Online metadata "tvdb" how to force specific show?
thenamelessthing
Post Sun Mar 02, 2014 2:52 pm
Hi all, is there any way to force specific show by it's show number or any other way to retrieve online metadata? Ex: adding show ID in the parent folder
My case is I have Sherlock Holmes comic series from 1984 but for this year it exist 2 Sherlock Holmes series and serviio doesn't pick the right one..
I know I can fix it locally, but I don't want to do that if I can..
Thanks you for your help!
"Envoyé depuis mon SAMSUNG-SGH-I747 avec Tapatalk"
My Setup : BDT220 Panasonic Bluray player, TC-L55ET5 and TC-L42ET5 Panasonic TV. My home media server run Serviio 1.4.2 Pro under GNU/Linux Ubuntu 14.04 LTS server x64 and the hardware is Amd 1045t Phenom II X6, 6Gb DDR3 1333 mhz on SSD and data on soft raid 5 (3x1tb).
Post Sun Mar 02, 2014 11:32 pm
Re: Online metadata
There is a related request to assist finding metadata for movies based on the imdb number - see https://bitbucket.org/xnejp03/serviio/i ... for-movies. Maybe append that request to include similar for series.
I had a quick look in the thetvdb.com and couldnt work out what the two series in 1984 are. What are you seeing, maybe I can help to find a filename that differentiates the two series. (or what are the two series ID's?)
thenamelessthing
Post Mon Mar 03, 2014 2:06 am
Re: Online metadata
The id for the right show is: 73082 and the metadata serviio apply are from the serie 73529
thenamelessthing
Post Mon Mar 03, 2014 2:10 am
Re: Online metadata
and I have another question btw. I just added Starwars ep V. why is sorted after the VI?? Any possibility to order them by the real order and not computer like order?
Post Mon Mar 03, 2014 2:33 am
Re: Online metadata
thenamelessthing wrote:The id for the right show is: 73082 and the metadata serviio apply are from the serie 73529
Am confused - 73529 is a 1954 series (not 1984) - see http://thetvdb.com/?tab=series&id=73529&lid=7. 73082 is an 1984 cartoon called Sherlock Hound - see http://thetvdb.com/?tab=series&id=73082&lid=7.
If you want the 1954 show, then a filename of simply Sherlock Holmes S01E01.xyz worked for me??
thenamelessthing
Post Mon Mar 03, 2014 2:35 am
Re: Online metadata
Ho Sorry for the mistake! Indeed is Sherlock hound.. It's my error. Sorry! Because in french they translated the title by "Sherlock holmes". This caused the mistake when serviio retrieve the metadata.
thenamelessthing
Post Mon Mar 03, 2014 2:42 am
Re: Online metadata
By the way, I have observed many time french character are not supported. Episode with é or è by example are not added when I scan for metadata.... ;-( I have to change every character with en "é" or "è" for an "e".
It is normal?
Post Mon Mar 03, 2014 2:47 am
Re: Online metadata
No problems.
No idea, even on the computer VI comes after V?
I have the same problem for movies which are part of a set where the names are not alphabetical (eg. the Harry Potter series, the Indiana Jones series). Other than creating custom metadata I haven't found an answer (I havent really looked either - it hasn't worried me).
I have to change every character with en "é" or "è" for an "e". It is normal?
Sorry - perhaps zip or Illico can help. I thought it would follow the language that you specify under the Metadata tab, Video, Language option in serviio console but perhaps that only applies to what info is retrieved, not what is search for??
thenamelessthing
Post Mon Mar 03, 2014 2:54 am
Re: Online metadata "tvdb" how to force specific show?
For the french accent problem, everything look fine in mediabrowser. The problem is only when I try to add file which contains these kind of accent.
Post Fri Mar 07, 2014 10:00 pm
Re: Online metadata
For the accent issue see zips response here: viewtopic.php?f=5&t=16117#p88656
Users browsing this forum: Baidu [Spider], Google [Bot] and 21 guests
