WDTV live stream blank
andy00ff00
Post Wed Jan 29, 2014 11:05 am
Hi
I'm trying to live-stream a webcam to WDTV play. I've got VLC streaming the camera to http, that seems to work, I can see it from my tablet.
I'm then trying to publish that on LAN with serviio 1.4.
WDTV can see serviio, and the name of the online content, however when I try to play it, the screen is just blank. (actually it worked on one occasion, but I haven't been able to repro).
I found http://forum.serviio.org/viewtopic.php?f=5&t=13896 and I'm getting the same log entries:
WARN  [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
I assume the thread referred to in that post is http://forum.serviio.org/viewtopic.php?f=5&t=13280&p=79175&hilit=wdtv#p79175
However I've looked in my profiles.xml and it doesn't have
<ProtocolInfo>simple</ProtocolInfo>
, so I can't remove it.
http://forum.serviio.org/viewtopic.php?f=12&t=9910 seems to suggest that these "range entry" logs are a Fundamentally Bad Thing.
WDTV play has up to date firmware, there are no other interesting-looking entries in the serviio log. Firewall is off while I debug this.
Anything else I can try?
TIA
Andy
andy00ff00
Post Mon Feb 03, 2014 11:28 pm
Re: WDTV live stream blank
Further to last, here's a detailed log, starting when I select the item on WDTV play's GUI.
Sorry if I've missed something obvious, I have done my best to search previous forum entries, just want to know if this is worth persevering or if there's a basic incompatibility. Thanks.
Also here's the ffmpeg output, it's shorter so I've put it first:-
8<------------
$ ./ffmpeg.exe -i "http://192.168.0.9:8080/"
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-libass --enable-librtmp --enable-fontconfig --enable-libfreetype --enable-zlib --enable-libx264 --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config
[mpegts @ 01B3A1E0] max_analyze_duration 5000000 reached at 5015467 microseconds
Input #0, mpegts, from 'http://192.168.0.9:8080/':
Duration: N/A, start: 1142.215033, bitrate: 128 kb/s
Program 1
Stream #0:0[0x44](): Audio: mp2 ([3][0][0][0] / 0x0003), 44100 Hz, stereo, s16p, 128 kb/s
Stream #0:1[0x45](): Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p, 360x288 [SAR 16:15 DAR 4:3], 25 fps, 25 tbr, 90k tbn, 50 tbc
8<------------ (detailed serviio log follows --------------
[list=]2014-02-03 23:09:01,359 DEBUG [ServiioHttpService] Incoming request from /192.168.0.4:51153: POST /serviceControl HTTP/1.1, headers = [Host: 192.168.0.9:8895,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks,SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse",Content-Type: text/xml; charset="utf-8",Content-Length: 452]]
2014-02-03 23:09:01,359 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2014-02-03 23:09:01,359 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.4
2014-02-03 23:09:01,406 DEBUG [ContentDirectory] Browse() called for renderer WD TV Play (profile 14) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 64, sortCriteria =
2014-02-03 23:09:01,437 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2014-02-03 23:09:04,140 DEBUG [ServiioHttpService] Incoming request from /192.168.0.4:64358: POST /serviceControl HTTP/1.1, headers = [Host: 192.168.0.9:8895,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks,SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse",Content-Type: text/xml; charset="utf-8",Content-Length: 452]]
2014-02-03 23:09:04,140 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2014-02-03 23:09:04,140 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.4
2014-02-03 23:09:04,140 DEBUG [ContentDirectory] Browse() called for renderer WD TV Play (profile 14) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 64, sortCriteria =
2014-02-03 23:09:04,140 DEBUG [VideoDAOImpl] Retrieving number of video initials [Any]
2014-02-03 23:09:04,187 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2 [Any]
2014-02-03 23:09:04,203 DEBUG [SeriesDAOImpl] Retrieving number of series
2014-02-03 23:09:04,218 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [Any]
2014-02-03 23:09:04,218 DEBUG [VideoDAOImpl] Retrieving number of 10 last viewed videos [Any]
2014-02-03 23:09:04,234 DEBUG [VideoDAOImpl] Retrieving number of 10 last added videos
2014-02-03 23:09:04,234 DEBUG [VideoDAOImpl] Retrieving number of videos of type 0 [Any]
2014-02-03 23:09:04,250 DEBUG [GenreDAOImpl] Retrieving number of genres for VIDEO
2014-02-03 23:09:04,281 DEBUG [VideoDAOImpl] Retrieving number of video ratings [Any]
2014-02-03 23:09:04,296 DEBUG [PersonDAOImpl] Retrieving number of person initials for role ACTOR
2014-02-03 23:09:04,328 DEBUG [PersonDAOImpl] Retrieving number of person initials for role DIRECTOR
2014-02-03 23:09:04,328 DEBUG [PersonDAOImpl] Retrieving number of person initials for role PRODUCER
2014-02-03 23:09:04,343 DEBUG [VideoDAOImpl] Retrieving number of video release years [Any]
2014-02-03 23:09:04,343 DEBUG [PlaylistDAOImpl] Retrieving number of playlists for VIDEO [Any]
2014-02-03 23:09:04,359 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [Any]
2014-02-03 23:09:04,375 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [Any]
2014-02-03 23:09:04,390 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2014-02-03 23:09:09,375 DEBUG [ServiioHttpService] Incoming request from /192.168.0.4:59020: POST /serviceControl HTTP/1.1, headers = [Host: 192.168.0.9:8895,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks,SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse",Content-Type: text/xml; charset="utf-8",Content-Length: 455]]
2014-02-03 23:09:09,375 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2014-02-03 23:09:09,375 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.4
2014-02-03 23:09:09,375 DEBUG [ContentDirectory] Browse() called for renderer WD TV Play (profile 14) with parameters: objectID = V_OF, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 64, sortCriteria =
2014-02-03 23:09:09,375 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [Any]
2014-02-03 23:09:09,375 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [Any]
2014-02-03 23:09:09,390 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000070001961 and profile WDTV Live
2014-02-03 23:09:09,390 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_PAL
2014-02-03 23:09:09,390 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_NTSC
2014-02-03 23:09:09,390 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [Any]
2014-02-03 23:09:09,390 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [Any]
2014-02-03 23:09:09,406 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2014-02-03 23:09:12,093 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:byebye) message from Renderer 179325a7-0090-a962-cd64-1d050ebdc4a0 from address 192.168.0.4
2014-02-03 23:09:12,093 DEBUG [RendererManager] Removing renderer 179325a7-0090-a962-cd64-1d050ebdc4a0 from list of active renderers
2014-02-03 23:09:12,109 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:byebye) message from Renderer 179325a7-0090-a962-cd64-1d050ebdc4a0 from address 192.168.0.4
2014-02-03 23:09:12,125 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:byebye) message from Renderer 179325a7-0090-a962-cd64-1d050ebdc4a0 from address 192.168.0.4
2014-02-03 23:09:12,140 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:alive) message from Renderer 179325a7-0090-a962-cd64-1d050ebdc4a0 from address 192.168.0.4
2014-02-03 23:09:12,140 DEBUG [RendererManager] Adding renderer Renderer [uuid=179325a7-0090-a962-cd64-1d050ebdc4a0, ipAddress=192.168.0.4, name=WD TV Play, profileId=14, manuallyAdded=false, forcedProfile=true, enabled=true, accessGroupId=1] to list of active renderers
2014-02-03 23:09:12,171 DEBUG [ServiioHttpService] Incoming request from /192.168.0.4:34143: HEAD /resource/1000000070001961/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.0.9:8895,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2014-02-03 23:09:12,171 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2014-02-03 23:09:12,171 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:09:12,171 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000070001961 and type 'MEDIA_ITEM' received
2014-02-03 23:09:12,171 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000070001961 (online)
2014-02-03 23:09:12,171 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2014-02-03 23:09:12,171 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000070001961, format MPEG_PS_PAL and profile WDTV Live
2014-02-03 23:09:12,171 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file http://192.168.0.9:8080/
2014-02-03 23:09:12,171 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_PAL
2014-02-03 23:09:12,171 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_NTSC
2014-02-03 23:09:12,187 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Content-Length: 50000000000,Date: Mon, 03 Feb 2014 23:09:12 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.4,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-02-03 23:09:12,281 DEBUG [ServiioHttpService] Incoming request from /192.168.0.4:34144: GET /resource/1000000070001961/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks,Host: 192.168.0.9:8895,Accept: */*,Range: bytes=0-1023]]
2014-02-03 23:09:12,281 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2014-02-03 23:09:12,281 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:09:12,281 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000070001961 and type 'MEDIA_ITEM' received
2014-02-03 23:09:12,281 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000070001961 (online)
2014-02-03 23:09:12,281 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2014-02-03 23:09:12,281 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000070001961, format MPEG_PS_PAL and profile WDTV Live
2014-02-03 23:09:12,281 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file http://192.168.0.9:8080/
2014-02-03 23:09:12,281 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_PAL
2014-02-03 23:09:12,281 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_NTSC
2014-02-03 23:09:12,281 WARN [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
2014-02-03 23:09:12,281 DEBUG [VideoDeliveryEngine] Delivering item '1000000070001961' for client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:09:12,281 DEBUG [VideoDeliveryEngine] Delivering file 'http://192.168.0.9:8080/' using transcoding
2014-02-03 23:09:12,281 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:09:12,281 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: http://192.168.0.9:8080/
2014-02-03 23:09:12,281 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -analyzeduration 10000000 -threads auto -i http://192.168.0.9:8080/ -y -threads auto -c:v mpeg2video -pix_fmt yuv420p -qscale:v 1 -r 25 -g 15 -c:a ac3 -b:a 384k -ac 2 -map 0:0 -map 0:1 -sn -f vob pipe:
2014-02-03 23:09:18,968 DEBUG [ServiioHttpService] Incoming request from /192.168.0.4:34145: GET /resource/1000000070001961/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks,Host: 192.168.0.9:8895,Accept: */*,Range: bytes=0-1023]]
2014-02-03 23:09:18,968 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2014-02-03 23:09:18,968 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:09:18,968 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000070001961 and type 'MEDIA_ITEM' received
2014-02-03 23:09:18,968 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000070001961 (online)
2014-02-03 23:09:18,968 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2014-02-03 23:09:18,968 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000070001961, format MPEG_PS_PAL and profile WDTV Live
2014-02-03 23:09:18,968 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file http://192.168.0.9:8080/
2014-02-03 23:09:18,968 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_PAL
2014-02-03 23:09:18,968 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_NTSC
2014-02-03 23:09:18,968 WARN [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
2014-02-03 23:09:18,968 DEBUG [VideoDeliveryEngine] Delivering item '1000000070001961' for client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:09:18,968 DEBUG [VideoDeliveryEngine] Delivering file 'http://192.168.0.9:8080/' using transcoding
2014-02-03 23:09:20,171 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2014-02-03 23:09:20,171 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-02-03 23:09:20,171 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2014-02-03 23:09:22,281 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:09:22,281 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_PAL
2014-02-03 23:09:22,281 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_NTSC
2014-02-03 23:09:22,281 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2014-02-03 23:09:22,281 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2014-02-03 23:09:22,281 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Date: Mon, 03 Feb 2014 23:09:22 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.4,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-02-03 23:09:22,296 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2014-02-03 23:09:22,296 DEBUG [TimeoutStreamDelegator] Scheduling stream stop to happen in 20 seconds if there is no traffic
2014-02-03 23:09:23,421 DEBUG [ServiioHttpService] Incoming request from /192.168.0.4:34146: HEAD /resource/1000000070001961/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.0.9:8895,Accept: */*]]
2014-02-03 23:09:23,421 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2014-02-03 23:09:23,421 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:09:23,421 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000070001961 and type 'MEDIA_ITEM' received
2014-02-03 23:09:23,421 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000070001961 (online)
2014-02-03 23:09:23,421 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2014-02-03 23:09:23,421 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000070001961, format MPEG_PS_PAL and profile WDTV Live
2014-02-03 23:09:23,421 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file http://192.168.0.9:8080/
2014-02-03 23:09:23,421 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_PAL
2014-02-03 23:09:23,421 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_NTSC
2014-02-03 23:09:23,421 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Date: Mon, 03 Feb 2014 23:09:23 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.4,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-02-03 23:09:23,421 DEBUG [ServiioHttpService] Incoming request from /192.168.0.4:34146: GET /resource/1000000070001961/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.0.9:8895,Accept: */*,Range: bytes=0-]]
2014-02-03 23:09:23,437 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:09:23,437 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000070001961 and type 'MEDIA_ITEM' received
2014-02-03 23:09:23,437 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000070001961 (online)
2014-02-03 23:09:23,437 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2014-02-03 23:09:23,437 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000070001961, format MPEG_PS_PAL and profile WDTV Live
2014-02-03 23:09:23,437 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file http://192.168.0.9:8080/
2014-02-03 23:09:23,437 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_PAL
2014-02-03 23:09:23,437 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_NTSC
2014-02-03 23:09:23,437 WARN [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
2014-02-03 23:09:23,437 DEBUG [VideoDeliveryEngine] Delivering item '1000000070001961' for client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:09:23,437 DEBUG [VideoDeliveryEngine] Delivering file 'http://192.168.0.9:8080/' using transcoding
2014-02-03 23:09:23,437 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:09:23,437 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2014-02-03 23:09:23,437 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2014-02-03 23:09:23,437 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Date: Mon, 03 Feb 2014 23:09:23 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.4,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-02-03 23:09:23,500 DEBUG [ServiioHttpService] Incoming request from /192.168.0.4:34147: GET /resource/1000000070001961/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.0.9:8895,Accept: */*,Range: bytes=0-]]
2014-02-03 23:09:23,500 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2014-02-03 23:09:23,500 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:09:23,500 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000070001961 and type 'MEDIA_ITEM' received
2014-02-03 23:09:23,500 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000070001961 (online)
2014-02-03 23:09:23,500 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2014-02-03 23:09:23,500 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000070001961, format MPEG_PS_PAL and profile WDTV Live
2014-02-03 23:09:23,500 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file http://192.168.0.9:8080/
2014-02-03 23:09:23,500 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_PAL
2014-02-03 23:09:23,500 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_NTSC
2014-02-03 23:09:23,500 WARN [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
2014-02-03 23:09:23,515 DEBUG [VideoDeliveryEngine] Delivering item '1000000070001961' for client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:09:23,515 DEBUG [VideoDeliveryEngine] Delivering file 'http://192.168.0.9:8080/' using transcoding
2014-02-03 23:09:23,515 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:09:23,609 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2014-02-03 23:09:23,609 DEBUG [TimeoutStreamDelegator] Scheduling stream stop to happen in 20 seconds if there is no traffic
2014-02-03 23:09:24,515 DEBUG [StreamBasedTranscodingDeliveryStrategy] Transcoded stream is empty, connection may have been lost
2014-02-03 23:09:24,515 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_PAL
2014-02-03 23:09:24,515 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_NTSC
2014-02-03 23:09:24,515 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2014-02-03 23:09:24,515 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2014-02-03 23:09:24,515 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Date: Mon, 03 Feb 2014 23:09:24 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.4,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-02-03 23:09:24,671 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2014-02-03 23:09:24,671 DEBUG [TimeoutStreamDelegator] Scheduling stream stop to happen in 20 seconds if there is no traffic
2014-02-03 23:09:28,750 DEBUG [ServiioHttpService] Incoming request from /192.168.0.4:34148: GET /resource/1000000070001961/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.0.9:8895,Accept: */*,Range: bytes=0-]]
2014-02-03 23:09:28,750 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2014-02-03 23:09:28,750 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:09:28,750 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000070001961 and type 'MEDIA_ITEM' received
2014-02-03 23:09:28,750 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000070001961 (online)
2014-02-03 23:09:28,750 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2014-02-03 23:09:28,750 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000070001961, format MPEG_PS_PAL and profile WDTV Live
2014-02-03 23:09:28,750 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file http://192.168.0.9:8080/
2014-02-03 23:09:28,750 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_PAL
2014-02-03 23:09:28,750 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_NTSC
2014-02-03 23:09:28,750 WARN [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
2014-02-03 23:09:28,750 DEBUG [VideoDeliveryEngine] Delivering item '1000000070001961' for client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:09:28,750 DEBUG [VideoDeliveryEngine] Delivering file 'http://192.168.0.9:8080/' using transcoding
2014-02-03 23:09:28,750 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:09:28,750 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2014-02-03 23:09:28,750 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2014-02-03 23:09:28,750 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Date: Mon, 03 Feb 2014 23:09:28 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.4,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-02-03 23:09:29,171 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2014-02-03 23:09:29,171 DEBUG [TimeoutStreamDelegator] Scheduling stream stop to happen in 20 seconds if there is no traffic
2014-02-03 23:09:30,062 DEBUG [SearchManager] Committing search index
2014-02-03 23:09:33,093 DEBUG [ServiioHttpService] Incoming request from /192.168.0.4:34149: GET /resource/1000000070001961/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.0.9:8895,Accept: */*,Range: bytes=0-]]
2014-02-03 23:09:33,093 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2014-02-03 23:09:33,109 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:09:33,109 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000070001961 and type 'MEDIA_ITEM' received
2014-02-03 23:09:33,109 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000070001961 (online)
2014-02-03 23:09:33,109 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2014-02-03 23:09:33,109 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000070001961, format MPEG_PS_PAL and profile WDTV Live
2014-02-03 23:09:33,109 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file http://192.168.0.9:8080/
2014-02-03 23:09:33,109 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_PAL
2014-02-03 23:09:33,109 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_NTSC
2014-02-03 23:09:33,109 WARN [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
2014-02-03 23:09:33,109 DEBUG [VideoDeliveryEngine] Delivering item '1000000070001961' for client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:09:33,109 DEBUG [VideoDeliveryEngine] Delivering file 'http://192.168.0.9:8080/' using transcoding
2014-02-03 23:09:33,109 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:09:33,109 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2014-02-03 23:09:33,109 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2014-02-03 23:09:33,109 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Date: Mon, 03 Feb 2014 23:09:33 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.4,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-02-03 23:09:33,109 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2014-02-03 23:09:33,109 DEBUG [TimeoutStreamDelegator] Scheduling stream stop to happen in 20 seconds if there is no traffic
2014-02-03 23:10:00,062 DEBUG [SearchManager] Committing search index
2014-02-03 23:10:20,171 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2014-02-03 23:10:20,171 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-02-03 23:10:20,187 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2014-02-03 23:10:30,062 DEBUG [SearchManager] Committing search index
2014-02-03 23:11:00,062 DEBUG [SearchManager] Committing search index
2014-02-03 23:11:20,187 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2014-02-03 23:11:20,187 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-02-03 23:11:20,187 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2014-02-03 23:11:30,062 DEBUG [SearchManager] Committing search index
2014-02-03 23:11:49,609 DEBUG [ServiioHttpService] Incoming request from /192.168.0.4:34150: GET /resource/1000000070001961/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks,Host: 192.168.0.9:8895,Accept: */*,Range: bytes=0-1023]]
2014-02-03 23:11:49,609 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2014-02-03 23:11:49,609 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:11:49,609 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000070001961 and type 'MEDIA_ITEM' received
2014-02-03 23:11:49,609 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000070001961 (online)
2014-02-03 23:11:49,609 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2014-02-03 23:11:49,609 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000070001961, format MPEG_PS_PAL and profile WDTV Live
2014-02-03 23:11:49,609 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file http://192.168.0.9:8080/
2014-02-03 23:11:49,609 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_PAL
2014-02-03 23:11:49,609 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_NTSC
2014-02-03 23:11:49,609 WARN [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
2014-02-03 23:11:49,609 DEBUG [VideoDeliveryEngine] Delivering item '1000000070001961' for client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:11:49,609 DEBUG [VideoDeliveryEngine] Delivering file 'http://192.168.0.9:8080/' using transcoding
2014-02-03 23:11:49,609 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:11:49,609 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2014-02-03 23:11:49,609 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2014-02-03 23:11:49,609 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Date: Mon, 03 Feb 2014 23:11:49 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.4,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-02-03 23:11:49,750 DEBUG [ServiioHttpService] Incoming request from /192.168.0.4:34151: HEAD /resource/1000000070001961/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.0.9:8895,Accept: */*]]
2014-02-03 23:11:49,750 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2014-02-03 23:11:49,750 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:11:49,750 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000070001961 and type 'MEDIA_ITEM' received
2014-02-03 23:11:49,750 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000070001961 (online)
2014-02-03 23:11:49,750 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2014-02-03 23:11:49,750 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000070001961, format MPEG_PS_PAL and profile WDTV Live
2014-02-03 23:11:49,750 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file http://192.168.0.9:8080/
2014-02-03 23:11:49,750 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_PAL
2014-02-03 23:11:49,750 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_NTSC
2014-02-03 23:11:49,750 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Date: Mon, 03 Feb 2014 23:11:49 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.4,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-02-03 23:11:49,750 DEBUG [ServiioHttpService] Incoming request from /192.168.0.4:34151: GET /resource/1000000070001961/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.0.9:8895,Accept: */*,Range: bytes=0-]]
2014-02-03 23:11:49,750 WARN [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
2014-02-03 23:11:49,765 DEBUG [VideoDeliveryEngine] Delivering item '1000000070001961' for client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:11:49,765 DEBUG [VideoDeliveryEngine] Delivering file 'http://192.168.0.9:8080/' using transcoding
2014-02-03 23:11:49,765 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:11:49,984 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2014-02-03 23:11:49,984 DEBUG [TimeoutStreamDelegator] Scheduling stream stop to happen in 20 seconds if there is no traffic
2014-02-03 23:11:50,765 DEBUG [StreamBasedTranscodingDeliveryStrategy] Transcoded stream is empty, connection may have been lost
2014-02-03 23:11:50,765 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_PAL
2014-02-03 23:11:50,765 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_NTSC
2014-02-03 23:11:50,765 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2014-02-03 23:11:50,765 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2014-02-03 23:11:50,765 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Date: Mon, 03 Feb 2014 23:11:50 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.4,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-02-03 23:11:50,859 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2014-02-03 23:11:50,859 DEBUG [TimeoutStreamDelegator] Scheduling stream stop to happen in 20 seconds if there is no traffic
2014-02-03 23:11:51,343 DEBUG [ServiioHttpService] Incoming request from /192.168.0.4:34152: GET /resource/1000000070001961/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.0.9:8895,Accept: */*,Range: bytes=0-]]
2014-02-03 23:11:51,343 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2014-02-03 23:11:51,359 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2014-02-03 23:11:51,359 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:11:51,359 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000070001961 and type 'MEDIA_ITEM' received
2014-02-03 23:11:51,359 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000070001961 (online)
2014-02-03 23:11:51,359 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2014-02-03 23:11:51,359 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000070001961, format MPEG_PS_PAL and profile WDTV Live
2014-02-03 23:11:51,359 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file http://192.168.0.9:8080/
2014-02-03 23:11:51,359 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_PAL
2014-02-03 23:11:51,359 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_NTSC
2014-02-03 23:11:51,359 WARN [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
2014-02-03 23:11:51,359 DEBUG [VideoDeliveryEngine] Delivering item '1000000070001961' for client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:11:51,359 DEBUG [VideoDeliveryEngine] Delivering file 'http://192.168.0.9:8080/' using transcoding
2014-02-03 23:11:51,359 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:11:51,359 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2014-02-03 23:11:51,359 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2014-02-03 23:11:51,359 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Date: Mon, 03 Feb 2014 23:11:51 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.4,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-02-03 23:11:51,546 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2014-02-03 23:11:51,546 DEBUG [TimeoutStreamDelegator] Scheduling stream stop to happen in 20 seconds if there is no traffic
2014-02-03 23:11:55,671 DEBUG [ServiioHttpService] Incoming request from /192.168.0.4:34153: GET /resource/1000000070001961/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.0.9:8895,Accept: */*,Range: bytes=0-]]
2014-02-03 23:11:55,671 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2014-02-03 23:11:55,671 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:11:55,671 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000070001961 and type 'MEDIA_ITEM' received
2014-02-03 23:11:55,671 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000070001961 (online)
2014-02-03 23:11:55,671 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2014-02-03 23:11:55,671 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000070001961, format MPEG_PS_PAL and profile WDTV Live
2014-02-03 23:11:55,671 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file http://192.168.0.9:8080/
2014-02-03 23:11:55,671 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_PAL
2014-02-03 23:11:55,671 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_NTSC
2014-02-03 23:11:55,671 WARN [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
2014-02-03 23:11:55,671 DEBUG [VideoDeliveryEngine] Delivering item '1000000070001961' for client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:11:55,687 DEBUG [VideoDeliveryEngine] Delivering file 'http://192.168.0.9:8080/' using transcoding
2014-02-03 23:11:55,687 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:11:55,687 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_PAL
2014-02-03 23:11:55,687 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_NTSC
2014-02-03 23:11:55,687 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2014-02-03 23:11:55,687 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2014-02-03 23:11:55,687 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Date: Mon, 03 Feb 2014 23:11:55 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.4,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-02-03 23:11:55,859 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2014-02-03 23:11:55,859 DEBUG [TimeoutStreamDelegator] Scheduling stream stop to happen in 20 seconds if there is no traffic
2014-02-03 23:12:00,062 DEBUG [ServiioHttpService] Incoming request from /192.168.0.4:34154: GET /resource/1000000070001961/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.0.9:8895,Accept: */*,Range: bytes=0-]]
2014-02-03 23:12:00,062 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2014-02-03 23:12:00,062 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:12:00,062 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000070001961 and type 'MEDIA_ITEM' received
2014-02-03 23:12:00,062 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000070001961 (online)
2014-02-03 23:12:00,062 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2014-02-03 23:12:00,062 DEBUG [SearchManager] Committing search index
2014-02-03 23:12:00,062 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000070001961, format MPEG_PS_PAL and profile WDTV Live
2014-02-03 23:12:00,062 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file http://192.168.0.9:8080/
2014-02-03 23:12:00,062 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_PAL
2014-02-03 23:12:00,062 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://192.168.0.9:8080/: MPEG_PS_NTSC
2014-02-03 23:12:00,062 WARN [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
2014-02-03 23:12:00,062 DEBUG [VideoDeliveryEngine] Delivering item '1000000070001961' for client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:12:00,062 DEBUG [VideoDeliveryEngine] Delivering file 'http://192.168.0.9:8080/' using transcoding
2014-02-03 23:12:00,062 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.0.4, Profile=WDTV Live'
2014-02-03 23:12:00,062 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2014-02-03 23:12:00,062 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2014-02-03 23:12:00,062 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Date: Mon, 03 Feb 2014 23:12:00 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.4,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-02-03 23:12:00,078 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2014-02-03 23:12:00,078 DEBUG [TimeoutStreamDelegator] Scheduling stream stop to happen in 20 seconds if there is no traffic
2014-02-03 23:12:20,187 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2014-02-03 23:12:20,187 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-02-03 23:12:20,187 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
[/list]
Post Tue Feb 04, 2014 8:00 pm
The range header should not be there, as Serviio tells the device it's not supported. I'm not sure if that is the reason. Does this stream work for you? viewtopic.php?f=41&t=4689
Users browsing this forum: No registered users and 52 guests
