Newbie question about Serviio usage
• Page 2 of 2 • 1, 2
Basically FireFox 24.3 (the newest available from my Linux distro repo) and sometimes Chrome ver 32
Re: Newbie question about Serviio usage
And if aspect ratio info is not included in TS stream, is it possible to force in profile file format 16x9 for all streamed channels?
Should be (will apply to all files), have a look in profiles.xml file for examples of how to use the DAR (display aspect ratio) profile option.
will wrote:There is a known issue with Firefox that will be fixed in 1.4.1, does Chrome have Flash built in under Linux?
Yes, I have Flash Player version 12,0,0,44 installed in Chrome
So what happens when you use MediaBrowser? (http://your-server-ip:23424/mediabrowser)
OK, got it working in Chrome! But not in FF.
One more question. I want to use Serviio ONLY for streaming from may satbox to tablet/PC over internet. So Audio/Photo/Video detailed options are unnecessary for me. It is possible to hide unnecessary for me options in Serviio console. But is effects only for ServiioGo not for mediabrowser. Is any way to hide it too?
mackowiakp wrote:OK, got it working in Chrome! But not in FF.
Firefox should work in 1.4.1 when its released (its marked as fixed in the issue tracker).
MediaBrowser doesn't use the presentation options, so no you cannot hide categories using the console. However, you can bookmark specific locations e.g. http://server-ip:23424/mediabrowser/#/b ... id=0&bid=V takes you directly to online sources (assuming you have already logged in).
Thank You VERY much for help. Now I will set-up final installation and will test stability. Nice should be use SSH....
