DLNA - Subtitles
AlexR
Post Mon Feb 17, 2014 6:37 pm
DLNA - Subtitles
I own a SONY BRAVIA 26EX550 tv and I am trying unsuccessfully to play a movie with external subtitles.
I checked every box from these settings
For some reason, when I check all three options, I can't even play the movie on my tv. When I check only the first option, I can play the movie but I can not see the external subtitles. Why is that happenning?
Post Mon Feb 17, 2014 8:19 pm
Re: DLNA - Subtitles
Could you enable detailed log , restart serviio services (or reboot PC), then check log file during the file transcoding ?
AlexR
Post Tue Feb 18, 2014 1:03 am
Thank you for the reply
I did the process you described. There are two text files inside the log folder, "derby" and "serviio". Here is their content.
derby:
Tue Feb 18 02:56:24 EET 2014:
Booting Derby version The Apache Software Foundation - Apache Derby - 10.10.1.1 - (1458268): instance a816c00e-0144-427e-68ab-ffff8366333d
on database directory C:\Program Files\Serviio\library\db with class loader sun.misc.Launcher$AppClassLoader@192d342
Loaded from file:/C:/Program%20Files/Serviio/lib/derby.jar
java.vendor=Sun Microsystems Inc.
java.runtime.version=1.6.0_39-b04
user.dir=C:\Program Files\Serviio\bin
os.name=Windows 7
os.arch=x86
os.version=6.1
derby.system.home=C:\Program Files\Serviio\bin\\..\library
derby.stream.error.file=../log/derby.log
Database Class Loader started - derby.database.classpath=''
serviio
2014-02-18 02:56:18,069 WARN  [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2014-02-18 02:56:18,069 WARN  [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2014-02-18 02:56:18,070 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2014-02-18 02:56:18,070 WARN  [IndexedDiskCache] Region [tokens] Disk cache not shutdown properly, shutting down now.
2014-02-18 02:56:18,170 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2014-02-18 02:56:18,270 INFO  [FeedUpdaterThread] Finished looking for online resources information
2014-02-18 02:56:18,370 INFO  [PluginCompilerThread] Finished looking for plugins
2014-02-18 02:56:18,474 INFO  [SearchIndexer] Closing search index writer
2014-02-18 02:56:18,497 INFO  [SearchIndexer] Closing search index writer
2014-02-18 02:56:18,513 INFO  [WebServer] WebServer shutting down
2014-02-18 02:56:18,513 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2014-02-18 02:56:18,513 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2014-02-18 02:56:18,513 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2014-02-18 02:56:18,513 INFO  [EventDispatcher] Leaving EventDispatcher
2014-02-18 02:56:18,565 INFO  [DatabaseManager] Shutting down database
2014-02-18 02:56:19,184 INFO  [RendererExpirationChecker] Leaving RendererExpirationChecker
2014-02-18 02:56:22,080 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2014-02-18 02:56:23,786 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2014-02-18 02:56:23,794 INFO  [MediaServer] ------------------------------------------------------------------------
2014-02-18 02:56:23,794 INFO  [MediaServer] Serviio DLNA media streaming server v 1.4 (rev. c307c4dd528d)
2014-02-18 02:56:23,794 INFO  [MediaServer] Petr Nejedly 2009-2013
2014-02-18 02:56:23,794 INFO  [MediaServer] http://www.serviio.org
2014-02-18 02:56:23,794 INFO  [MediaServer] Java 1.6.0_39-Sun Microsystems Inc.
2014-02-18 02:56:23,794 INFO  [MediaServer] OS Windows 7 x86 6.1
2014-02-18 02:56:23,794 INFO  [MediaServer] File encoding: windows-1253
2014-02-18 02:56:23,795 INFO  [MediaServer] Headless mode enabled: true
2014-02-18 02:56:23,795 INFO  [MediaServer] User: ALEX-PC$
2014-02-18 02:56:23,795 INFO  [MediaServer] User home dir: C:\Windows\System32\config\systemprofile
2014-02-18 02:56:23,795 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2014-02-18 02:56:23,795 INFO  [MediaServer] ------------------------------------------------------------------------
2014-02-18 02:56:23,890 INFO  [WebServer] Socket buffer set to 65535 bytes
2014-02-18 02:56:23,891 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2014-02-18 02:56:23,923 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2014-02-18 02:56:23,923 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2014-02-18 02:56:23,937 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2014-02-18 02:56:23,943 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2014-02-18 02:56:24,394 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2014-02-18 02:56:25,405 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2014-02-18 02:56:25,406 DEBUG [LocalAddressResolverStrategy] Resolving host IP address automatically
2014-02-18 02:56:25,406 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2014-02-18 02:56:25,406 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2014-02-18 02:56:25,407 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2014-02-18 02:56:25,408 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2014-02-18 02:56:25,408 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2014-02-18 02:56:25,409 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2014-02-18 02:56:25,409 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2014-02-18 02:56:25,410 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2014-02-18 02:56:25,411 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2014-02-18 02:56:25,411 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2014-02-18 02:56:25,412 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2014-02-18 02:56:25,412 DEBUG [DBLogDAOImpl] Checking if script 'script-1.1.sql' has been run
2014-02-18 02:56:25,413 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.sql' has been run
2014-02-18 02:56:25,413 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.1.sql' has been run
2014-02-18 02:56:25,415 DEBUG [DBLogDAOImpl] Checking if script 'script-1.3.sql' has been run
2014-02-18 02:56:25,415 DEBUG [DBLogDAOImpl] Checking if script 'script-1.4.sql' has been run
2014-02-18 02:56:25,423 DEBUG [LicenseValidator] Validating license file (348 bytes)
2014-02-18 02:56:25,564 INFO  [Device] Created UPnP Device with UUID: 0f101fff-14eb-3d1e-95fd-4532f1542b2a, bound address: 192.168.1.70
2014-02-18 02:56:25,594 INFO  [MediaServer] ------------------------------------------------------------------------
2014-02-18 02:56:25,595 INFO  [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2014-02-18 02:56:25,595 INFO  [MediaServer] ------------------------------------------------------------------------
2014-02-18 02:56:25,988 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2014-02-18 02:56:25,990 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2014-02-18 02:56:26,025 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2014-02-18 02:56:26,025 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2014-02-18 02:56:26,030 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2014-02-18 02:56:26,031 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2014-02-18 02:56:26,032 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2014-02-18 02:56:26,032 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2014-02-18 02:56:26,033 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2014-02-18 02:56:26,033 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2014-02-18 02:56:26,033 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2014-02-18 02:56:26,033 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2014-02-18 02:56:26,034 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2014-02-18 02:56:26,034 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_ef
2014-02-18 02:56:26,035 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2014-02-18 02:56:26,035 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2014-02-18 02:56:26,035 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2014-02-18 02:56:26,035 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2014-02-18 02:56:26,036 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2014-02-18 02:56:26,036 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2014-02-18 02:56:26,037 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2014-02-18 02:56:26,037 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2013
2014-02-18 02:56:26,038 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013)' (id=sony2013)
2014-02-18 02:56:26,038 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2012
2014-02-18 02:56:26,039 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2014-02-18 02:56:26,039 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010
2014-02-18 02:56:26,040 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2014-02-18 02:56:26,040 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010us
2014-02-18 02:56:26,040 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2014-02-18 02:56:26,040 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2011
2014-02-18 02:56:26,040 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2014-02-18 02:56:26,040 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2014-02-18 02:56:26,041 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2014-02-18 02:56:26,041 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2014-02-18 02:56:26,042 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2014-02-18 02:56:26,042 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2014-02-18 02:56:26,042 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2014-02-18 02:56:26,042 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2014-02-18 02:56:26,044 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2014-02-18 02:56:26,044 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2014-02-18 02:56:26,045 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2014-02-18 02:56:26,045 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2014-02-18 02:56:26,046 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2014-02-18 02:56:26,046 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011
2014-02-18 02:56:26,046 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2014-02-18 02:56:26,046 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2010
2014-02-18 02:56:26,046 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2014-02-18 02:56:26,046 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile plps2010
2014-02-18 02:56:26,046 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2014-02-18 02:56:26,046 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2014-02-18 02:56:26,047 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2014-02-18 02:56:26,047 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2009
2014-02-18 02:56:26,047 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2014-02-18 02:56:26,047 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 22
2014-02-18 02:56:26,047 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2014-02-18 02:56:26,047 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011a
2014-02-18 02:56:26,048 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2014-02-18 02:56:26,048 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011
2014-02-18 02:56:26,048 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2014-02-18 02:56:26,048 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2010
2014-02-18 02:56:26,048 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2014-02-18 02:56:26,048 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012us
2014-02-18 02:56:26,048 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2014-02-18 02:56:26,049 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011us
2014-02-18 02:56:26,049 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2014-02-18 02:56:26,049 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonySTR
2014-02-18 02:56:26,049 INFO  [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2014-02-18 02:56:26,049 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonyCMT
2014-02-18 02:56:26,049 INFO  [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2014-02-18 02:56:26,049 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viziotv
2014-02-18 02:56:26,050 INFO  [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2014-02-18 02:56:26,050 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile win8metro
2014-02-18 02:56:26,051 INFO  [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2014-02-18 02:56:26,051 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile panasonicBDT220
2014-02-18 02:56:26,051 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2014-02-18 02:56:26,051 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile philips_streamium
2014-02-18 02:56:26,051 INFO  [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2014-02-18 02:56:26,051 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile roku
2014-02-18 02:56:26,051 INFO  [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2014-02-18 02:56:26,051 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile YamBD
2014-02-18 02:56:26,052 INFO  [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2014-02-18 02:56:26,052 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile TNDC
2014-02-18 02:56:26,052 INFO  [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2014-02-18 02:56:26,052 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile xbox_one
2014-02-18 02:56:26,052 INFO  [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2014-02-18 02:56:26,067 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2014-02-18 02:56:26,067 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile flv_player
2014-02-18 02:56:26,067 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2014-02-18 02:56:26,067 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile ios
2014-02-18 02:56:26,067 INFO  [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2014-02-18 02:56:26,067 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_standard
2014-02-18 02:56:26,068 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2014-02-18 02:56:26,068 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo
2014-02-18 02:56:26,068 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2014-02-18 02:56:26,068 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_hls
2014-02-18 02:56:26,068 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2014-02-18 02:56:26,069 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_gtv
2014-02-18 02:56:26,069 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2014-02-18 02:56:26,069 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile wp8
2014-02-18 02:56:26,069 INFO  [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2014-02-18 02:56:26,103 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2014-02-18 02:56:26,104 INFO  [PluginCompilerThread] Started looking for plugins
2014-02-18 02:56:26,104 INFO  [UpdateChecker] Checking if a new version is available
2014-02-18 02:56:26,109 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2014-02-18 02:56:26,111 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2014-02-18 02:56:27,961 INFO  [FFMPEGWrapper] Found FFmpeg: ffmpeg version N-54096-ge41bf19 Copyright (c) 2000-2013 the FFmpeg developers
2014-02-18 02:56:27,968 DEBUG [DCRawWrapper] Invoking DCRAW to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/dcraw.exe
2014-02-18 02:56:27,968 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/dcraw.exe
2014-02-18 02:56:28,648 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2014-02-18 02:56:28,649 DEBUG [AbstractTranscodingDeliveryEngine] Deleting temporary transcoded files from: C:\Windows\TEMP\Serviio
2014-02-18 02:56:28,705 DEBUG [LocalAddressResolverStrategy] Resolving host IP address automatically
2014-02-18 02:56:28,705 INFO  [WebServer] WebServer starting on port 8895
2014-02-18 02:56:28,835 INFO  [Device] Updated bound IP address of Device with UUID: 0f101fff-14eb-3d1e-95fd-4532f1542b2a, bound address: 192.168.1.70
2014-02-18 02:56:28,855 DEBUG [DiscoveryManager] UPNP device 0f101fff-14eb-3d1e-95fd-4532f1542b2a (192.168.1.70) is available
2014-02-18 02:56:28,856 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2014-02-18 02:56:28,856 INFO  [EventDispatcher] Starting EventDispatcher
2014-02-18 02:56:28,856 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2014-02-18 02:56:28,859 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2014-02-18 02:56:28,892 INFO  [RendererSearchSender] Searching for Renderer devices
2014-02-18 02:56:28,892 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.1.70, timeout = 0
2014-02-18 02:56:28,893 DEBUG [RendererSearchSender$RendererSearchWorker] Multicasting SSDP M-SEARCH using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.1.70, timeout = 0
2014-02-18 02:56:28,902 DEBUG [RendererSearchSender$RendererSearchWorker] Sending 1 'm-search' messages
2014-02-18 02:56:28,907 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.70:57875s
2014-02-18 02:56:28,908 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.70:57875s
2014-02-18 02:56:28,939 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.1.70, timeout = 0
2014-02-18 02:56:28,939 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 0f101fff-14eb-3d1e-95fd-4532f1542b2a
2014-02-18 02:56:28,950 DEBUG [ServiioHttpService] Incoming request from /192.168.1.70:53109: GET /deviceDescription/0f101fff-14eb-3d1e-95fd-4532f1542b2a HTTP/1.1, headers = [User-Agent: Azureus 5.0.0.0,Connection: close,Accept-Encoding: gzip,Host: 192.168.1.70:8895,Accept: text/html, image/gif, image/jpeg, *; q=.2, */*; q=.2]]
2014-02-18 02:56:28,950 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.70
2014-02-18 02:56:28,977 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 0f101fff-14eb-3d1e-95fd-4532f1542b2a from 192.168.1.70 (headers = [User-Agent: Azureus 5.0.0.0,Connection: close,Accept-Encoding: gzip,Host: 192.168.1.70:8895,Accept: text/html, image/gif, image/jpeg, *; q=.2, */*; q=.2])
2014-02-18 02:56:28,977 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.70
2014-02-18 02:56:28,978 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [User-Agent: Azureus 5.0.0.0,Connection: close,Accept-Encoding: gzip,Host: 192.168.1.70:8895,Accept: text/html, image/gif, image/jpeg, *; q=.2, */*; q=.2]
2014-02-18 02:56:28,979 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.70
2014-02-18 02:56:29,155 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2014-02-18 02:56:30,776 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2014-02-18 02:56:34,902 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2014-02-18 02:56:38,987 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.1.70, timeout = 0
2014-02-18 02:56:38,988 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 0f101fff-14eb-3d1e-95fd-4532f1542b2a
2014-02-18 02:56:40,789 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2014-02-18 02:56:48,920 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.70:58773s
2014-02-18 02:56:48,921 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.70:58773
2014-02-18 02:56:48,973 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.1.70, timeout = 0
2014-02-18 02:56:48,974 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 0f101fff-14eb-3d1e-95fd-4532f1542b2a
2014-02-18 02:56:50,774 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:15 (advertisement duration is 1800 sec.)
2014-02-18 02:56:54,906 INFO  [FeedUpdaterThread] Started looking for information about online resources
2014-02-18 02:56:54,907 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2014-02-18 02:56:54,908 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2014-02-18 02:56:54,911 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-02-18 02:56:54,923 DEBUG [RepositoryDAOImpl] Reading all Repositories
2014-02-18 02:56:54,927 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2014-02-18 02:56:54,927 DEBUG [RepositoryDAOImpl] Reading all Repositories
2014-02-18 02:56:54,928 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2014-02-18 02:56:54,931 DEBUG [PlaylistDAOImpl] Reading all Playlists
2014-02-18 02:56:54,979 DEBUG [LibraryUpdatesCheckerThread] Looking for removed playlist files in repository: C:\Users\Alex\Videos\Νέος φάκελος
2014-02-18 02:56:54,979 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: C:\Users\Alex\Videos\Νέος φάκελος
2014-02-18 02:56:54,979 DEBUG [PlaylistDAOImpl] Reading Playlists for Repository (id = 1)
2014-02-18 02:56:54,980 DEBUG [LibraryAdditionsCheckerThread] Found file 'House.of.Cards.2013.S02E01.WEBRip.XviD-FUM.avi', checking if it's already in the Library
2014-02-18 02:56:54,982 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item C:\Users\Alex\Videos\Νέος φάκελος\House.of.Cards.2013.S02E01.WEBRip.XviD-FUM.avi
2014-02-18 02:56:54,982 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: C:\Users\Alex\Videos\Νέος φάκελος\House.of.Cards.2013.S02E01.WEBRip.XviD-FUM.avi, ignore case: true
2014-02-18 02:56:55,019 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: C:\Users\Alex\Videos\Νέος φάκελος
2014-02-18 02:56:55,019 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 1)
2014-02-18 02:56:55,020 DEBUG [MediaItemDAOImpl] Media item C:\Users\Alex\Videos\Νέος φάκελος\House.of.Cards.2013.S02E01.WEBRip.XviD-FUM.avi already exists in DB
2014-02-18 02:56:55,021 DEBUG [RepositoryDAOImpl] Marking Repository 1 as scanned with current timestamp
2014-02-18 02:56:55,042 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2014-02-18 02:56:55,052 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2014-02-18 02:56:55,060 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2014-02-18 02:56:55,061 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type IMAGE
2014-02-18 02:56:55,062 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1) and extractor EMBEDDED
2014-02-18 02:56:55,144 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1) and extractor COVER_IMAGE_IN_FOLDER
2014-02-18 02:56:55,146 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 1)
2014-02-18 02:56:55,166 DEBUG [RepositoryDAOImpl] Marking Repository 1 as scanned with current timestamp
2014-02-18 02:57:38,980 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /169.254.102.16:59423s
2014-02-18 02:57:38,981 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /169.254.102.16:59423
2014-02-18 02:57:39,075 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:byebye) message from Renderer 00000000-0000-1010-8000-00a096f19934 from address 169.254.102.16
2014-02-18 02:57:39,081 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /169.254.102.16:59423s
2014-02-18 02:57:39,082 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /169.254.102.16:59423
2014-02-18 02:57:39,182 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /169.254.102.16:59423s
2014-02-18 02:57:39,183 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /169.254.102.16:59423
2014-02-18 02:57:39,306 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:byebye) message from Renderer 00000000-0000-1010-8000-00a096f19934 from address 169.254.102.16
2014-02-18 02:57:39,398 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.70:58773s
2014-02-18 02:57:39,399 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.70:58773
2014-02-18 02:57:39,442 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:alive) message from Renderer 00000000-0000-1010-8000-00a096f19934 from address 169.254.102.16
2014-02-18 02:57:39,451 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 169.254.102.16
2014-02-18 02:57:39,452 DEBUG [RendererDAOImpl] Updating Renderer (uuid = 00000000-0000-1010-8000-00a096f19934, ipAddress = 169.254.102.16)
2014-02-18 02:57:39,492 DEBUG [RendererManager] Adding renderer Renderer [uuid=00000000-0000-1010-8000-00a096f19934, ipAddress=169.254.102.16, name=KDL-26EX550, profileId=sony2012, manuallyAdded=false, forcedProfile=false, enabled=true, accessGroupId=1] to list of active renderers
2014-02-18 02:57:39,681 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:alive) message from Renderer 00000000-0000-1010-8000-00a096f19934 from address 169.254.102.16
2014-02-18 02:57:44,399 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.71:44258s
2014-02-18 02:57:44,399 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.71:44258
2014-02-18 02:57:44,427 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:byebye) message from Renderer 00000000-0000-1010-8000-00a096f19934 from address 192.168.1.71
2014-02-18 02:57:44,427 DEBUG [RendererManager] Removing renderer 00000000-0000-1010-8000-00a096f19934 from list of active renderers
2014-02-18 02:57:44,499 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.71:44258s
2014-02-18 02:57:44,500 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.71:44258
2014-02-18 02:57:44,599 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.71:44258s
2014-02-18 02:57:44,600 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.71:44258
2014-02-18 02:57:44,678 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:byebye) message from Renderer 00000000-0000-1010-8000-00a096f19934 from address 192.168.1.71
2014-02-18 02:57:44,816 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:alive) message from Renderer 00000000-0000-1010-8000-00a096f19934 from address 192.168.1.71
2014-02-18 02:57:44,816 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.71
2014-02-18 02:57:44,817 DEBUG [RendererDAOImpl] Updating Renderer (uuid = 00000000-0000-1010-8000-00a096f19934, ipAddress = 192.168.1.71)
2014-02-18 02:57:44,822 DEBUG [RendererManager] Adding renderer Renderer [uuid=00000000-0000-1010-8000-00a096f19934, ipAddress=192.168.1.71, name=KDL-26EX550, profileId=sony2012, manuallyAdded=false, forcedProfile=false, enabled=true, accessGroupId=1] to list of active renderers
2014-02-18 02:57:45,054 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:alive) message from Renderer 00000000-0000-1010-8000-00a096f19934 from address 192.168.1.71
2014-02-18 02:57:48,921 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.70:58773s
2014-02-18 02:57:48,921 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.70:58773
2014-02-18 02:57:54,977 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2014-02-18 02:57:54,977 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-02-18 02:58:00,590 DEBUG [WebServer] I/O error: Connection reset
2014-02-18 02:58:48,921 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.70:58773s
2014-02-18 02:58:48,921 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.70:58773
2014-02-18 02:58:54,978 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2014-02-18 02:58:54,978 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
giovanni.anfossy
Post Fri Feb 21, 2014 1:42 am
I found the exact same problem with TV Sony Bravia TV model KDL 55HX755.
By the way, I'm using "Sony Bravia TV(2012)" profile on Serviio.
AlexR
Post Fri Feb 21, 2014 3:15 am
Anyone willing to help?
Post Fri Feb 21, 2014 4:13 am
Willing, yes - able, maybe.
You need to post a detailed log (the Serviio log) as Illico requested, but it must show you trying to play the movie with subtitles (the snippet of the log you have posted doesn't show you playing or attempting to play the file). When posting the log you would be better posting it as an attachment (zipped up if needed).
Also post MediaInfo details of the file you are having problems with. Are the subtitles embedded or located in a separate file - if the latter, is that file named the same as the movie file name (excluding the extension) and encoded as UTF-8? Also read: viewtopic.php?f=11&t=2396 which has some info on subtitle support on the Sony's.
Lastly, a hunch - try changing line in the Sony Bravia TV (2012) profile - which I presume you are using:
from
      <HardSubsTranscoding>
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="384" DAR="16:9" />
to
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="384" DAR="16:9" />
(mpegts to mpeg). Let me know how that goes. Remember to restart your PC after editing profiles.xml.
