SKYSPORTSPLUS - A SPORTS STREAM WEBRESOURCE
This is not working in Belgium ....
Re: SKYSPORTSPLUS - A SPORTS STREAM WEBRESOURCE
Wont cooperate for me.
I see the folder that I named SKY Sports in Serviio online Resources, but when I click on the folder it states "There is no playable file" .
Attached is a screen shot of my Serviio setup.
Regards!
Device: Sony Media Player SMP-N100
Win7 Dual Core 2.9GHz
3GBR
Malwarebytes Anti-Spyware
BitDefender Total Security
Serviio allowed in all security software
3GBR
hi guys I am hoping someone can help me please. I have installed the pluggin and set everything up regarding the 1st post. However I cant see any listings at all I ahve attached my settings...could some one tell me where i am going wrong please.
Lol...well you see I posted in Feb 2014 asking the same question and 7 months later her you are!
I really don't think the guy who posted the plugin is intrested anymore.
If you figure it out pass it on...good luck!
Regards!
3GBR
3GBR
As posted previously:
Unfortunately, the improved version requires modifications that Serviio does not support, as well as access to tokens which are well hidden and generally unaccessable.
I can only suggest that you play the event on your pc and stream the desktop to your tv using vlc as posted elsewhere in the forum and wiki.
They have switched to some servers the plugin cannot decode. Hopefully I will post an improved version with Serviio 1.3
