TX-P55VT50Y, problems with reading files
Punnaniboy
Post Wed Feb 05, 2014 6:08 pm
Hi guys!
I`m not all into this decoding stuff, but I`m having trouble playing alot of files on my TV: TX-P55VT50Y
I can confirm that the problems are with *.mp4 files, I also have trouble with subtitles on my *.mkv files.
The problem with the *.mp4 files has occured after latest patch\update from panasonic, worked as a dream before and all files where playable.
TV sends message, please wait... 2 minutes later, cannot read file..
Can any of you guys with a similar TV give me a howto or a file to replace?
Thx in advance.
Punnaniboy
Post Wed Feb 05, 2014 6:56 pm
Re: TX-P55VT50Y, problems with reading files
Latest log:
[Parsed_subtitles_0 @ 00000000027abb80] Unable to open D:/download/filmer/Iron Man 3 (2013) [1080p]/Iron.Man.3.2013.1080p.BluRay.x264.YIFY.srt
[AVFilterGraph @ 00000000027b1e00] Error initializing filter 'subtitles' with args 'filename=D\:/download/filmer/Iron Man 3 (2013) [1080p]/Iron.Man.3.2013.1080p.BluRay.x264.YIFY.srt:original_size=1920x800:charenc=UTF-8'
Error opening filters!
2014-02-05 19:54:33,378 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2014-02-05 19:54:43,254 DEBUG [TranscodingJobListener] Deleted temp file 'C:\Windows\TEMP\Serviio\transcoding-temp-2466-viera2011-ORIGINAL-82c1a3543656ca59d81af52cee1a1af4.stf': true
2014-02-05 19:54:43,255 DEBUG [AbstractTranscodingDeliveryEngine] Removing transcoding listener with id transcoding-temp-2466-viera2011-ORIGINAL-82c1a3543656ca59d81af52cee1a1af4.stf
2014-02-05 19:54:43,255 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:49)
at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:134)
at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:110)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:153)
at org.serviio.delivery.GETMethodProcessor.retrieveResource(GETMethodProcessor.java:121)
at org.serviio.delivery.GETMethodProcessor.buildDeliveryContainer(GETMethodProcessor.java:48)
at org.serviio.delivery.AbstractMethodProcessor.handleRequest(AbstractMethodProcessor.java:100)
at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:81)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:86)
at org.serviio.upnp.webserver.ServiioHttpService.doService(ServiioHttpService.java:77)
2014-02-05 19:54:44,263 DEBUG [ServiioHttpService] Incoming request from /192.168.0.9:59992: GET /resource/2466/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.0.4:8895,TimeSeekRange.dlna.org: npt=00:00:00.000-,transferMode.dlna.org: Streaming,Connection: keep-alive]]
2014-02-05 19:54:44,264 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2014-02-05 19:54:44,265 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.9, Profile=Panasonic Viera E/S/ST/VT (2011)'
2014-02-05 19:54:44,265 DEBUG [ResourceDeliveryProcessor] Request for resource 2466 and type 'MEDIA_ITEM' received
2014-02-05 19:54:44,265 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2466 (local)
2014-02-05 19:54:44,265 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2466)
2014-02-05 19:54:44,266 DEBUG [VideoDAOImpl] Reading a Video (id = 2466)
2014-02-05 19:54:44,267 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 2466, format MPEG_PS_PAL and profile Panasonic Viera E/S/ST/VT (2011)
2014-02-05 19:54:44,267 DEBUG [MediaItemDAOImpl] Getting file of media item 2466
2014-02-05 19:54:44,268 DEBUG [SubtitlesService] Found external subtitle file: D:\download\filmer\Iron Man 3 (2013) [1080p]\Iron.Man.3.2013.1080p.BluRay.x264.YIFY.srt
2014-02-05 19:54:44,268 DEBUG [MediaItemDAOImpl] Getting file of media item 2466
2014-02-05 19:54:44,268 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Iron.Man.3.2013.1080p.BluRay.x264.YIFY.mp4
2014-02-05 19:54:44,269 DEBUG [MediaItemDAOImpl] Getting file of media item 2466
2014-02-05 19:54:44,269 DEBUG [SubtitlesService] Found external subtitle file: D:\download\filmer\Iron Man 3 (2013) [1080p]\Iron.Man.3.2013.1080p.BluRay.x264.YIFY.srt
2014-02-05 19:54:44,269 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Iron.Man.3.2013.1080p.BluRay.x264.YIFY.mp4: MPEG_PS_PAL
2014-02-05 19:54:44,269 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Iron.Man.3.2013.1080p.BluRay.x264.YIFY.mp4: MPEG_PS_NTSC
2014-02-05 19:54:44,269 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2466 (local)
2014-02-05 19:54:44,270 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2466)
2014-02-05 19:54:44,270 DEBUG [VideoDAOImpl] Reading a Video (id = 2466)
2014-02-05 19:54:44,271 DEBUG [VideoDeliveryEngine] Delivering item '2466' for client 'Identifier=192.168.0.9, Profile=Panasonic Viera E/S/ST/VT (2011)'
2014-02-05 19:54:44,271 DEBUG [MediaItemDAOImpl] Getting file of media item 2466
2014-02-05 19:54:44,272 DEBUG [SubtitlesService] Found external subtitle file: D:\download\filmer\Iron Man 3 (2013) [1080p]\Iron.Man.3.2013.1080p.BluRay.x264.YIFY.srt
2014-02-05 19:54:44,272 DEBUG [MediaItemDAOImpl] Getting file of media item 2466
2014-02-05 19:54:44,272 DEBUG [VideoDeliveryEngine] Delivering file 'Iron.Man.3.2013.1080p.BluRay.x264.YIFY.mp4' using transcoding
2014-02-05 19:54:44,273 DEBUG [SubtitlesService] Found external subtitle file: D:\download\filmer\Iron Man 3 (2013) [1080p]\Iron.Man.3.2013.1080p.BluRay.x264.YIFY.srt
2014-02-05 19:54:44,273 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.0.9, Profile=Panasonic Viera E/S/ST/VT (2011)'
2014-02-05 19:54:44,274 DEBUG [MediaItemDAOImpl] Getting file of media item 2466
2014-02-05 19:54:44,274 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: D:\download\filmer\Iron Man 3 (2013) [1080p]\Iron.Man.3.2013.1080p.BluRay.x264.YIFY.mp4
2014-02-05 19:54:44,275 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -threads 8 -i D:\download\filmer\Iron Man 3 (2013) [1080p]\Iron.Man.3.2013.1080p.BluRay.x264.YIFY.mp4 -y -threads 8 -c:v mpeg2video -pix_fmt yuv420p -qscale:v 1 -vf subtitles=filename="D\\:/download/filmer/Iron Man 3 (2013) \[1080p\]/Iron.Man.3.2013.1080p.BluRay.x264.YIFY.srt":original_size=1920x800:charenc=UTF-8 -r 24000/1001 -g 15 -c:a ac3 -b:a 384k -ac 2 -map 0:0 -map 0:1 -sn -f vob C:\Windows\TEMP\Serviio\transcoding-temp-2466-viera2011-ORIGINAL-82c1a3543656ca59d81af52cee1a1af4.stf
2014-02-05 19:54:44,384 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error. Detailed output follows.
creation_time : 2013-08-20 05:03:20
handler_name : GPAC ISO Audio Handler
[Parsed_subtitles_0 @ 00000000026dbb80] Unable to open D:/download/filmer/Iron Man 3 (2013) [1080p]/Iron.Man.3.2013.1080p.BluRay.x264.YIFY.srt
[AVFilterGraph @ 00000000026e1e00] Error initializing filter 'subtitles' with args 'filename=D\:/download/filmer/Iron Man 3 (2013) [1080p]/Iron.Man.3.2013.1080p.BluRay.x264.YIFY.srt:original_size=1920x800:charenc=UTF-8'
2014-02-05 19:54:44,384 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2014-02-05 19:54:53,394 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2014-02-05 19:54:53,394 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-02-05 19:54:54,276 DEBUG [TranscodingJobListener] Deleted temp file 'C:\Windows\TEMP\Serviio\transcoding-temp-2466-viera2011-ORIGINAL-82c1a3543656ca59d81af52cee1a1af4.stf': true
2014-02-05 19:54:54,277 DEBUG [AbstractTranscodingDeliveryEngine] Removing transcoding listener with id transcoding-temp-2466-viera2011-ORIGINAL-82c1a3543656ca59d81af52cee1a1af4.stf
2014-02-05 19:54:54,277 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
Media info:
Complete name : D:\download\filmer\Iron Man 3 (2013) [1080p]\Iron.Man.3.2013.1080p.BluRay.x264.YIFY.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 1.95 GiB
Duration : 2h 10mn
Overall bit rate : 2 141 Kbps
Encoded date : UTC 2013-08-20 05:02:57
Tagged date : UTC 2013-08-20 05:02:57
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 2h 10mn
Bit rate : 2 043 Kbps
Maximum bit rate : 13.2 Mbps
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.055
Stream size : 1.86 GiB (95%)
Writing library : x264 core 132 r2 76a5c3a
Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=36 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=2043 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=31250 / vbv_bufsize=31250 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Tagged date : UTC 2013-08-20 05:03:22
Color primaries : BT.709
Matrix coefficients : BT.709
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 2h 10mn
Bit rate mode : Variable
Bit rate : 93.8 Kbps
Maximum bit rate : 104 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 87.6 MiB (4%)
Language : English
Encoded date : UTC 2013-08-20 05:03:20
Punnaniboy
Post Wed Feb 05, 2014 7:02 pm
Ah I see what i did there, but by removing the srt files for the movie it plays...
any workaround on howto get the subtitle working?
Post Wed Feb 05, 2014 10:51 pm
First ensure that the srt file is OK. Run it through srtWiz and see if that helps: viewtopic.php?f=17&t=2971
Although a positive response doesn't mean much, does the file play with subs on your PC?
Punnaniboy
Post Thu Feb 06, 2014 8:34 am
Runs ok on computer with srt files.
What is the deal with *.mkv files and srt subfiles and streaming? Not compatible?
Post Thu Feb 06, 2014 9:09 am
Depends on the TV. Many Panasonics only support embedded subs with MKV's. Try embedding the sub using MKVMerge or similar tool.
But... I thought we were dealing with the MP4 file above?? Is that now working?
Punnaniboy
Post Thu Feb 06, 2014 11:03 am
mp4 files working when removing srt files from video file folder.
Post Sat Feb 08, 2014 11:19 pm
The VT50 doesn't support subs natively on MP4 files - you need to enable "Enable burned-in sub-titles", "Only when required" in Serviio Console for these.
I'm pretty sure that subs for MKV's are only supported by the VT50 if embedded within the MKV container ie. separate srt files are not supported, use MKVMerge to embed the sub.
Return to Panasonic
