hot to put serviio mediabrowser https..?
thenamelessthing
Post Thu Feb 27, 2014 4:04 am
Hi all, I know i'ts not directly related to serviio but how to put my url for mediabrowser in https (ssl)? I'm under ubuntu 12.04...
Thanks you for your help..
My Setup : BDT220 Panasonic Bluray player, TC-L55ET5 and TC-L42ET5 Panasonic TV. My home media server run Serviio 1.4.2 Pro under GNU/Linux Ubuntu 14.04 LTS server x64 and the hardware is Amd 1045t Phenom II X6, 6Gb DDR3 1333 mhz on SSD and data on soft raid 5 (3x1tb).
Post Fri Feb 28, 2014 1:34 pm
Re: hot to put serviio mediabrowser https..?
I guess you'd have to run it through a proxy server. Here could be a start: http://wiki.serviio.org/doku.php?id=ext ... xy_forward
Then just add the SSL bit.
Also try to search the forum, I think someone has done it already.
