Samsung C-Series - No Films since update to 1.4
touralou
Post Sun Mar 02, 2014 8:15 am
since the update to Windows Serviio 1.4 films are no longer found by the TV (C-series) - before everything worked fine
- Music and Image folders are found and displayed on TV
- Film folders and films can be accessed via Mediabrowser (and played via iExplore - playing does not work with Firefox)
means: Serviio database is complete and working
. via Twonky Beam App on my Android I can access Serviio Server and play films on the Samsung TV UE40C6200
but access to films directly is impossible?
Any Idea, what is missing?
Win7, Samsung TV UE40C6200
btw I can watch films via Synology DS 211j and WD MYBook - its only the direct access to my films via Serviio Server which is no longer working since the update.
Thanks for your help
Toura Lou
Post Tue Mar 04, 2014 9:16 pm
Re: Samsung C-Series - No Films since update to 1.4
Are you using the right profile?
touralou
Post Wed Mar 05, 2014 7:41 am
Hi Petr,
thx for your reply
the profile should be ok - checked: the profile file was generated in 12/2013 - and worked fine until the update
TV is configured to C/D Series
what should I check?
rgds Toura
touralou
Post Wed Mar 05, 2014 8:05 am
Hi Petr,
additional Info - just checked the 2nd TV UE32D5700 - Video Database is complete and working
but UE40C6200 still can not find any films but music and picutes
... I installed Serviio to watch .wtv films - some films work - some new films don´t - but this will be another question
thx Toura
Post Wed Mar 05, 2014 7:37 pm
No idea. It works on my C series TV.
touralou
Post Thu Mar 06, 2014 3:23 pm
thx for your attention
maybe I will install serviio again...
rgds
Toura
touralou
Post Sun May 11, 2014 2:58 pm
[SOLVED] Re: Samsung C-Series - No Films since update to 1.4
new installation did not help
but since thee update to 1.4.1.2 everything works fine again
as far as I can see in my network
Also wtv files are streamed - even in the browser version.
thanks for all your energy and the great program.
rgds toura
