Streaming VIDEO_TS how can i choose the language?
lobo00
Post Sat Feb 05, 2011 4:43 pm
Hi all,
everything is working OK, using serviio as media server for LCD TV KDL-40EX508, I can see the files and i can start the dvds.. all is fine. But sometimes i would like to change the language of the moovie and didn't find any possibility to do this. Are there any possibility to chance the default language of the DVD ?
Thanks a lot for your support
regards
Karl
Post Sat Feb 05, 2011 4:49 pm
Re: Streaming VIDEO_TS how can i choose the language?
lobo00 wrote:...I can see the files and i can start the dvds..
What do you mean by dvds? VTS_xxxxx.vob files?
lobo00 wrote: all is fine. But sometimes i would like to change the language of the moovie and didn't find any possibility to do this.
On remote control, you have the "Audio" button.
lobo00
Post Sat Feb 05, 2011 5:21 pm
Hi Illico,
Yes, i mean the VTS**.VOB files.
The Audio button on the remote control change the audio 1 to audio 2 but there is no change of the default language. It doesn't work for me. Maybe is possible to set the subtitles but i don't know how to do that..
Karl
Post Sat Feb 05, 2011 5:38 pm
I confirm that on Sony Bravia TV renderers
- audio track selection on .vob files are not supported ( "Audio" button on remote control)
- subtitles selection are not supported (....) button on remote control
http://samples.mplayerhq.hu/MPEG-VOB/ClosedCaptions/
For example:
/ffmpeg.exe -threads 1 -i "D:\temp\Starship_Troopers.vob"
686-mingw32-
  libavutil     50.36. 0 / 50.36. 0
  libavcore      0.16. 0 /  0.16. 0
  libavcodec    52.108. 0 / 52.108. 0
  libavformat   52.92. 0 / 52.92. 0
  libavdevice   52. 2. 3 / 52. 2. 3
  libavfilter    1.72. 0 /  1.72. 0
  libswscale     0.12. 0 /  0.12. 0
[mpeg @ 015fd0b0] max_analyze_duration reached
Seems stream 0 codec frame rate differs from container frame rate: 59.94 (60000/
1001) -> 59.94 (60000/1001)
Input #0, mpeg, from 'D:\temp\Starship_Troopers.vob':
  Duration: 00:00:51.28, start: 1986.626100, bitrate: 4620 kb/s
    Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], 9800 kb/s, 23.98 fps, 59.94 tbr, 90k tbn, 59.94 tbc
    Stream #0.1[0x83]: Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
    Stream #0.2[0x82]: Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
    Stream #0.3[0x80]: Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
    Stream #0.4[0x81]: Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s
    Stream #0.5[0x20]: Subtitle: dvdsub
    Stream #0.6[0x22]: Subtitle: dvdsub
lobo00
Post Sat Feb 05, 2011 6:30 pm
Illico, thanks a lot for your support!
regards
Karl
