened again now after about 2 hours of watching it.
2014-02-03 14:26:55,860 INFO [WebServer] WebServer shutting down
2014-02-03 14:26:55,882 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2014-02-03 14:26:55,882 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2014-02-03 14:26:55,882 INFO [EventDispatcher] Leaving EventDispatcher
2014-02-03 14:26:55,936 INFO [WebServer] WebServer starting on port 8895
2014-02-03 14:26:56,294 INFO [Device] Updated bound IP address of Device with UUID: 52f87b40-3dc2-3196-b089-5640e5a2fa57, bound address: 192.168.0.104
2014-02-03 14:26:56,294 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2014-02-03 14:26:56,294 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2014-02-03 14:26:56,294 INFO [EventDispatcher] Starting EventDispatcher
2014-02-03 14:26:56,347 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Marvell Yukon 88E8055 PCI-E Gigabit Ethernet Controller) and address 192.168.0.104, timeout = 0
2014-02-03 14:26:56,348 INFO [RendererSearchSender] Searching for Renderer devices
2014-02-03 14:26:56,510 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
Post Mon Feb 03, 2014 10:43 pm
Please post a detailed log (click link) showing some of the messages leading up to the server restarting. It may shed some light.
