AirPlayer not fast forwarding
vfrans
Post Wed Jan 29, 2014 9:22 pm
Hello everyone!
I've been using serviio for a couple of days now, works flawlessly!
Except AirPlayer on my iPad. I reads the file ok but the only problem is that I can't fast forward in it.
There's a slider at the top of the screen so that you can select the position you want in the video if you slide it, it'll just reset to your current position.
Also tried with ACE Player, the slider does not even appear.
With the dlna server i was using previously (UMS), it was working without any problem.
I find serviio much more stable and powerfull than any other dlna server and i'd like to stick with it!
Thanks a lot for your help,
Regards
gaztop26
Post Thu Feb 06, 2014 6:07 pm
Re: AirPlayer not fast forwarding
Hi all,
I would like to get this working fast forwarding and rewinding issue sorted as well.
gaztop26
Post Thu Feb 06, 2014 8:58 pm
Sorted and solved, it wasn't a serviio issue it was with the air player settings! I just went to settings and switched everything for the device on, and now it all works. :)
vfrans
Post Fri Feb 07, 2014 5:50 am
Wow thanks!
It indeed works!
However, for me it worked after setting ffmpeg as plugin.
The only drwaback is that now, video is lagging pretty hard :(
I guess, i'll stick with mediabrowser since it work pretty good.
Return to User experiences
