mkv doesn't work with ubuntu
behiz
Post Fri Feb 14, 2014 2:46 pm
Hello
I've installed serviio 1.4 on ubuntu 13.4 x64 using this http://wiki.serviio.org/doku.php?id=howto:linux:install:ubuntu and I want to play mkv files on Sony KDL40ex520 but it doesn't show the mkv files on the list.
I've also upgraded ffmpeg using this https://trac.ffmpeg.org/wiki/UbuntuCompilationGuide
this is "ffmpeg -version" command result:
ffmpeg version 2.1.git
built on Feb 14 2014 17:37:45 with gcc 4.7 (Ubuntu/Linaro 4.7.3-1ubuntu1)
configuration: --prefix=/home/behzad/ffmpeg_build --extra-cflags=-I/home/behzad/ffmpeg_build/include --extra-ldflags=-L/home/behzad/ffmpeg_build/lib --bindir=/home/behzad/bin --extra-libs=-ldl --enable-gpl --enable-libass --enable-libfdk-aac --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-nonfree --enable-x11grab
libavutil 52. 63.101 / 52. 63.101
libavcodec 55. 52.101 / 55. 52.101
libavformat 55. 32.100 / 55. 32.100
libavdevice 55. 9.100 / 55. 9.100
libavfilter 4. 1.102 / 4. 1.102
libswscale 2. 5.101 / 2. 5.101
libswresample 0. 17.104 / 0. 17.104
can anyone help me?
NX3
Post Fri Feb 14, 2014 8:29 pm
Re: mkv doesn't work with ubuntu
I'd look at the serviio wiki about how to compile ffmpeg perhaps and check what profile youve got set on serviio console. Check for Sony
Sent from my HTC One mini using Tapatalk
behiz
Post Sun Feb 16, 2014 6:03 pm
Thanks for the reply.
The profile set on the serviio console is the right model of my sony tv.
Any other solution?
NX3 wrote:I'd look at the serviio wiki about how to compile ffmpeg perhaps and check what profile youve got set on serviio console. Check for Sony
NX3
Post Sun Feb 16, 2014 8:33 pm
What profile set to though?
