View Active Files
mmarauder
Post Sat Feb 15, 2014 2:10 am
View Active Files
Is there a way to see what files are currently being streamed, locally and through the mediabrowser. I tried greping the logs for the file a was viewing but nothing showed up. I'm not sure if I have it on the wrong log setting. I was wondering if anyone had found a solution.
mmarauder
Post Sat Feb 15, 2014 2:49 am
Re: View Active Files
Never mind I figured it out. I had to change the log settings to debug. then I can search through the logs. I'm going to script this soon, so its easier. I'll post the once I make it.
mmarauder
Post Sat Feb 15, 2014 3:35 am
That's not really a viable option as it creates massive log files.
Return to User experiences
Users browsing this forum: Google [Bot] and 13 guests
