Upgrade to 1.4 issues
zappakat
Post Fri Feb 21, 2014 9:54 am
So I got round to upgrading Serviio last night and realised this morning that I've broken it.
Although the TV can see the server, browse the folders, view the film screenshot and attempt playback it fails with a "Temporarily can not access the server. Please retry".
I'm assuming that this is a FFMPEG issue?
The log itself looks like this:-
2014-02-21 09:03:37,894 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file 'C:\Windows\TEMP\Serviio\transcoding-temp-11648-sony2010-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file 'C:\Windows\TEMP\Serviio\transcoding-temp-11648-sony2010-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:47)
at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:134)
at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:110)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:153)
at org.serviio.delivery.GETMethodProcessor.retrieveResource(GETMethodProcessor.java:121)
at org.serviio.delivery.GETMethodProcessor.buildDeliveryContainer(GETMethodProcessor.java:48)
at org.serviio.delivery.AbstractMethodProcessor.handleRequest(AbstractMethodProcessor.java:100)
at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:81)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:86)
at org.serviio.upnp.webserver.ServiioHttpService.doService(ServiioHttpService.java:77)
2014-02-21 09:04:24,393 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error. Detailed output follows.
If it is FFMPEG what's the best way to replace the version Serviio is using? I'm assuming it's the one in C:\Program Files\Serviio\Lib..
zappakat
Post Fri Feb 21, 2014 10:16 am
Re: Upgrade to 1.4 issues
So I downloaded FFMPEG ( ffmpeg-20140221-git-76dd01e-win64-static) from Zeranoe and copied across ffmpeg.exe to my Serviio lib directory and restarted the server.
Same error.
zappakat
Post Fri Feb 21, 2014 10:35 am
Fixed :D
Grumpa
Post Sun Feb 23, 2014 9:18 pm
zappakat wrote:Fixed :D
How? Elaborate please
Users browsing this forum: Google [Bot] and 33 guests
