Samsung UE40B7000 profile
gandalf_69
Post Thu Jan 23, 2014 2:24 pm
Hello everiboby,
I need help about a correct profile for my Samsung TV UE40B7000. By selecting a profile (in Serviio console) for B series I don't hear any audio (such as DTS, AC3 or other). By switching on A series profile the audio is correct.
Can you help me for selecting or adding a new profile for these video type:
* MKV
* AVI
* MPEG
* MOV from Canon camera
and audio type:
* DTS
* AC3
* mp3
* audio from Canon video
Can anyone help me ?
Can you suggest to me a new configuration for my Smsung TV ?
Thanks in advance.
gandalf_69
Post Mon Feb 03, 2014 1:36 pm
Re: Samsung UE40B7000 profile
Many thanks !
Post Mon Feb 03, 2014 9:42 pm
User Duktok had a similar problem which we solved by using the Samsung B profile, but we changed all occurrences of targetACodec="ac3" to targetACodec="mp3". See viewtopic.php?f=10&t=15640#p86596 for more detail.
Remember to restart your PC after changing profiles.xml.
ps. not in front of my Serviio PC at the moment so cannot confirm this will cover all your cases, but give it a try.
gandalf_69
Post Wed Feb 05, 2014 4:09 pm
Thanks a lot !
Add for transcode Canon camera MOV file ?
Any suggestion ?
Post Wed Feb 05, 2014 10:04 pm
Please post MediaInfo details for the file, see viewtopic.php?f=5&t=4510.
gandalf_69
Post Thu Feb 06, 2014 11:24 am
This is a post from mediainfo informations:
File name: MVI_2409.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 1.07 GiB
Duration : 6mn 11s
Overall bit rate : 24.7 Mbps
Encoded date : UTC 2013-12-20 17:00:02
Tagged date : UTC 2013-12-20 17:00:02
Format : AVC
Format profile : Baseline@L4.1
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=15
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 6mn 11s
Bit rate : 23.3 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 30.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.841
Stream size : 1.01 GiB (94%)
Language : English
Color primaries : BT.709
Matrix coefficients : BT.601
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : sowt
Duration : 6mn 11s
Bit rate mode : Constant
Bit rate : 1 411.2 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Bit depth : 16 bits
Stream size : 62.5 MiB (6%)
Language : English
Please help me.
Many thans in advance.
Post Thu Feb 06, 2014 11:59 am
This should be getting transcoded by Serviio, so not sure what is happening. What are you experiencing?
Try switching to the Generic Profile and seeing if this file plays.
gandalf_69
Post Thu Feb 06, 2014 2:03 pm
Sorry, I've tested the Canon MOV file with the preview audio modifications (changed all occurrences of targetACodec="ac3" to targetACodec="mp3") and all works correctly.
I've another audio problem with this avi file (see below mediainfo text):
Complete name : WD - La bella addormentata nel bosco.avi
Format : AVI
File size : 1.09 GiB
Duration : 1h 12mn
Overall bit rate : 2 170 Kbps
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 1
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (MPEG)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 12mn
Bit rate : 1 613 Kbps
Width : 656 pixels
Height : 256 pixels
Display aspect ratio : 2.563
Frame rate : 25.000 fps
Color space : YUV
Bit depth : 8 bits
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.384
Stream size : 832 MiB (74%)
Title : La bella addormentata nel bosco
Writing library : XviD 1.2.0.dev47 (UTC 2006-11-01)
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 2000
Duration : 1h 12mn
Bit rate : 448 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 231 MiB (21%)
Alignment : Aligned on interleaves
Interleave, duration : 64 ms (1.60 video frames)
Interleave, preload duration : 192 ms
Title : Italiano
Audio #2
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 12mn
Bit rate mode : Variable
Bit rate : 96.0 Kbps
Stream size : 47.8 MiB (4%)
Interleave, duration : 24 ms (0.60 video frame)
Interleave, preload duration : 91 ms
Title : English
Writing library : LAME3.98
Encoding settings : -m j -V 4 -q 3 -lowpass 15.1 --abr 96
It seems that this video file have two audio trace. Can you say something about this malfunctions ? What changes I do in profiles.xml file for hear a audio trace ?
Thanks in advance
Post Thu Feb 06, 2014 11:31 pm
Serviio only acts on the first audio track. In this case there is no handler for AC-3, so the video is being sent asis to your TV (which cannot decode AC-3, and it fails),
Try the following, add the line:
<Matches container="avi" aCodec="ac3"  />
before the line
Not sure if this will work as its will try and package xvid video in an mts container. If it fails, move the line further down, just before the existing line: <Matches container="avi" vCodec="mjpeg" />
gandalf_69
Post Mon Feb 10, 2014 12:57 pm
Hello, move the line further down, just before the existing line: <Matches container="avi" vCodec="mjpeg" /> all work correctly.
I have another question about another series of flims. Please see the Mediainfo data below:
Complete name : F:\Film C.ANIMATI\WD - Le avventure di Winnie the Pooh.avi
Format : AVI
Duration : 1h 10mn
Overall bit rate : 2 204 Kbps
Format settings, BVOP : 2
Codec ID : DX50
Codec ID/Hint : DivX 5
Duration : 1h 10mn
Bit rate : 1 971 Kbps
Width : 512 pixels
Height : 384 pixels
Display aspect ratio : 4:3
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.401
Stream size : 1 000 MiB (89%)
Title : Video
Audio #1
Format : MPEG Audio
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 10mn
Bit rate : 122 Kbps
Nominal bit rate : 144 Kbps
Sampling rate : 32.0 KHz
Stream size : 61.7 MiB (6%)
Interleave, duration : 36 ms (0.90 video frame)
Interleave, preload duration : 92 ms
Title : iTALiAN
Encoding settings : -m j -V 4 -q 2 -lowpass 16 --abr 144
Audio #2
Format : MPEG Audio
Format version : Version 2
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 10mn
Bit rate : 93.7 Kbps
Nominal bit rate : 116 Kbps
Sampling rate : 22.05 KHz
Stream size : 47.6 MiB (4%)
Interleave, duration : 26 ms (0.65 video frame)
Interleave, preload duration : 106 ms
Title : ENGLiSH
Encoding settings : -m j -V 4 -q 2 -lowpass 11 --abr 116
All films with these audio characteristics you do not hear the audio, on TV scrren appear the indication "Audio data non supported".
Can you help me ? For my little son is much important :)
Also is not possible to do, when Serviio server transcoding all audio trace to amplify the audio at 0db (because some audio trace are too low) ?
I'm waiting your precious help and excuse me if i reply continuosly with some problem, but I'am putting in place my DLNA server with Serviio for watch all my videos.
Thanks a lot.
Post Mon Feb 10, 2014 11:42 pm
Not sure - this should be presented to your TV natively (you can confirm this by viewing a detailed log), so it is something your TV doesn't like.
It may be the fact that it has dual audio tracks. Try removing one using the command (from the command prompt type - assuming you're a Windows user):
"C:\Program Files\Serviio\lib\ffmpeg.exe" -i "F:\Film C.ANIMATI\WD - Le avventure di Winnie the Pooh.avi" -vcodec copy -acodec copy "F:\Film C.ANIMATI\WD - Le avventure di Winnie the Pooh TEST.avi"
and see if the resultant file plays (this should only copy the first audio track only - the Italian track. Please check with MediaInfo). Let me know how this goes - if it doesn't work we may need to re-encode the audio. Please take note of any errors or warnings when running the above command.
gandalf_69
Post Tue Feb 11, 2014 1:10 pm
By deleting the second audio trace (in english) the video work corrctly, I hear the italian audio trace.
But I have another film with a single audio mp3 trace and my TV doesn't reply this. Now my question is, it is possible to do at Serviio the transcoding for all audio trace in one only audio format audible from my Samsung TV ?
I see from the previous changes, that when I do to Serviio a transcoding audio (DTS or AC3) in mp3 the audio works correctly.
I want to try this way, if it is possible.
Can you say to me the profiles.xml changes to do this work ?
NOTE: as for my previous post I want to do at Servvio (between it transcoding audio trace) amplify audio trace at 0db for most videos that have audio too low.
I'm waiting your precious help.
Thanks in advance
Post Tue Feb 11, 2014 1:31 pm
The problem is that the audio track is already in the format your TV should understand (ie. in MP3). There is no way to force Serviio to re-encode the audio from MP3 to MP3.
It could simply be that this is a bad encode of the video (and by bad, I simply mean something that your Samsung doesn't like). Try using the ffmpeg command from my previous post (changing file names), that often fixes this problem.
There is no way to increase the volume when transcoding in Serviio that I know of. Not sure if forcing it to stereo (from Serviio Console or in the profile) or changing the audio bit rate will help, you would need to play with it: have a read of http://www.serviio.org/index.php?option ... icle&id=24 which will give you the options for stereo and audio bit rate (I doubt this will help though - anything's possible).
gandalf_69
Post Fri Feb 14, 2014 8:01 pm
Sorry, but I have another problem, please see Mediainfo report below:
Complete name : F:\Film C.ANIMATI\WD - Cenerentola.mkv
Format : Matroska
File size : 2.19 GiB
Duration : 1h 14mn
Overall bit rate : 4 205 Kbps
Encoded date : UTC 2012-09-25 12:14:11
Writing application : mkvmerge v5.8.0 ('No Sleep / Pillow') built on Sep 2 2012 15:37:04
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 14mn
Bit rate : 2 037 Kbps
Width : 1 452 pixels
Height : 1 080 pixels
Frame rate : 23.976 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.054
Stream size : 1.03 GiB (47%)
Title : Cinderella
Writing library : x264 core 125 r2200 999b753
Encoding settings : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=2037 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Audio #1
Format : DTS
Mode : 16
Codec ID : A_DTS
Duration : 1h 14mn
Bit rate : 1 509 Kbps
Bit depth : 24 bits
Stream size : 804 MiB (36%)
Title : DTS 5.1
Language : Italian
Default : Yes
Forced : No
Audio #2
Format : AC-3
Codec ID : A_AC3
Duration : 1h 14mn
Bit rate : 640 Kbps
Bit depth : 16 bits
Stream size : 341 MiB (15%)
Title : Dolby Digital 5.1
Language : English
Default : No
Forced : No
Text #1
Format : VobSub
Codec ID : S_VOBSUB
Codec ID/Info : The same subtitle format used on DVDs
Title : forced
Language : Italian
Default : Yes
Forced : Yes
Text #2
Format : VobSub
Codec ID : S_VOBSUB
Title : Italiano
Language : Italian
Default : No
Forced : No
Text #3
Format : VobSub
Codec ID : S_VOBSUB
Title : English
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : it:Chapter 01
00:01:23.166 : it:Chapter 02
00:04:20.718 : it:Chapter 03
00:07:37.415 : it:Chapter 04
00:10:15.239 : it:Chapter 05
00:13:29.141 : it:Chapter 06
00:17:39.308 : it:Chapter 07
00:22:07.826 : it:Chapter 08
00:23:32.953 : it:Chapter 09
00:26:05.730 : it:Chapter 10
00:27:55.173 : it:Chapter 11
00:31:00.149 : it:Chapter 12
00:33:32.510 : it:Chapter 13
00:36:49.040 : it:Chapter 14
00:38:55.708 : it:Chapter 15
00:42:02.102 : it:Chapter 16
00:44:11.982 : it:Chapter 17
00:48:23.108 : it:Chapter 18
00:52:54.171 : it:Chapter 19
00:56:57.122 : it:Chapter 20
01:00:42.472 : it:Chapter 21
01:04:11.097 : it:Chapter 22
01:07:34.800 : it:Chapter 23
01:13:05.714 : it:Chapter 24
In this video sometimes the audio is not syncronized with video trace and also the audio don't hear it.
I suppose that this is a problem for DTS transcoding trace. can you help me and suggest a profiles.xml rectifications ?
Thanks a lot !
gandalf_69
Post Mon Feb 17, 2014 12:04 pm
Hello Dany,
have you any news about my problem ?
Thanks so much for your help.
Post Mon Feb 17, 2014 11:42 pm
Nothing stands out for me. Maybe it is the DTS to MP3 transcode - try choosing a different audio format to transcode to (change all targetACodec="mp3" to targetACodec="lpcm" perhaps) and see if that helps.
Users browsing this forum: Google [Bot] and 7 guests
