Transcode everything for PS3
Hi everyone, i'm very new to this transcode feature, i have a ps3 and a samsung series6 (UE46ES6900) smart TV, i would like to ask if there is a way to let serviio transcode everything for PS3, i mean, if i have something that doesn't works on my samsung i will turn on my ps3 and use that to watch without having to became mad understanding where the problem is, if is a bad codec setting, a bad audio codec, a bad container setting.. etc..
So basically:
Samsung = no transcode
PS3 = transcode all
also with that kind of setting is it possible to retain the source resolution and audio codec/channels ? i mean if i have a stereo mp3 as audio source it will be transcoded as stereo signal while if i have an ac3/DTS it will be transcoded as a 5.1 audio signal, and if i have a 1080p video it will be a 1080p or if is a 576p it will be a 576p retaining the same fps too, and interlace, etc...
is there a common universal transocde setting for ps3 that will do that kind of job?
thanks.
Honestly till now with the samsung i have problems only with mov files made with my camera, here's the file format:
maybe that's because baseline 5.0 profile ?
i've tried also remux them as mkv with no success
ps3 is much less ocmpatible than the samsung instead, the above file doesn't works on both devices...
my transcode option is ON, but the Serviio profile for samsung is "Samsung TV Player C/D Series" while on PS3 is "playstation 3", i will do more tests in the meantime, just realized my samsung is an E series so i have to change the profile.
So basically:
PS3 = transcode all
thanks.
- Code:
Complete name : G:\++PHOTOS++\2013-08-XX EMMA\MVI_0772.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 124 MiB
Duration : 29s 404ms
Overall bit rate : 35.3 Mbps
Encoded date : UTC 2013-08-08 15:53:05
Tagged date : UTC 2013-08-08 15:53:05
CNTH : ½¶óú}°`üä.à‡
com.apple.quicktime.make : Canon
com.apple.quicktime.model : Canon PowerShot S100
Format : AVC
Format profile : Baseline@L5.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate : 33.7 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.678
Stream size : 118 MiB (96%)
Language : English
Color primaries : BT.709
Matrix coefficients : BT.709
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : sowt
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 5.38 MiB (4%)
Language : English
