unnable to load license
uricanezu
Post Wed Feb 26, 2014 11:52 pm
hello i've changed distributions on my server from debian to arch linux
after reinstalling serviio and webui on the new distro i am unnable to load the license file via webui , i select it click upload it says data imported but nothing happens , after refresh its the same Licensed To: ()
i've also tried from my phone with serviidroid but when i try to upload the license file the application crashes
uricanezu
Post Thu Feb 27, 2014 12:51 am
Re: unnable to load license
now its saying license file invalid when trying from serviidroid
uricanezu
Post Thu Feb 27, 2014 2:58 am
at org.serviio.ui.resources.server.LicenseUploadServerResource.save(LicenseUploadServerResource.java:35)
at org.serviio.licensing.LicensingManager.validateLicense(LicensingManager.java:123)
at org.serviio.licensing.LicenseValidator.validateProvidedLicense(LicenseValidator.java:87)
at org.serviio.licensing.LicenseValidator.validateLicense(LicenseValidator.java:113)
org.serviio.licensing.InvalidLicenseException: License failed validation these tests: The license signature can't be verified
2014-02-27 00:24:45,329 WARN [LicenseUploadServerResource] License is not stored because it's not valid: License failed validation these tests: The license signature can't be verified
Post Fri Feb 28, 2014 1:32 pm
Is the license file still in it's original state?
Check the date time on your server, is that current?
Not sure if the WebUI has a bug, try to get the latest version of that.
